Old 07-21-2007, 07:38 AM   #1 (permalink)
das5439's Avatar
Home made air breather
My factory air breather is cracking and falling apart. The after market assemblies are far to expensive for me so I'm going to fab one up myself.
I just need to know what filter element is used? I know someone on here made thier own because I've seen pictures but I can't find it now.
1997 F-350 4X4 PSD, 5 speed, SRW, 210K Rides like a bull ~ purrs like a kitten.
http://www.cardomain.com/ride/2603045/4
das5439 is offline
Old 07-21-2007, 10:33 AM   #2 (permalink)
Re: Home made air breather
Do a search for Tymar or DIY intake. I forget the filter number offhand.
Aaron SEIA
My Truck:
94.5 F350 dually crew cab psd 5 speed
0-35 lb DiProcol Boost gauge
DIY Intake
3" MBRP DP
AaronSEIA is offline
Old 07-21-2007, 10:47 AM   #3 (permalink)
mmcspadden's Avatar
Donaldson filter. I have a huge one on my Tymar. I can get you the exact filter number if you like. Just let me know.
1999.5 F250 PSD 4X4
Mgf. Date 07/99
http://www.mcspadden.cc/themule.html
mmcspadden is offline
Old 07-21-2007, 12:04 PM   #4 (permalink)
NAPA part #6637 and a piece of 4" exhaust tubing is all you need. i think the filter runs around 50-60 bucks.
95 Ex. Cab 4x4 Auto, Lots of Oil, Lots of Fuel, Lots of Air=Broke Truck
nycowboy is offline
Old 07-21-2007, 04:05 PM   #5 (permalink)
johndeere9610's Avatar
Send a message via AIM to johndeere9610 Send a message via Yahoo to johndeere9610
I know you can build your own. But a Tymar is only like $110 and it looks really nice. buy the time you drive and find the "4 pipe and get a filter, clamps, and coupling, and fuel. you are about at the same money with in 20 bucks. and the Tymar will come with a clamp on the filter to get it up off the wheel well and powder coated.
Just my 0.02 cents
Rusty
1995 F-350, Auto (stock), 4x4, Crewcab, Longbed, 4" superlift, 35" BFG's All Terrains, E12000 Milemarker Winch, 5" miter stacks, 160cc Injectors, Shimmed FPR, Tymar Intake, Tyamr HPX, 7.3L Intercooler , 6.0L Tranny Cooler(Thanks Jon), ISSPRO Guages Trany/Boost/Pyro, Built tranny in garage being built.
WILDMAN NATION
RDRCM# 50
johndeere9610 is offline
Old 07-21-2007, 04:19 PM   #6 (permalink)
that works too. i just had the stuff laying around along with a piece of diamond plate aluminum to make a homade box/shroud around the filter to hold it off the inner fender. it looks pretty sweet [img]/ubbthreads/images/graemlins/cool.gif[/img]
nycowboy is offline
Old 07-21-2007, 08:37 PM   #7 (permalink)
Believer45's Avatar
My Photos: (16)
Click intake link in my signature to see what I did with instructions as to how.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is offline
Old 07-22-2007, 01:02 AM   #8 (permalink)
You have to rest the filter 1/2 to 1" OFF the fender. Dale's intake system comes w/ a clamp that has a foot on it to give the filter that air gap.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RSD Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake * gutted ebpv * 4" exhaust & 5" tip * AlumaCraft diamond plate toolbox * custom antenna mount (108" whip) * Uniden cb * diamond plate bed rail caps * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25 * ccv mod * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * poly bushings (front) * Rancho RS9000 shocks * dual steering stabalizer * 60,279 on rebuilt engine (myself) as of 1/08
To do list:IDM mod
94strokerace is offline
Old 07-22-2007, 01:42 AM   #9 (permalink)
das5439's Avatar
Dave / Believer45
This is what I was looking for. However, I may just go with the Tymar since it's affordable. I just can't see spending 2 or 3 hundred bucks on the performance intakes like on e-bay and the like, frankly I don't see what makes them SO expensive.
I did a search for Tymar and I should be set....thanks guys.
das5439 is offline
Old 07-22-2007, 01:57 AM   #10 (permalink)
Good choice. You'll like it.
WILDMAN NATION
RDRCM# 50
Old 07-22-2007, 09:29 AM   #11 (permalink)
When I priced doing a DIY compared to Tymar I was within a few dollars and the black powder coated pieces look great.
Todd
AKA Toad
1995 Ford F250 7.3L, auto stock 390,000mi, filler neck Mod, 3" DP with test pipe (no cat!), Fumoto oil drain valve, BDP Stage I Injectors, Tymar Intake, DB Electrical High Torque Starter
1965 Ford Mustang Fastback 289 4bbl 75,000mi
1988 Honda CRX Si 1.6L stock
1988 Honda CRX 1.5L stock
1990 Honda CRX 1.5L stock
1991 Honda CRX 1.5L stock
1998 Kawasaki Vulcan 1500 Classic
1981 Honda GL500
1995 F350 7.3L Parts Truck
stang65fst is offline
Old 07-22-2007, 09:13 PM   #12 (permalink)
My Photos: (11)
For anyone thinking about doing a DIY intake here's a little somehting to think about. If you use exhaust tubing I suggest painting it so it doesn't rust & flake off on the INSIDE & go into the motor. At the very minimum, paint the inside of the tubing. This is what I did.
Although, if &/or I ever do it again on a different truck, I'm just going to call Dale. I've talked to him a few times by e-mail & on teh phone & I've met him in person once & he's just a top notch guy. To bad we don't have more people like him.
His: '95 F350 CrewCab, 3.55 SRW, 5spd std w/ Royal Purple, LUK SMFW, VDO Pillar gauges, Homemade open air intake, 3" Downpipe W/ 4" cat-back exhaust from Tymar, Tunes by DP Tuner, Baby Seat Mod on rear bench, 198K miles. It gets 21-23 mpg consistently (on the highway) and 17 mpg in town. My remaining planned mod list includes Amsoil & electric radiator fans.
Hers: 2004 Chevy Malibu Classic; 2.2Ecotec 4 cylinder. VERY dissapointed in mpg's.
Company Car (Daily Drive): 2007 Chevy Impala, Jet Black
cmichalik is offline
