Old 12-23-2007, 10:14 AM   #1 (permalink)
Has anyone air bagged one of these trucks yet????
I'm Pull a 5th wheel camper with my 97 crew cab and after Timbren blocks add a leafs shocks and so on the truck just rides like crap and even stock it rode like crap. I see alot of guys using the super duty springs but I don't want to hack up the bumper or gain the 3" lift from the shackle rev. kit. So I see more and more new trucks fully air bagged and the fabrication isn't the problem for me I was just curious where to start looking for info. and if anyone has done it and what the results were.
Thanks Marc
97 F-250XLT 4X4 C/C SHORT BED PSD, D60 FRONT AXLE CONVERSION TYMAR OPEN AIR INTAKE, FULL 4" EXHAUST, DP 3 POS CHIP, BANKS BILLET TORQUE CONV.ISSPRO TRIPLE SET
97 HOLIDAY RAMBLER 32.5' 5TH WHEEL ALUMALITE
97 F-350XLT STD CAB 4X4 PSD, BANKS STINGER PLUS KIT
87 F-350XL 4X4 STAKEBODY 6.9 5 SPEED
(21 YEARS OLD) OLD ENOUGH TO SMOKE
77 F-250CUSTOM 4X4 CREW CAB SHORT BED 400M C6
02 EXPEDITION XLT
96 HONDA FOREMAN 400
GONE 3/6/07 BUT NOT FORGOTTEN LONG LIVE THE IDI
93 F-250XLT 4X4 4" BANKS SIDEWINDER+STRAIGHT PIPE, AND STRAIGHT AXLE CONVERSION
Supercab79 is offline
Old 12-23-2007, 10:58 AM   #2 (permalink)
Re: Has anyone air bagged one of these trucks yet????
Let ya know in about a month. I'm going to install firestone A/B on the rear.
97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07).
http://community.webshots.com/user/amberjax
amberjax is offline
Old 12-23-2007, 11:58 AM   #3 (permalink)
You complaining about the empty or loaded ride? What shocks are you useing?
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 12-23-2007, 01:04 PM   #4 (permalink)
js2941's Avatar
I've been using Kelderman air suspension on the rear for about 4 years now with Bilstein shocks. Has worked very well for me. I pull a 32' 5vr.
1994 F350 4dr SRW 2WD w/32" sleeper - 1 owner, ZF5, 410, Stock inj, SC1705 tuner, 3" BD dp, Isspro pyro & boost gauges, LUK flywheel & clutch, Kelderman air suspension(rear), YORK conversion air compressor (DIY), DIY Ex Brake & AIC, 340k
js2941 is offline
Old 12-23-2007, 09:03 PM   #5 (permalink)
i have air ride 100psi bags and i love them. i leave them on 80 psi and i have no problems with anything. i tow my sander for the winter and empty or full i can't tell the difference. i recommend them and the install was easy.
1997 f-250. 3" down pipe with 4" bully dog exhaust, edge plug in- maxed out, KYB, flatbed with BF goodies M/T,air bagged out and can tow anything.
spaz1 is offline
Old 12-24-2007, 09:07 AM   #6 (permalink)
First the ride sucked stock loaded or unloaded and with the Timbens and the add a leaf up front it's almost unbareable. I've never owned anything but a 1 ton or 3/4 4x4 trucks and for some reason the 97 crew cab rides the worst out of all of they. I've always run Rancho 5000 shocks and always had great results. The oil instead of a gas charged shock always seamed to calm the bone jarring ride down. Anyway I started looking into the Kelderman system and the prices are not that bad and they look way heavy duty.
So we shall see
Thanks Marc
02 EXPEDITION XLT
Old 12-26-2007, 12:05 PM   #7 (permalink)
I use the air ride set up from Kelderman Manufacturing. You can see it here
http://www.keldermanairride.com/category.php?id=1
I have had it for a couple of years pulling a 24' cargo 40,000 miles a year. I like it.
