02-28-2007, 03:50 PM
#1 (permalink )
How big of tires can you go with a 4 inch lift?
How big a tire can you go on a 95 F-250 super cab long bed with a 4 inch lift?
1995 F-250 XLT PSD Super-cab 4x4. Edge Evolution, 3 inch down-pipe, 4 inch stainless steel Silverline exhaust, Autometer gauges, Tymar intake, 4.10 gears, 4 inch Superlift with Pro-Comp shocks and skyjacker dual steering stabilizer, 315 75 16 Nitto Terra Grapplers on '16 Eagle alloys.
02-28-2007, 03:56 PM
#2 (permalink )
Re: How big of tires can you go with a 4 inch lift?
definitely 35's, 37's possibly with a little bumper trimmin depending on what kinda wheels you got
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
02-28-2007, 04:45 PM
#3 (permalink )
Got the stock wheels. Are the 315 75 16s 35s? What is the tire size if you go 37s? Are 37s even possible with the stock rims??
02-28-2007, 05:06 PM
#4 (permalink )
I clear 35" tires with my 4" lift on my F-250. Any bigger would not clear without bumper shimming. When my tires were BRAND new they would OCCASIONALLY rub at full lock on a fast turn...after about 500 miles on them, not another rub (now have 60k miles on same tires)
1997 F-250HD SuperCab ●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
02-28-2007, 05:07 PM
#5 (permalink )
yes , 325/75R16(i think) and yes it's possible but it won't handle very well. Too much sidewall flex
02-28-2007, 05:18 PM
#6 (permalink )
welcome! good to see another phoenix powerstroke on here. yes 35s will fit a 4'' 4wd and will fit a 2wd with some cutting
My F-250 HD
1997 PSD F-250 HD 2wd ex-cab longbed prerunner. 4.10 LS rear. Edge Evolution. BDP electric fuel system. 3'' downpipe to 4'' out. 0.84 Turbo Housing. HPX mod. Gutted EBPV. Tymar intake. 3rd E4OD. B&M deep transmission pan. 4'' Fabtech lift on 35s. Bedcage toolmounts. Prerunner bumper with skidplate. SS brake lines. Flipped steering stabilizers
02-28-2007, 05:32 PM
#7 (permalink )
Hey thegreg92 where are you at? I'm in Gilbert.
02-28-2007, 05:36 PM
#8 (permalink )
I got 285 75 16s on stock right now. But I'm putting in a 4 inch superlift with Pro Comp shocks. I think the 285s are about 32-33s but I want to go a little bit bigger once I get the lift. I also have 4.10 gears.
02-28-2007, 07:45 PM
#9 (permalink )
i am in north phoenix at about i17 and 101. is your truck a 4wd? 315/75/16 would do great
My F-250 HD
02-28-2007, 08:08 PM
#10 (permalink )
You're not far from me then, I'm by 101 and 51. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Rodney #33
96 F250 XLT, RC, 4X4, 3.55's. 86 Kingpin D60, Sixpak of TW's tunes, DI Mini-Me's, H2E, Stealth Oil, BDP Fuel/twin SD pumps, ARP headstuds, DI pushrods, John Wood Trans, JoeServo IDM, 6.0 intercooler, Windstar fans, SD dual tensioner pulley, 4" TuffCountry lift, 35" BFG AT's, Centramatics, MileMarker hubs, Westach gauges, Fumoto valve, Amsoil bypass, Stancor 586-902, Aeroturbine 4040 /4" stacks, SD seats, PA 2818, 203º t'stat, vented filler necks, a/c mod, custom desert pinstripes,,,,,,,,,
2000 3500 SLT QC 24V 4x4 DRW NV5600 mostly stock
Arizona Powerstroke Group
02-28-2007, 10:15 PM
#11 (permalink )
Saw (not kidding didnt have my camera for proof) an 96' stroker 4x4 F250 the other day, had an add a leaf in the front, thats it, had 37/14.5's swampers on it. This thing was so slammed, I dont even think it could turn, rediculous. So...back to the point should be able to run some 37's with a little bumper shim.
Kevin
94.5, PSD, F-250, 4x4, Handshaker,
Couple Do-Dads
Linear Mode
» Site Navigation
» Other Sites
» Network Links
