Old 10-12-2005, 11:09 PM   #16 (permalink)
My Photos: (6)
Re: High Pressure Oil Crossover Mod??
How about this one ?
[img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
KCM S.S. HPX Line (94-97)
The KCM Stainless Steel High Pressure Crossover (HPX) line connects the driver side and passenger side High Pressure Oil Rails together. This results in a more balanced High Pressure Oil system with fewer pressure spikes (see Injection Control Pressure graphs below). In most trucks, the elimination of ICP spikes and balancing of pressures in the High Pressure Oil Rails will smooth operation and may even quiet the engine somewhat.
The KCM HPX line is constructed from only the highest quality components. Stainless Steel tubing and aircraft quality steel fittings ensure thousands of miles of trouble-free operation. Illustrated installation instructions are also included (click HERE to preview instructions).
KCM offers a 6 month limited warranty on the S.S. HPX line.
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Beans D-66 Turbo, 3 inch intake plenums, Early 99 spider
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
252,000 Miles and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
Old 10-12-2005, 11:27 PM   #17 (permalink)
and i bet it costs more than 20 bucks. not to sound arogant but a lot of us on this site r diy'ers and we take pride in that [img]/ubbthreads/images/graemlins/smokin.gif[/img] and maybe were a lil cheap too [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Joey
97 F-350,XLT, 4-dr, auto, 270xxx mi, Geolander A/T's, 4"exhaust, no ebpv, 203* t-stat, electric fans, lunar gauges, amsoil nose to tail, custom weight bracket and hitch for pullin, diy intake/air filter, hpx hose, LED cab lights, extra fuse panels, kenwood stereo system, pedestal from Rick, 4r100 out of an '01, trans mods from Jon, custom big fuel system, arb's front and rear, and 6.0 i/c, custom big oil
pics
"...the smoke rolled out and the day turned BLACK!"
stage II's
D66
THANKS BEAN!
awesome tuning
THANKS TONY!
'06 M7 153" Let it Snow!
joeyslushr is offline
Old 10-18-2005, 12:33 PM   #18 (permalink)
Guys! Can I please suggest extreme caution here. I too try to save a buck everywher I can. I am always looking for a way to cut out the middle man. But I also have first hand experience with a high pressure oil leak. I had an employee nearly roasted to death by a 2,500 lb hydraulic leak that sprayed on the turbo. There is a thread up on the SD side right now decribing a similar fireball that happened with a HPOP leak. IMO, this is not a place to save a few bucks! I have some experience with selecting hose for use to run engine oil lines on diesel engines. Engine oil deteriorated standard hydraulic hose rapidly. On one application I was forced to replace every year. This is on engine oil running at 30 to 80 psi (Cummins 855). On the HPOP system we are not only running hot engine oil but we are running it at high pressure (3,000) and with a lot of pressure impulses. At a minimum I would recomend a hose at least the same quality as the OEM. There is a lot more to this than just the pressure and burst ratings of the hose. Why not let some else assume th resonsibility to do the research on the long term use of the hose?
It's not worth being stranded or at worst burning your truck down. I'm planning to replace my original HPOP hoses as a preventative measure before placing any more demand on them. After all 10 years is a good life for any hose. Will the hose you made up last 10 years?
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
» Sponsor Links
»Garage Storage and Cabinets
