I would really like to do away with the whole acuator cylinder like I've seen some do but what is the ped made of? If you just gut the rod assembly and plug it does this starve the turbo for oil?
Any help would be great
Thanks Marc
97 F-250XLT 4X4 C/C SHORT BED PSD, D60 FRONT AXLE CONVERSION TYMAR OPEN AIR INTAKE, FULL 4" EXHAUST, DP 3 POS CHIP, BANKS BILLET TORQUE CONV.ISSPRO TRIPLE SET
97 HOLIDAY RAMBLER 32.5' 5TH WHEEL ALUMALITE
97 F-350XLT STD CAB 4X4 PSD, BANKS STINGER PLUS KIT
87 F-350XL 4X4 STAKEBODY 6.9 5 SPEED
(21 YEARS OLD) OLD ENOUGH TO SMOKE
77 F-250CUSTOM 4X4 CREW CAB SHORT BED 400M C6
02 EXPEDITION XLT
96 HONDA FOREMAN 400
GONE 3/6/07 BUT NOT FORGOTTEN LONG LIVE THE IDI
93 F-250XLT 4X4 4" BANKS SIDEWINDER+STRAIGHT PIPE, AND STRAIGHT AXLE CONVERSION
I don't see how just gutting it up cannot cause a problem. There is a pressure hole in the cylinder that will leak right to the return if not welded.
Trust me it works fine did mine right before christmas no problems.
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
I would go with a modded turbo pedestal from Rick96F250 He will take care of you. He can send you a modded pedestal that will NEVER leak.
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
I would go with a modded turbo pedistol from Rick96F250 He will take care of you!
Why spend cash when you can spend alittle time modding what you have when doing other chores,I did mine when I was putting in transmission and new up pipe gaskets.It really is not that hard and its almost free pipe plug cost me change I had in my pocket. Just my .02
If it worked for you great, the modded pedestal WILL also make removing the turbo almost fun. Without the barrel for the actuator the back bolts almost jump out! To each his own. I'm not trying to bring down what you've done. I'm only offering an alternative.
It leaks right to the return on a normally functioning one that isn't gutted.
The plunger is in between the pressurized port and the big oil return passage. The other port also goes to the return but is controlled by the solenoid. If you take the plunger out you are letting presurized oil albeit a small amount (the pressurized port has about an .080 hole it)go directly to the return all the time instead of just when the pcm is calling for the ebpv to operate.
I agree with the ease of the bolt thing but, I will upgrade to a s/d ped. and such when I get a gerrett ball bearing. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
You are doing good so far.
Still diong good.
Not so good now. The PCM closes the EBP valve by blocking the return not by asking for oil supply. The oil supply is always there and is always dumping except when the EBP valve is closed. Any time the engine is warm the oil supply for the actuator is dumping into the return. BTW the supply hole is .040".
Understood. I don't plan on going that route. My next turbo will be the D66. My pedestal will remain and I still would recommend it to anyone. Rick did a great job fabbing and welding mine. All in all it is a GREAT mod and the price ain't all that bad either. The SD pedestal is a great idea too, but like I said I want to keep mine and most people on here will keep their stock turbo and now with the D66 out, I would imagine there really is that many less people that would change pedestals. The welded pedestal is very clean and neat plus makes the turbo removal easy and I will never again have any leak worries.
