Old 12-22-2007, 09:57 PM   #1 (permalink)
HELP --HPOP
installed new hpop on truck can not get to run only 200 psi cranking tryed diff ipr what did i do wrong ran before
DSRTECH is offline
Old 12-22-2007, 10:39 PM   #2 (permalink)
DaveBey's Avatar
My Photos: (212)
Send a message via AIM to DaveBey Send a message via Yahoo to DaveBey
Re: HELP --HPOP
DSR -- Check the oil level in the high pressure oil reservoir. Make sure it's topped off. [img]/forums/images/%%GRAEMLIN_URL%%/cool.gif[/img]
Cheers from Tulsa, OK! [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Dave
DaveBey is offline
Old 12-22-2007, 11:01 PM   #3 (permalink)
Re: HELP --HPOP
oil level full ran fine on old pump 1996 truck but not on sdpump does some thing else need changed
DSRTECH is offline
Old 12-22-2007, 11:24 PM   #4 (permalink)
johndeerebones's Avatar
Re: HELP --HPOP
Not insulting in anyway, but did you tighten the gear? if its spinning on the shaft it won't make enough pressure. Also check out the wires to the ipr, if it ain't getting voltage that's your problem.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 12-23-2007, 04:12 AM   #5 (permalink)
Supporting Member
Excavator's Avatar
My Photos: (11)
Re: HELP --HPOP
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: johndeerebones</div><div class="ubbcode-body">Not insulting in anyway, but did you tighten the gear? if its spinning on the shaft it won't make enough pressure. Also check out the wires to the ipr, if it ain't getting voltage that's your problem. </div></div>
Even if you tightend gear, double check the bolt because the gear might have been off a touch and when you spun over engine the gear seated in right spot but now bolt could be loose as well as the gear. This has happened to more people than you could beleive
Jim Sult / Excavator (we dig it)
Avatar- my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Stock for now Auto trans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 173000 miles
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, Tymar intake, 112000 miles
1997 F350 XL DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 175,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Excavator is offline
Old 12-23-2007, 07:36 AM   #6 (permalink)
DZLJIM's Avatar
Re: HELP --HPOP
DSR,
You do know that any time you mess with the High Pressure Oil System it takes ALOT of cranking. Actually, A LOT of cranking is an understatement.
You will not see more than 200 psi until it purges enough air out to build pressure.
It's not just going to fire right back up...
How much cranking have you done?
Have you tried to bleed the heads by cracking the oil plugs on the top of the heads?
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB
DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
DZLJIM is offline
Old 12-23-2007, 07:33 PM   #7 (permalink)
johndeere9610's Avatar
Send a message via AIM to johndeere9610 Send a message via Yahoo to johndeere9610
Re: HELP --HPOP
Give your starter a break went your cranking. and put a battery charger on it as well. Just to well everything else out.
1995 F-350, Auto (stock), 4x4, Crewcab, Longbed, 4" superlift, 35" BFG's All Terrains, E12000 Milemarker Winch, 5" miter stacks, 160cc Injectors, Shimmed FPR, Tymar Intake, Tyamr HPX, 7.3L Intercooler , 6.0L Tranny Cooler(Thanks Jon), ISSPRO Guages Trany/Boost/Pyro, Built tranny in garage being built.
WILDMAN NATION
RDRCM# 50
johndeere9610 is offline
Old 12-23-2007, 07:46 PM   #8 (permalink)
Re: HELP --HPOP
Also after you get it started up and get done checkin for leaks, drive around for a bit to help get rid of any air pockets. Mine started like crap for about 2 days until I went for a about a 30 min drive.
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 12-24-2007, 03:32 AM   #9 (permalink)
GSXRTURBOQUAD's Avatar
Re: HELP --HPOP
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: excavator</div><div class="ubbcode-body">Even if you tightend gear, double check the bolt because the gear might have been off a touch and when you spun over engine the gear seated in right spot but now bolt could be loose as well as the gear. This has happened to more people than you could beleive </div></div>Very good advice! That has happened many times!
Although, making 200 psi, sounds like the pump is turning. Check your IPR connection, as said above!
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 12-24-2007, 03:46 PM   #10 (permalink)
My Photos: (10)
Re: HELP --HPOP
Make sure you did not plug in the wrong plug to the IPR. The ebv plug is the same as the IPR, and MANY people plug in the wrong one......it is an easy mistake to make....
"If your talkin' bout me.....your leavin' somebody else alone.
wackerjr is offline
Old 12-24-2007, 11:21 PM   #11 (permalink)
Re: HELP --HPOP
Hey Jeremy, I think that only applies to the SD's. OBS trucks have a different plug on the EBPV. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
SDRCM #7
