Help w/clutch install - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 03-13-2010, 10:32 PM   #16 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
If you can't get the MTL, you need to get a SYNTHETIC ATF (such as Mobil 1 ATF). Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 03-15-2010, 06:36 AM   #17 (permalink)
Liked the Idea of redline but i couldn't get it local so I ended up with royal purple atf, Rear main and clutch are in....up pipe's broke a bolt, had to pull trubo to get it out fm running haha. Needs bushings in pedal assembly, had to adjust pto it works great now, clutch is esay to push in just real low in the floor. Up-pipes still leak or I still got a leak fm running haha.....
Bushings are worn up under dash especailly towards the passenger side,,,
95 F450 7.3 ZF5 159k 12'PTO Dump, 3"DownPipe,
Tymar Intake & Coolent Filter, SB CON O, DIY Exh Brake.
95 2500 RCLB 251k, HTT 57/65/12, 191 DV, 5x.012 Injectors, 4KGSK, S&B Intake, 5in exh, 33x12.5x17's PC EMT, ProjectorHL w/6k HIDS, Goerend Tripple Disk Auto, 4 Isspro's
BuckshotRam is offline
Old 03-15-2010, 08:27 AM   #18 (permalink)
you might have a manifold leaking or has a broken bolt.... in winter its easy to find them warped just make it start cold and smoke white like hell youll see the leak ;>
2005 KR CC SB Auto 6.0L - 4in straight to the back no muff or kitty, Upfitter High Idle mod, Blue Spring
1996 F250 Crew Cab LBox 5sp "Sold"
1967 Ford Fairlane 2Dr Post factory radio delete non ac, manual brakes, manual steering car. 80% restored working on interior Body and Paint done- 390FE stock oil eater, C6, Starshifter, Micky T Indy Style 60 Series on back. Originaly Black repainted black
1972 Ford Gran Torino Fastback 351 Cobra Sold
1979 F350 Custom Crew Cab Short Box replaced Torino for project vehicle..
2004 Lincoln LS8 "Sold"
2008 Kawasaki Brute Force 750 4x4i
96strokerlb is offline
Old 03-15-2010, 02:59 PM   #19 (permalink)
I was thinking of that, only time the truck will smoke...
Ive heard the up-pipe donuts will seal up more once they have some heat cycles on them. Any truth to that???????
Here's some more pics...
Help w/clutch install-atf.jpg   Help w/clutch install-broken-springs.jpg   Help w/clutch install-up-pipes.jpg
Old 03-15-2010, 11:37 PM   #20 (permalink)
I have discovered I have a broken head on the driver side exhaust manifold. The last bolt in the maniflold right next to the lower bolts on the up-pipe. How hard is it to pull the maifold?