Midwestman
95 350 CC SRW 4X4 398k. Amsoil everwhere w/dualbypass filter. Early Centurion model custom paint (white with grey striping) Grey shell, brushguard, Flexsteel leatherseating wood trim and overhead console. BTS hold on tight E4OD tranny. Custom chip by Cale Thompson at BTS. Hypermax DP. Tymar Open element intake. Tru-Cool 28,000 GVW trans cooler plus Super Duty trans cooler. Super Duty Intercooler with GTS pipes. CCV mod. 3 pod A pillar guages with Isspro Pyrometer,Boost and Tranny temp guages. Fumoto oil drain. John Deere coolant eye. Sylvania Silverstars. Joe Servo IDM. BABY SWAMPS. Magnaflow 4" exhaust. Tymar Coolant Filter. Sirius satellite radio. Kelderman Air Ride on the rear. Mods as the budget will allow.I think I am almost finished.
midwestman is offline
Old 12-26-2007, 10:20 PM   #8 (permalink)
brencoracing09's Avatar
Send a message via AIM to brencoracing09
it says right in the advertisement that the only reason to use it is to gain a better ride? is this what you are going after because it says nothing in the kelderman kit about gaining weight
95 psd,cc,dually,long box,288k,xlt,diy open element intake,unplugged fuel bowl heater....damn that fuse 22
brencoracing09 is offline
Old 12-27-2007, 01:10 PM   #9 (permalink)
What is your goal a true air bag no spring or air bag load assist?
Many people have the air bags, a few have the Kelderman and there is at least one guy on here that has a true air bag no spring suspension. It was a crew cab 250 and red if I remember right.
1996 f250 crewcab chip 4inch exhaust homemade intake
Mike_Honcho is offline
Old 12-27-2007, 08:47 PM   #10 (permalink)
The ride of my 1997 crew cab is terrible. I mean it's bone jarring and if anyone sits in the back forget it I've had people bounce their heads off the roof sitting back there. With the fifth wheel on the rebound going over bumps or overpass transitions is down right scary. It feels like the trailer is going to rip the bed off or break the truck in half. I know an air ride hitch would help but the empty ride is even more of a problem. The truck holds the weight just fine. I just need a way to soften things up a bit.
Marc
02 EXPEDITION XLT
Old 12-27-2007, 08:57 PM   #11 (permalink)
You still didn't answer my question about full bag?
I agree you need to fix the truck first and then maybe consider an airride hitch. That has to be hard on the 5er! I have been looking for some Velvet Ride shackles that were made and discontinued. They are $100ish and easy to do.
What is your tire pressure in the rear when empty? Do you have factory helpers on the rear--if so are they touching empty or close to touching?
Old 12-27-2007, 09:06 PM   #12 (permalink)
Velvet Rides have been reincarnated and improved. sulastic
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 12-27-2007, 10:53 PM   #13 (permalink)
BlueMule's Avatar
My Photos: (12)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mike_Honcho</div><div class="ubbcode-body">there is at least one guy on here that has a true air bag no spring suspension. It was a crew cab 250 and red if I remember right. </div></div>
That's Jareds truck. You can see some pictures of it HERE The suspension was designed and built by a shop in Tucson. The last time he was here he took me for a ride, it just floats like a big ole cadillac. That truck is now for sale because he just bought an 08 F450. If anyone is interested send him a PM. He goes by Hellstroker on here or if you want his phone # send me a PM
BlueMule is offline
Old 12-27-2007, 11:33 PM   #14 (permalink)
When I look them up they have different numbers for 250 and 350's. And the same numbers for a 96 250 as a 2002 and different numbers for the 350 but the same for 350 96 or 2k+. Then the Excursion is the same as the Expedition.
Does anyone have these yet? I know the old BFG velvet rides were good.
Old 12-28-2007, 08:26 AM   #15 (permalink)
fixithud's Avatar
I looked at the Hellstroker pics, that was pretty cool!
I was also looking at the Kelderman front setup. It would be all I would need for a stock height truck. The only thing, right off, that popped into my mind was why not remove the front spring and replace it with a solid piece from the axle back to the rear spring mount. Basically to mimic the 'coil/radius arm' setup from the 70's that ford used.
The rear spring mount handles locating the axle with the factory leaf setup. I have not looked at the horizontal relationship of the spring mount the and the top of the axle pad though.
I thought it would make it look like a more custom setup than an add on.
Take a piece of proper sized material to fit the spring mount, sleeve it for a bushing, then weld on a plate at the other end that is drilled for the u-bolts. Add a center pin for the axle pad location and go from there with the kelderman bag setup.
Yeah, seems like a lot of work, I think I will just shut up and tie another fly.
Hud
95 F-350 cc xlt 4x4 srw
tymar air filter
4" exhaust with dp
gutted ebpv
kitty gone
3 position chip from Tymar, stock, tow, race.
99 F-550 xl 2x4 drw
12' Johnie Gregory Dump
six speed
stock with 230k
fixithud is offline
