Old 06-20-2008, 03:34 PM   #1 (permalink)
drwoodchopper's Avatar
Gutting the EBPV for lower EGT's
I am thinking of doing this when I install my new downpipe. I only want to do this if it will lower my EGT's. I was thinking of wiring for an exhaust brake but it doesn't sound like it works that great but if I can lose a little on the egt's I will do it. How much have you guys seen?? It has probably been beat to death but I couldn't find what I was looking for on the search page.
1997 F350 CC4X4 88K superclean truck Superchips custom tuned! IDM mod(it works!) Pyro, Boost and Trans Autometers over mirror. Tymar downpipe and 4" straight pipe! 285/65X18's Dune Grapplers. Shimmed FPR. Aftermarket trans cooler Tymar Intake. (intercooler,stg II's and 17*hpop to come then D66turbo) 1997 F350 XLT 4dr 125K 5" Pipe no muf and no kitty (totaled). 04/04 F350 EX Cab LWB "Leveled" Lariat FX4 Limited slip. BFG's 295/75R16. 4" pipe from back of kitty exiting in front of rear wheel. Autometer Pyro and Boost guages 65K. 422hp and 772tq (SOLD) 96 F250 powerstroke extended cab. Original E40D 132K Wood hauling machine. 10k MOD. Autometer Pyro and Boost gauges. Gutted Cat. Sold.
1966 Mustang "mostly restored" It only takes money which is always scarce and I would rather spend it on the beast!
drwoodchopper is offline
Old 06-20-2008, 08:21 PM   #2 (permalink)
I have read that gutting it lowers about 20*. Maybe some other chime in.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; gutted Kitty; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 06-20-2008, 11:50 PM   #3 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
I saw about a 50F drop in EGT's when I did mine. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is online now
Old 06-22-2008, 01:59 AM   #4 (permalink)
Dale I's Avatar
My Photos: (19)
If you want, shoot me an email and I can send you instructions on how to do this, which will include pictures so you don't get too lost. I see guys using freeze plugs to close the opening left by the shaft once it is removed and (personal opinion here) I think this is a VERY bad idea. Freeze plugs were never designed or engineered to take that type of heat. A much better way to do it is to knock out the sleeve that the shaft rides in and tap the cast metal for a 1/2 inch pipe plug. Screw a pipe plug in it and go on down the road.
As much as I'm sure I will hear, "I've had a freeze plug for .... long and no problems", I've had at least two customers call me with the freeze plugs melted out. Not a problem if it happens around town and you just need to get home and take it apart. Larger problem while on vacation with the family and you can't run the heater or AC because of the exhaust piped into the cab.
The issue most guys wiring for exhaust brakes will not consider is that the solenoid is a 10v max unit and they are applying 12v to it. What they don't realize is that it is a segmented 12v signal that will actually close 100 percent at a 8v level. IF you decide to wire yours up, definitely reduce the 12v signal to an 8v max.
Again, I've had customers burn the solenoid, which isn't a problem around town but is when you are away. I don't know about you guys, but nothing ever breaks down in my driveway...
Thanks for reading, Dale
Pics 1995 F350 - To much stuff to list,
more money spent than I want to admit.
Dale I is offline
Old 06-22-2008, 03:59 PM   #5 (permalink)
Send a message via AIM to mark97psd
hey if your sending instructions ill take a copy im expecting a downpipe in a couple days soi was going to do that when im already in there. thanks e-mail=yamaha2043@aol.com
1997 F-350 PSD: AFE Stage 2, custom exhaust exits in front of rear tire, A-pillar gauges(boost, pyro, trans), Superduty Cab lights, and a long list of other mods not done yet.
