Help where to put tank heater into heater hose - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-09-2009, 07:24 PM   #1 (permalink)
midwestconnection's Avatar
I have a tank heater, think Kats or any other heater hose tank heater. Mine is a Kim Hotstart 2000 Watt but they all hook up the same.
They call it thermosiphon
Mine is horizontal but it could be stood up vertical as long as the "out" is up and below the water level both bottom and top.
The 1/4 inch drive coolant drain plug on the side of the block by the oil filter, I'm using the one on the drivers side if that's ok to the "in" on the tank heater and then the heater hose for the "out" "hot" from the tank heater.
I have a 1996 E350 Van and a good place to get to the heater hoses is from the inside drivers side with the doghouse removed.
There are two nice heater hose lines right there where I can get at them and complete my hookup. They are going to and coming from the auxiliary heater core in the side panel drivers side about 2/3 of the way back in the van.
The feed to this heater core comes directly off from the water pump and then circultates right back forward from this rear heater core and goes to the front heater core under the hood passenger side, and then from there the front return heater hose goes back into the engine I think.
I can't figure out which one of the two heater hoses, going and coming from the rear heater core to hook into.
Can anybody help please. Thank You
Bumper to bumper, Full Synthetic!!! Rotella T 5-40(7.3L) -- Mobil 1 Mercon V(E40D) -- Amsoil Extreme 75-90(Danas 60) -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 XLT Club Wagon 15 Passenger Van. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
Old 11-09-2009, 07:30 PM   #2 (permalink)
The hose that comes off the H20 pump is the supply to the heater core. The other hose is the return back to the right head.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 11-09-2009, 07:58 PM   #3 (permalink)
So it sounds like if I hook into the return hose from the rear heater core I will be bypassing the rear heater but going back into the right head on the engine after it goes through the front heater core. I sure hope this works. I've never done it before.
