DI makes a set! Some of the Super Duty guys are running them. I dont how much of a difference they make but it would have to make a HUGE difference before I'd pay that price.
If they actually make a difference I will make my own. Stainless all the way. Got to get through the holidays first. Do you think they are the same for vans and trucks?
Dann
