Well I am sure some of you have done this but I am ordering guages here soon and was going to power the guages from the same source that powers the stock guage cluster lights so they all come on together, where would I tie in at? Would I have to run a relay due to an overload? Thanks.
I just used a fuse tap off of the fuse for the instrument cluster.
No issues with blown fues for me.
Most of the guages come with some instructions for install.
Tim
You know I was wrong I did the wire tap into the lights too, must have been thinking of something else.
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
I tied mine into the gauge lights, by tapping into the wire that goes into the headlight switch(I believe it is a white wire with a blue strip). With the gauge lights hooked to this wire it allows me to dim the gauge lights when I turn the headlight knob to dim the gauge lights. If no one else chimes in I can look and make sure tonight when I get home. Hope this helps.
95 F-250 LWB PSD 4X4 extended cab auto trans, 6-inch superlift with super runner steering, 37X13.5-17 Toyo - Open Country M/T tires and American Racing - Clash (Black)rims, TYMAR 3x4" DP, TYMAR 4" straight exhaust(lost the cat during install), coolant filter, 10K Mod, FPR shimmed, Gutted EBPV, Autometer Ultra Lite boost, pyro, & trans gauges in the A-pillar, 26K GVW transmission cooler, K&N FIPK, Warn manual hubs, 95 windstar dual electric fans, Viper Alarm with remote start.
Thats EXACTLY what I was looking to do because I wanted to be able to dim them as well, do you pull the big dash panel to get in there? Yeah if you could let me know what what color the wire is that would be great!
