High pressure pump - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-24-2008, 04:58 PM   #1 (permalink)
High pressure pump
Hi there, back again and thanks in advance, i got a high pressure pump and i would like to know the difference between the 15 degree pump and the 17 degree pump without removing the back cover of it and if the only option is to removed the back cover do you know how to removed, i try the duck tape and did not work for me, i remember some body did it before with air but i can remember how to do it, any input will be appreciated, the numbers in the pump are 449c91-RR-orig (this is in the back cover and is flat) but the pump have the quick connectors like the SD, and the casting number is 1092238A. Thanks
tamasloco is offline
