How close is he on the completion dates? I am not good with waiting, especially after a date I am told, so I am just curious on your experiences. Just trying to pass time while waiting for my stage 1's from him.
FOR SALE - 1995 F-250 7.3 PSD auto 4x4,SC,269K, Rebuilt motor 100K warranty,3"DP, stage 1's, autometer- pyro,boost and trans gauges,Tymar intake,33-gal. Bronco tank.
He was right on time with me when he rebuilt my injectors to stage 1's. That was 16 months ago. BTW, have 42k on these injectors, no problems. He was also helpful with a problem I thought I was having with my chip, after the sale.
96 F350 reg. cab SRW 4x4, original owner. 5 spd. manual with a South Bend Clutch solid flywheel and Con-O clutch kit, clutch petal mod., Truetrac differentials, front and rear, 4.10 gears. Tymar intake, gutted EBPV, 3" downpipe, 4" exhaust, BDP stage 1 injectors, DIY IDM mod, 4 pos chip, Banks technicooler intercooler, shimmed FPR. 324k miles and still rattling.
everything I have gotten from him was on time or as expected...injectors, turbo, etc....I have no complaints at all [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
__________________ #14
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
Same here..just remember that some things are out of control of any vendor and [censored] happens, but it won't be their fault. Beans always bent over backwards to help me.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
I am sorry if it has taken longer then what you were told, we try to make a best geuss estimate on time frames but things do happen to put a kink in that such as the flow bench going down, more orders then expected at that time, etc... We are very busy currently (think its tax return time) and apologize for any inconvience for holding you up.
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems Stealth Dual HPOP Systems Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
I seriously doubt that you will find better customer support anywhere else. I had purchased a chip from another vender and immediately sent it to Ryan for a reflash and a set of Stage 1s. After installing the chip and injectors I had a problem. The selector knob would be in position #2 for instance, but when I started the truck it would start up in maybe the #5 position and it wouldn't switch to any other program regardless of the knob's position. Ryan told me that my warranty from the selling vender was voided because he (Ryan) had reflashed it. I wasn't aware of the warranty been voided until Ryan told me about it. And it was just one of those things that a vender doesn't think about, so Ryan certainly could not be faulted for it in any way, as far I as I concerned. But Ryan offered to replace the chip even though I bought it somewhere else. I wasn't to keen on that. I certainly didn't want to buy another chip, but on the other hand I didn't feel that it was Ryan's responsibility either. It was just one of those unpleasant situations that happen from time to time. He kept offering to replace it and I wasn't ready to give up on it yet, and luckily I discovered that the problem was that I had tightened the nut on the switch too tight and that was causing the contacts inside the switch to make contact with each other somehow creating the faulty condition.
So to make a short story long, you can see from my example that he is a stand up guy. You can't go wrong with dealing with Ryan Bean.
He is great to deal with, I sent him my injectors on a wednesday I also ordered a Tymar and a 6 position chip and by the following Tuesday everything was waiting for me on my porch when I got home. I put it back together wednesday night after work and have not had a problem, 17k since injector rebuild. Also bought a IDM and after I returned the core I had a check for the core charge in my mailbox in 2 or 3 days. Good Luck
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
I think Ryan is one of the finest people I've ever done business with. Two years ago he FedEx'd me a single stock injector (emergency repair), which arrived the next day, for dirt cheap. A few months later I bought Stage 1s, which were all I was told they'd be.
Last month I was in TN (GF's Dad passed away), and en route back to Ohio I decided to detour to Bean's. I called ahead and asked if he had the time to see me, and Bean said "sure, c'mon over". When I arrived I described the miss I heard, we talked a bit, then he grabbed his scanner and we went out to my truck. He scanned the engine both parked and underway, buzz test, contribution, everything. He then gave me a tour of the shop, his latest projects (one is going to be spooky fast when he's finished), and then refused to charge me when I offered to pay for his time. I will happily spend more at Bean's when I can afford to do so, and would encourage anyone to patronize his shop.
Josh
PS: Jonathan Ryan at Swamp's is every bit as stand-up-guy as Ryan; met him a couple of years ago at his shop in TN, and he took all the time needed to answer a bunch of questions, showed me around, etc.
PPS: Hey Bean - the miss turned out to be a VC gasket with a VERY small distortion in the plastic between the GP pin and the adjacent inj pin. I swapped it out today (first sunny 60*+ day when I didn't have to be elsewhere) and in the sun could see a crack between pins 1 and 2. HOLY COW - when it runs on all eight it RUNS like a striped-assed ape.
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 Toyo A/T (2nd set - got 55k from first set) on factory Alcoas, big front bumper w/4 really bright lights; F add-a-leaf, new alt x3, fuel pump, water pump, t-stat, fuel heater, vac pump x 3, PS pump x2, SD starter, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, 222k and counting...
I too have to wait for my Stage 1s....but in all fairness, if he is waiting for cores....not much he can do but wait...When he got them...they went out almost immediately. Gauges are in...but still waiting for the injectors. UPS is the problem for me...Not BEAN'S....but think of it this way...good things come to those who wait.
I cannot say enough about Bean! I was leaning over his mechanic's (Buck's) shoulder bugging him the whole time they were installing my injectors, consiquently neither of us noticed that a copper crush washer had been left in. After I got home I popped an injector O-ring.
Bean walked me through the injector removal on the phone, and then promptly sent me a refund for his labor and even tossed in 20 bucks for the new parts I needed! If I hadn't been back in MD, I'm sure he would have done the work himself free of charge.
I have never dealt with a more honest and helpful person in the performance industry, ever.
Bean was awesome to deal with. If I remember my fuel system was a little late on delivery(wanted all ss lines).But it was well worth the wait.Even contacted me after the fire to see what he could do.As far as the other guy in Tenn.(joanthan)well everyone is intitled to their opinion. [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2006 GMC DURAMAX/6 SPEED ALLISION/CREW CAB
4" TUFF COUNTRY KIT,12.50-33-18 TOYO OPEN COUNTRY ON POLISHED MHT WHEELS,MBRP DUALS,COBALT GAUGES,EDGE EVO.TUNER,AFE INTAKE & MORE.
Great group of folks to deal with, you won't have any problems with this bunch. This goes for his associates as well.
Thanks Clete
1997 F250 XLT PSD,CC,4wd,E4OD,4.10L,Hypermax 3" DP,Beans Stage I's, Tymar intake, 5" exhaust w/muffler rear exit, Intercooled, pedal mod, HPX cross over, 4 Position chip with some badazz burns, FPR shimmed, modded IDM, Isspro EV trans.temp in collum pod, and pyro guage and boost set in "A" pillar, tranny cooler ,remote trans filter, Fuel heater in the scrap iron, Precision Industries Stallion TC, Mag Hy-tech transmission pan.
Galaxy 959 peaked and tuned ,DM452 mic, Predator 10K
Well he is not waiting for cores for mine, since he has mine, the thing that is getting to me is I was told they would be done appox. the March 19. I called on the 19 was told 1 more day, not a problem sounded good, I called back on the 22 was told again 1 more day sorry,ok I understand things go wrong. But then I call on the 26 again told 1 MORE DAY, now 1 more day is getting old just want to know WHEN!!! Glad to hear your good stories hopefully mine tuns that way soon. All I want is to be told the truth if there is a problem or if they are waiting on something I think that is what they should tell me. I will keep you informed what happens.
