Old 11-21-2006, 10:51 PM   #1 (permalink)
help wont run right
well here is the story, a couple hours ago i went to applebees and on the way the truck was runnin great [img]/ubbthreads/images/graemlins/smokin.gif[/img]. well when i left it didnt seem right, on acceleration it vibrated the whole truck. it does this on light or hard accel. also i could not get my egts above 1000 on the extreme setting, i tried on a hill where i usually hit 1000 on normal driving and this was to the floor. got home and started unhooking vc harness connecters(outside of vc) and when one whole side was unhooked it ran the same no matter what side i unhooked. these things can run on 4 cyl, but can they run on 3? thats seems to say they are all firing right [img]/ubbthreads/images/graemlins/shrug.gif[/img]. also my fuel filter was dirty but not too horrible, could this be the cause? thanks guys sorry for the long post, but this is my daily driver so all help is greatly needed
1996 f-250:115000miles,h2e,6.0 ic,3" intakes,studs,beefed-up e4od,4.10ls,add-a-leaf,straight pipe to one 5" stack,guages,diy intake,ccv mod,17*hpop,315/75r16 buckshots,170cc stage 2 diy injectors,wildman 4 pos. chip,timbrens
1969 mach 1 mustang
1965 Ford 4000 tractor:cone filter, 3.5" stack, mack truck nozzles(220cc), pump turned up
Sophmore at Bridgewater College
CURSURI SUMMUS NUDI!! latin for we're going streakin!!
http://community.webshots.com/user/machdriver69
jasonlambert is offline
Old 11-21-2006, 11:49 PM   #2 (permalink)
Re: help wont run right
Do you know anyone with a scanner or ae software? Did you check to see if the nut was still on your ipr to hold the solenoid on? Open the oil fill cap and smell for burnt wires, sometimes this makes wierd things happen.
richmondfarms is offline
Old 11-21-2006, 11:54 PM   #3 (permalink)
no no one w/ ae i have an evolution but that wont do much good im sure. i havent checked the nut, would that make it run like it was on 7 cyl.it still ran decent but nothin like it should.
1969 mach 1 mustang
Old 11-22-2006, 12:17 AM   #4 (permalink)
My Photos: (6)
check your connectors to your valve cover gaskets. my friends 96 had the same things goin on. the wire was just old and was get hot. check for burn spots look for smoke when its running. i ended up replaceing bith valve gaskets and the eng harness just to be on the safe side. his did the same thing pulled his horses out to the fair grounds just fine and when he went to leave it wouldnt run worth a s*&t.
97 F250 EXT CAB LWB. 4X4, HEAVY DUTY REBULIT AUTO(DONT LET BRAKES PLUS DO A TRANS FLUSH THEY SEEM TO HAVE TROUBLE GETTIN ALL THE OIL BACK IN THE TRANNY). BANKS DOWNPIPE,HOMEMADE TYMAR INTAKE, 18 K MOD.
87 F250 EXT CAB LWB 4X4 WAS AUTO NOW A 4 SPEED, STRAIGHT PIPED, REDNECK AIR INTAKE
86 F350 CC LONG SRW 4 SPEED, OWNED FOR TWO MONTHS THEN IT BURNED.
2000 F350 CC LONG SRW 6 SPEED ,STACKS AND AIR HORNS. 6.0 AIR FILTER, STRAIGHT 4 EXH TO THE 5IN STACKS- R.I.P. (WRAPED IT AROUND A POLE 80MPH)
PARTY LIKE A ROCKSTAR.....GO BIG OR GO HOME!
squirl919 is offline
Old 11-22-2006, 01:04 AM   #5 (permalink)
i didnt see any bad places on the harnees. ill have to get a better look at everything in the mornin. any more suggestions?
1969 mach 1 mustang
Old 11-22-2006, 11:29 PM   #6 (permalink)
is there anything else i can check. should i pull the vc in the mornin? it seems like it is runnin on 7 cyl, it even idles somewhat a rough. please help! i need the truck! Thanks guys!
1969 mach 1 mustang
Old 11-23-2006, 11:29 AM   #7 (permalink)
Replace your fuel filter, check fuel pressure, replace your IPR o-rings and also see if it runs better with the ICP disconnected, if so replace ICP. Do a search on these and you will learn how. If you are certain that it runs the same while disconnecting the different plugs then concentrate on things that control all cylinder and not just one, like all of the things I mentioned above. Good Luck.
97 cc PSD, Dually E4OD, 4.10, Tymar intake, International water pump w/filter , Amsoil , 3.5" DP, gutted EBPV, SD elec.pump w/ aeromotive reg. fuel system ,5K EOT ,JS IDM, Twildman chip, Gear Vendors, 7.3 Intercooler, 3/8 tranny lines, trucool max, 230k mi. Truck Pics
KCovey is offline
Old 11-23-2006, 11:53 AM   #8 (permalink)
My Photos: (6)
In order to really check the valve cover harness, you need to pull off the valve covers and then pop the under valve cover harness off from the valve cover gasket. Mine were all fine on the outside, and at the injectors, but once I cracked them off the vc gasket, the dameage was plainly visible.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 11-23-2006, 02:32 PM   #9 (permalink)
well pulled the driver side vc and first injectaint firin. wires are all good. pulled the coil or whatever it is off the top of the injector and the armeture screw was loose from doing the diy kit i guess but i tightened it, no good. so then i switched it with the one off one of the others and still no fire. what should i try now. thanks guys and happy thanksgivin.
1969 mach 1 mustang
Old 11-23-2006, 06:23 PM   #10 (permalink)
My Photos: (6)
if you can get a temp gun, check the temp on the out side of the block for all eight cly. if you cly is not fireing it wont be as warm as the rest and if its fire poorly there should be a noticeable differance in temp. good luck and happy thanksgiveing.
Old 11-23-2006, 06:48 PM   #11 (permalink)
brahamfireman's Avatar
pull both VC's off and run the truck, see if all the injetors are shooting out oil or just a few, the ones that are NOT are the problem ones. go from there.
try switch the UVC harness's front to back and see if the problem follows or stay with one injector, if it moves, then its the harness, if it stays with one injector swap solonoids on top and see what happens.
thats the easiest/cheapest way to find injector problems.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 11-25-2006, 05:33 PM   #12 (permalink)
i did switch harnesses and soloniods and still the same injector wont fire.what next??!! thanks guys
1969 mach 1 mustang
Old 11-25-2006, 07:21 PM   #13 (permalink)
Nit
I guess there's somethign wrong with it then
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
