Old 03-16-2005, 09:06 PM   #1 (permalink)
My Photos: (39)
Gutting the EBPV.....
What tools and stuff do I need so I can get it done this weekend?
Paul/TP
Houston Area Powerstrokes
I have a VERY bad case of DIESEL-I-TITS!!!! [img]/ubbthreads/images/graemlins/crazy.gif[/img]
<font color="blue">My 1995 250 S/C LWB PSD <font color="red">4x4</font></font>, SWAMPS Babies[img]/ubbthreads/images/graemlins/smokin.gif[/img], 6pos. Flip Chip by twildman, Isspro gauges, Hypermax DP & twin 5" stacks, TYMAR intake & HX hose, On Board Air, 4" Superlift [img]/ubbthreads/images/graemlins/smile.gif[/img], 35" A/T's, 5spd. w/Luk, 4:10's, Window guards,Carr steps [img]/ubbthreads/images/graemlins/smile.gif[/img], Pioneer Cd player, APC clear corners cab lights & side markers and headlights,Ranch Hand Grill Guard & rear bumper, AC mod
<font color="red">Tri-Community Volunteer Fireman </font>
BigStroker is offline
Old 03-16-2005, 09:14 PM   #2 (permalink)
Re: Gutting the EBPV.....
damnit paul, I AM BIRDMAN. lol You need a die grinder metric socket 12 points, and a freeze plug. Some people tap it, but i plugged it, i dunno, i get that often! HAHAHA
Thanks,
Jeff
1996 F-250 Powerstoke Diesel XLT, smokes bad, rides kinda rough.
open element air filter, H2E turbo, Custom Tranny, 6.0 Charge air cooler, Swamp 175/173 squirts, TS chip, A Cool Radio, COBRA truck condom.
WEBSHOTS--&gt;http://community.webshots.com/user/dieselwiezil
--&gt;http://houstonareapowerstrokes.com
DieselWiezil is offline
Old 03-16-2005, 09:19 PM   #3 (permalink)
My Photos: (39)
[/ QUOTE ]Jeff,
Yeah I know your BIRDMAN....I gotta git this truck rollin like BIRDMAN.
What size socket and what size freeze plug will I need?
Paul/TP
Old 03-16-2005, 09:42 PM   #4 (permalink)
10mm i think, now you better check it first cause im having withdrawls from not being able to play with the truck. Not sure on the freeze plug, goto vatto zone and check them out. I forgot to add you need a buddy and a set of SMALL hands.
Thanks,
Jeff
Old 03-16-2005, 09:52 PM   #5 (permalink)
Freeze plugs are supposed to be 20mm. But when I did mine I had to go back and get 19mm. May want to get both??...
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 A/R exhaust housing, vdo gauges, 279,000k
http://community.webshots.com/album/549770704UdvVUs
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, gauges, 6oh intercooler(GTS Kit), Tymar intake, HPX, .84a/r housing, 203* stat, 4pos Wildman chip!
ltfox is offline
Old 03-16-2005, 09:55 PM   #6 (permalink)
My Photos: (5)
You can also use a carraige bolt if you are worried about the freeze plug falling out. That's how I did mine and it was definitely quick and easy. The bolt top barely sticks up inside at all and it's pretty smooth, but you have the bolt threads sticking out the bottom. It's really not a bad job if you've got something that can take care of the rivets.
If you haven't had your EBPV off before be ready to beat the crap out of that rear bolt. I suggest putting the wrench on so it's sticking straight up in the air, put a piece of pipe up to it sticking out 90 degrees towards the engine bay, and then get out the BFH. Works like a charm [img]/ubbthreads/images/graemlins/grin.gif[/img]
Good luck, shouldn't take you more than 1-2 hours from start to finish with access to a die grinder.
Steve
Truck: '97 F250 PSD , ext. cab, shortbed, 5-speed, 4wd, 4.10L
Upgrades: BDP Stage I's, Stealth HPOP, BB Turbo with 1.0 wastegated housing, 6 pos DP Tuner chip, SBC OFE, dual SD fuel pumps, traction bars, US Gear OD, MAP regulator, SP Dongle, downpipe, extra 45 gal fuel tank, EGT-boost-TIP gauges, bilsteins, TYMAR, no cat, 3.5" flowmaster into 4" exhaust, gutted EBPV, XM SKYFi2, cab lights, BFG AT 285/75/16, Autoenginuity, 169k on 5/10/06
Coming soon: 6.0 Intercooler
Dyno'd 298/575, 296/582 before Stealth and Turbo
swh22 is offline
Old 03-16-2005, 11:10 PM   #7 (permalink)
Don't forgot to unplug the EBPV connector or gut that thing out too.