http://community.webshots.com/user/mark97psd1
mark97psd is offline
Old 06-23-2008, 02:43 PM   #6 (permalink)
I actually have your instructions Dale I got a downpipe from you! I was going to do it this week end but my local hardware store didn't have anything bigger than 1/4"npt tap. I am headed out of town for 3 weeks for big trout in AK so I will probably have to wait until then. I was hoping for a 20-50* drop so I will probably do it and forget the brake idea,
Old 06-23-2008, 10:42 PM   #7 (permalink)
I would be interested in those instuctions. Whats the chance of forwarding them to me? Thanks...... email tjseitz@bellsouth.net
Tom 96 F350 4dr. 75k Alpharetta GA.
tjseitz is offline
Old 06-24-2008, 01:03 PM   #8 (permalink)
Dale I's Avatar
My Photos: (19)
Emails have been sent. Check your in boxes.
Dale I is offline
Old 06-26-2008, 02:38 AM   #9 (permalink)
Dale, could I get those instructions too, please? You can send them to tattooed (at) starband.net
Thanks!
'95 F-250 ex-cab 4x4, 7.3 auto
Tymar intake
ITP oil x-over pipe
tps mod
fuel pressure shim
Tymar exhaust (soon)
Sarge1400 is offline
Old 07-01-2008, 12:05 PM   #10 (permalink)
Dale I's Avatar
My Photos: (19)
Done.
Dale I is offline
Old 07-01-2008, 12:23 PM   #11 (permalink)
Supporting Member
CSXPAID's Avatar
My Photos: (14)
Hey Dale can you send me them also? CHEVYDEVY@hotmail.com
Thank You
DEVLYN
1996 F-350, CC, Dually, 2wd, torreador red, tinted windows, rollpan w/hidden hitch, Cervini's fully functional ram air cowl hood, Diamond cut headlights/parking lights, billet grill, 93-95 lightning front bumper/ valance, lightning buckets and center seat in front, lightning buckets and subwoofer enclosure mounted in between, 2 10" diamond audio subs, Sony Amp, pioneer head unit, Eagle Alloy series 129/130 wheels, Bilstien shocks, triple pillar pod w/ stewart-warner boost, EGT, and Trans temp, Tymar intake, Tymar HPX, BD 45h.p. chip, Fumoto drain valve, fuel heater mod, Stancor GPR,Coolant Filter, Tymar 3x4" DP, 4" back turned out before rear wheels with Stainless 4"x5" slant tip
Mods to come: I have these just need to install: banks wheel, 203 degree thermostat
My Credo: "TOO LOW FOR FAT HO'S"
_________
Truck Pictures @ http://www.myspace.com/chevydevy
My website with how-to's and pics @ www.freewebs.com/csxpaid
CSXPAID is online now
Old 07-01-2008, 12:25 PM   #12 (permalink)
Talking
Thank You
DEVLYN
X2 for me? gtddrmx@yahoo.com.mx
Thank you very much.
Old 07-06-2008, 03:01 PM   #13 (permalink)
Make sure you block off the rod that acuated the door. i left mine in there and it leaks oil all over the motor now. I need to get in there, remove it and put a self tapping sheet metal screw with some sort of j/b weld and block it off.
96 7.3 f250 4x4 ext cab , longbed, DIY intake, 3" downpipe, Cat delete,Gutted ebpv, tw 4chip. Clean fpr screen and a shot of power service in the tank. 19 mpg on and off the foot.
ryhed is offline
Old 07-06-2008, 03:47 PM   #14 (permalink)
gnxtc2's Avatar
Better yet, chop off the entire cavity.
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, US GEAR downpipe, Bilstein 5150s, Front add-a-leaf w/urethane bushings, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, Shimmed fuel regulator, 4" Exhaust-Straight piped,FORD AIC, Custom triple A-pillar gauge holder,B&M Supercooler, gutted EBPV, B&M Transpan, ART Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, 149K
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 07-06-2008, 07:01 PM   #15 (permalink)
Would someone mind forwarding the instructions to me?
damoruso20@hotmail.com
Also this is how ive cut mine so far 100_1513 pictures from friends & fun photos on webshots
TIA
Dan
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
