Old 07-10-2006, 01:53 AM   #1 (permalink)
HELP with EBPV upgrade!!!!!!
Gutted my ebpv, the plate and its shaft are removed. I tried to install the 20 mm freeze plug but it won't go in!!!! I tried tapping it in carefulley and that didn't work so I beat the you know what out of it and no luck. My truck is a 1995. Do some of them take different sizes?
Thanks,
Richard
1995 F350 Dually Crew Cab 7.3 Power Stroke
Stock truck so far but planning to add everything
Upgrades so far: 6.0 transmission cooler
rhuggins is offline
Old 07-10-2006, 07:41 AM   #2 (permalink)
Re: HELP with EBPV upgrade!!!!!!
Use an old socket and hammer to put the cup in.
97 F-250 PSD 4wd 5spd 4.10 open SCLB, Tymar intake, 3"dp, EBPV gut, Boost/Pyro gauges, SBC Con-O, Stancor 586-902 GPR, Royal Purple gear and tranny oils
clem is offline
Old 07-10-2006, 08:00 AM   #3 (permalink)
I had to use a 19mm plug in my 94. Had the same trouble... the 20mm would'nt fit.
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 A/R exhaust housing, vdo gauges, 279,000k
http://community.webshots.com/album/549770704UdvVUs
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, gauges, 6oh intercooler(GTS Kit), Tymar intake, HPX, .84a/r housing, 203* stat, 4pos Wildman chip!
ltfox is offline
Old 07-10-2006, 04:25 PM   #4 (permalink)
My Photos: (18)
Sometimes a 3/4 inch will work too.
Tim
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
New Toy: Can-Am Outlander MAX XT 650 -- AWESOME
5th wheel 2000 Dutchman 24RL with 12' slide
TCH777 is offline
Old 07-10-2006, 06:06 PM   #5 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
could always use a 3/8" carriage bolt too.
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille,
318hp 643tq
#24
sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
PSDan000 is offline
Old 07-10-2006, 11:14 PM   #6 (permalink)
Thanks for the help. I'll try a 19mm and if that does not work I try a 3/4 inch, and will post what worked.
rhuggins is offline
Old 07-11-2006, 12:05 PM   #7 (permalink)
My Photos: (5)
I threaded the hole with a pipe tap and put in a 3/8NPT pipe plug as I recall...
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 07-11-2006, 06:15 PM   #8 (permalink)
169stang's Avatar
My Photos: (5)
I just had a buddy weld it up. I'm sure you could go to any exhaust shop or perf. shop and have it done. I couldn't imagine it costing more than $20.
1997 F350 7.3L DI diesel CC duelly
Tymar 3" DP, 4" exhaust, intake. Gutted EBPV, modified pedestal. True-Cool Max tranny cooler. Tony "Wildman" 4 position chip. Autometer gauges
2005 Mustang GT street/drag car. 76MM turbo 800rwhp
1996 Mustang Cobra Mystic #93
1969 Mustang Coupe-302
http://good-times.webshots.com/album...ost=good-times
169stang is offline
Old 07-11-2006, 07:00 PM   #9 (permalink)
brahamfireman's Avatar
thats what I did and in doing so I discovered there is a bushing in the bottom that has to come out. this might be what is causing it to not go in.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
