Ok i have a 95 f-350 and i keep seeing a sweet grille on other trucks that ive seen driving around. it has aluminum bars across the front. i have NO IDEA where i can get this. all the ones i see are for the new body style. any suggestions would be great
Are you talking about something like this? This is a billet grille, you camn find them at ant aftermarket parts place, and also you cam find them on E-bay!!
1996 F-350, CC, Dually, 2wd, torreador red, tinted windows, rollpan w/hidden hitch, Cervini's fully functional ram air cowl hood, Diamond cut headlights/parking lights, billet grill, 93-95 lightning front bumper/ valance, lightning buckets and center seat in front, lightning buckets and subwoofer enclosure mounted in between, 2 10" diamond audio subs, Sony Amp, pioneer head unit, Eagle Alloy series 129/130 wheels, Bilstien shocks, triple pillar pod w/ stewart-warner boost, EGT, and Trans temp, Tymar intake, Tymar HPX, BD 45h.p. chip, Fumoto drain valve, fuel heater mod, Stancor GPR,Coolant Filter, Tymar 3x4" DP, 4" back turned out before rear wheels with Stainless 4"x5" slant tip
Mods to come: I have these just need to install: banks wheel, 203 degree thermostat
CLICK HERE to go to LMC TRUCK PARTS and look at the bottom of the three in the picture. Should be what you want.
LMC is a good source for all kinds of parts for the OBS trucks.
Dave / Believer45
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
i took my stock grill off and had it painted green matching my truck came out pretty sweet
__________________ 97 f250 7.3 powerstroke all stock cept for the 3in downpipe, 4in stright pipe to the 5in tip245,xxx miles and still going. avg 18-20mpg
