Old 03-25-2007, 01:36 AM   #1 (permalink)
head stud install ?
i'm going to be doing this in the truck, so is there any particular order i need to go in since i wont be removing the head? how much do i need to jack up the cab for this? and what do most of yall torque them to? sorry for all the ?'s thanks
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
jasonlambert is offline
Old 03-25-2007, 01:48 AM   #2 (permalink)
GSXRTURBOQUAD's Avatar
Re: head stud install ?
Do one at a time, and torque them to 90lbs. Doesn't matter where you start. Loosen the cab bolts and jack up one side at a time(take one side all the way out). I jacked mine up a few inches(about the time the body touched the front bumper). I would suggest removing the front bumper. [img]/ubbthreads/images/graemlins/wink.gif[/img]
After one head is done, we tightened the studs to 120 in sequence(go to DI's website for that). Then go to 140 if you have H11's. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 03-25-2007, 04:20 AM   #3 (permalink)
Powerstrokenstang,
If you are using ARP studs, make sure you put the 8 shorter studs on the top row of the heads. They are only 5-6mm shorter than the rest so you'll have to look close. If you dont, the top base of you injectors will hit the studs.
Joey,
My new engine is thirsty for OIL!!!!!!!
03/98 F250 7.3,4X4,CC,SB,AT, 3.73, bought totally stock in 10/05 w/111k miles, #5 Cylinder burned up at 114K ml.
Upgrades since then= BTS T/C & V/B, 6.0 cooler, Van turbo, DIESELSITE= Dahl 100, Coolant Filter, Boost Relief Valve. FS2500 oil bypass, AIS air filter, Di/Pricol Gauges EGT, Boost and Trans Temp, Magnaflow 4" Turbo-back, Wicked Wheel (org. was bad), Fabtech 3.5" leveling kit w/ track-bar, rear Hellwig sway bar, Weld 16.5x12, 35x12.5-16.5, CCV mod,
117k ml 3rd motor now
DP Tuner stock-40-80-120, ARP studs, ITP Regulated Return Kit, new stock 7.3 I/C.
http://community.webshots.com/album/551035547SsFoES
Criminals love gun control -- it makes their jobs safer.
leonardo4760 is offline
Old 03-25-2007, 10:47 AM   #4 (permalink)
I can fix that. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
SDRCM #7
Old 03-25-2007, 11:00 AM   #5 (permalink)
ok thanks. do you need to use some kind of lube on them, they are arp's so thanks for letting me know some are shorter.
1969 mach 1 mustang
Old 03-25-2007, 01:34 PM   #6 (permalink)
They should come with instructions, if so follow them.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 03-25-2007, 01:42 PM   #7 (permalink)
TECH TIPS: ARP HEAD STUD INSTALLATIONS
Old 03-25-2007, 11:59 PM   #8 (permalink)
thanks guys they are used so no instructions, do we need to put sealer on the bottom of them? the link i was given said alot of head studs go in to the water jacket
1969 mach 1 mustang
Old 03-26-2007, 12:28 AM   #9 (permalink)
does anyone have a link to the torque sequence thanks
1969 mach 1 mustang
Old 03-26-2007, 01:12 AM   #10 (permalink)
torque sequence, Half way down the page not sure about sealant on the studs?
