just got my gauges, tymar intake, and 4 inch exhaust installed, no chip yet, still waiting for that to get here, and I'm getting around 18-20 psi when I hammer on it. Is this a normal psi range? theres no other engine mods. I did get more boost pressure, and top end pull after I put the exaust on, egt's where lower too. Oh and I can hear the turbo more now [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Thats normal, I noticed you had 4" exhaust, did you also replace the stock DP? If you have not, then you could get more by replacing it.
sorry just noticed the DIY E-brake
Thanks Clete
1997 F250 XLT PSD,CC,4wd,E4OD,4.10L,Hypermax 3" DP,Beans Stage I's, Tymar intake, 5" exhaust w/muffler rear exit, Intercooled, pedal mod, HPX cross over, 4 Position chip with some badazz burns, FPR shimmed, modded IDM, Isspro EV trans.temp in collum pod, and pyro guage and boost set in "A" pillar, tranny cooler ,remote trans filter, Fuel heater in the scrap iron, Precision Industries Stallion TC, Mag Hy-tech transmission pan.
Galaxy 959 peaked and tuned ,DM452 mic, Predator 10K
I was getting 17 max with everything stock. After my mods below, I am getting around 23.
I'd like to see what you get after the chip is installed. I am not sure if my programmer is giving me what I want, although I do get lots of black smoke.
Member since 11/27/1999 1996 F250/SC/4x4 BTS E4OD/Hayden 679 - 4.10/LS, BFG/ATs, Auto Meter, Tymar, Edge Programmer, DPP "exhaust products", 247K miles, B20 This winter:D66, DPP Reman Stage 2s, TW Chip
since we are on boost numbers i was wondering if this sounds about right . with my ats ic it would make 33-36psi and now with my superduty ic i am lucky to see 32psi . i know the volume of the pipes and the ic is much larger now but i just want someone to tell that these # are normal . thanks andy
1997 F-250 4 door
Dana 60 3.54,
4 in lift,
33x12.50r17 Mud Country on 17x10 Centerline Wolfer,
3in downpipe 5in exhaust with 7in tip,
Autometer NV gauges,
DP Chip (Thanks Jody),
Custom air intake,
7.3 intercooler,
Scheid 180cc injectors,
S/D HPOP,
BTS transmission,
D66 Turbo,
324 HP , 800 FT
60 Foot 1.90 , 1/8 mile 8.96 , 1/4 mile 14.30 http://rides.webshots.com/photo/2667...00260392FPVHjP http://www.andysgarageonline.com/
Andy, it not uncommon to see around 3-5 lbs drop in pressure with the larger cooler over the stock obs set-up. The temp loss across the cooler is the reason. But that in itself is a good thing. That means you are getting cooler, denser air with more 0xygen.....cooler air=less pressure....
thanks for the reply . i really was not that worried about it because the truck runs the same as it did with the smaller i/c . but when i saw the post about boost #s i thought i would ask . once again thanks andy
1997 F-250 4 door
Dana 60 3.54,
4 in lift,
Custom air intake,
7.3 intercooler,
S/D HPOP,
BTS transmission,
D66 Turbo,
324 HP , 800 FT
If your new intercooler is working better than you will get MORE air at less pressure. Remember, its air you want -- boost pressure is just a means to push the air in. The colder the air the more actual molecules will be pushed through the intake valves at a given pressure.