'89 F-250 XLT IDI Pickup
'92 F-450 XLT w/'97 PSD, 6-sp trans and intercooler w/ Century 412/F6000.
'92 F-450 XLT IDI w/ Century 412/F1
'94 F-350 CC XLT IDI Turbo Dually Pickup (SOLD)
'94 F-450 XLT IDI Turbo w/ Century 412/F1. (SOLD)
'01 F-550 CC XLT PSD 6-sp 4x4 w/ Century 502/F6000.
"The impossible just takes a little longer!"
ibuytoys is offline
Old 03-16-2005, 11:13 PM   #8 (permalink)
if you turn the ebphousing where the plug you put in is facing the front of the motor and up a little bit it will be a little easier to put back on. It will go on anyway as long as the bolts line up.
Thanks,
Jeff
Old 03-16-2005, 11:44 PM   #9 (permalink)
they're 8mm 12 pt cap screws (bolts), but my 5/16 ratchet wrench happened to fit, and made things a lot faster
95 f250 psd reg cab XLT 4x4 5sp 4:10 188k
diy tymar, big exhaust, 4 pos chip burnt by bdp, carbon fiber gauges, luk smfw
bean's stage I's
new ride: 02-99 f350 srw cc lb 4x4 6sp 3.73 stock, previous owner installed some kind of 10k, or 18k mod, true milage unknown
1064RG is offline
Old 03-16-2005, 11:44 PM   #10 (permalink)
My Photos: (39)
[/ QUOTE ]Been unplugged for 2yrs....lol
Paul/TP
Old 03-16-2005, 11:45 PM   #11 (permalink)
My Photos: (6)
[/ QUOTE ]Hey, sweet idea......Thanks
helixhippie is offline
Old 03-16-2005, 11:46 PM   #12 (permalink)
My Photos: (39)
[/ QUOTE ]Jeff,
Remember I am the buddy with small hands [img]/ubbthreads/images/graemlins/tongue.gif[/img] Besides if nothing else my little bro can get it....lol
Paul/TP
Old 03-17-2005, 12:01 AM   #13 (permalink)
Just to be safe, I would either remove the arm on the EBPV actuator and plug the actuator hole, or seal around where the actuator arm comes out of the housing with JB Weld or similar. They're notorious for suddenly leaking after gutting the EBPV, and it's much, much easier to fix when the turbo is off!
Just my $0.02! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Good Luck!
1997 F250HD Regular Cab 4x4, 4.10 SRW, Handshaker ZF5 Tranny, Bean Stage I's, TWildman 4 Pos Chip, 3" Downpipe/4" Exhaust, Tymar Intake, Luk Single Mass Flywheel/Clutch, IDM Mod, Ford AIC, Stancor GPR, HX Mod, Gutted EBPV, Dead Kitty, Coolant Filter, 203* Stat, Twin Electric Fans, A/C Mod, GPR Bypass System, 1.0 A/R Turbo Exhaust Housing
There's no Substitute for Cubic Inches!!!
F250Jockey is offline
Old 03-17-2005, 12:02 AM   #14 (permalink)
RSP
My Photos: (17)
They take a 5/16 12 point. 8mm is too big and fits looser then the 5/16. For the freeze plug ask for a Dorman 555-012. Get 2 and drive both in and then Stake the outer edge of the hole so they cant come out and your set. Use a Die grinder to grind the Buttons off of the rivits Flush and then drive them out with a punch and then the shaft will come out. Drive the Bushing out also.
2006 F250 CrewCab Lariat FX4 6.OH AFE, MBRP SS Cool Duals, Elite SCT, 4 Up the pillar, Bed Rug and Retrax Lockable cover.
1997 F350 CrewCab XLT 4x4. ?hp/?lb-ft Intercooled, BTS Trans, BTS Dual HPOP, Big Full Force Diesel Jectors, Big Turbo, Ford AIC, Rockin S Custom 5 inch Exhaust w/AeroTurbine Muffler, AFE Stage II Intake, Total Diesel Performance 4 Positon Chip, White Face Gauges,
1979 F250 SC Lariat 4X4 5.9 CTD, BTS E40D, Dana 60/Sterling 10.25, SD HydroBoost brakes, 440HP 992lb-ft, Intercooled, BFG All Terrains on Eagle Alloy 102s. Custom Rockin S Dual stack Exhaust system. DDP Stage IV injectors, HTB2 Turbo, Snow Water/Meth injection
My Webshots page
RSP is offline
Old 03-17-2005, 12:21 AM   #15 (permalink)
my bad, it is an 8mm, I wire brushed the bolts and put some anti-siez on them too.
Thanks,
Jeff
