i bought a 96 F350 turbo diesel 4x4 crew cab long bed. It was lifted when i bought it. I put 33's on it- In my mind it rides like crap and doesnt tow well either. My old truck was a super duty dually. I bought a 5th wheel toy hauler that weights 12000lbs two weekends ago and immediatly bought helper bags since the rear was saggin so bad. Im wondering if the previous owner put softer springs in it. I searched and found all the super duty and reverse shackle mods but I dont even know what i have. Heres some shots- The only marking i could find on the leaf spring was on the rear shackle it says VZ
Just a crap lift kit thats why it rides like it does..prime candidate for a RS kit SD spring mod!
Based on your third picture, there was some sort of modification done to the rear shackles. My initial guess was Velvet Ride but the shackles don't match what DZLJIM shows in his Velvet Ride Shackle Install article.
Cheers from Claremore, OK!
Dave
1996 F-350 XLT CC SRW 4x4 BTS-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●6.0L Fan●APCM 245,000 happy miles DZLJIM 3:16 ~~NTxPSA - Hold my beer and watch this.~~
so i found a set of sd springs online and the spring code says VA I know the fronts will work but what about the rear- Hes sending me some shots of them- he says they came out of a 2002 f250 diesel 4x4 and they do have the load compensator spring on the rear.
I know v is what im looking for but what about the rear?
scotzilla -- Not sure if this helps or not but here's the Springs description of the Vehicle Certification (VC) Label from the 2002 F-Super Duty/Excursion Workshop Manual.
Springs codes are listed as a two-part code. The first character listed is for the front springs. The second code listed is for the rear springs. Auxiliary rear springs may also be listed.
Front Springs — F-Series
Base part number — 5310 (RH/LH)
Pre-fix — F81A
B — Suffix BA
C — Suffix CA
D — Suffix DA
E — Suffix EA
F — Suffix FA
G — Suffix GA
H — Suffix HA
I — Suffix RA
J — Suffix SA
K — Suffix TA
L — Suffix UA
Pre-fix — 1C34
S — Suffix AAA
T — Suffix ABA
U — Suffix ACA
V — Suffix ADA
W — Suffix AEA
X — Suffix AFA
Front Springs — Excursion
Pre-fix — YC35
G — Suffix G
H — Suffix H
S — Suffix S
Pre-fix — 1C34
AG
AH
AJ
Rear Springs — F-Series
L — Rear air suspension
B — 1C34-5560-CB, F-250, F-350
C — 1C35-5560-DB, F-250, F-350
D — YC35-5560-EA, F-250, F-350
M — YC35-5A975-AA, F-450, F-550
N — YC35-5A975-BA, F-450, F-550
Auxiliary Springs — F-Series
A — YC35-5588-A (wide frame)
D — F81A-5588-D (narrow frame)
Rear Springs — Excursion
Base part number — 5560 (RH/LH)
Pre-fix — YC35
A — Suffix A
Pre-fix — 1C34
B — Suffix B
Dave
For 2002,
A = 6,084 pounds @ground = F-250
B = 6,840 pounds @ground = F-350 SRW and some F-250s
C = 8,250 pounds @ground = F-350 DRW
A's are "B"'s without the top overload spring, you can add them..just need longer center pin spacer and spring..I have all but the center pins..easy to get.
CARY- so if the spring code was VA and it has over loads they are the same as B's right? Im about to pay more in shipping then i am for the spring so i want to double check- Thanks
