how to get more boost out of stock turbo - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 09-20-2012, 03:35 PM Thread Starter
title says it all i have a 96 f250 7.3 i am only seeing 12-15 psi max of boost and i know that the turbo is capable of putting 20+psi i jus want to get to atleast more than 15psi is that all i should put out being stock or do i have a problem do i have a waste gate that isnt operating properly?
thanks,
cam
1996 f250 7.3l powerstroke glowshift gauges boost, egt, and trans temp. rest is stock
camd94234 is offline
post #2 of 9 (permalink) Old 09-20-2012, 03:37 PM Thread Starter
and my boost gauge is "t'ed" into my MAP sensor hose could i be getting a bad reading threw their and i have had a error code for my MAP sensor but i cleared it and it never came back so could that be a problem?
post #3 of 9 (permalink) Old 09-20-2012, 04:45 PM
bugman's Avatar
My Photos: (12)
You need a chip to push more fuel to make more boost. And with a chip you should also get a open air intake and get rid of the stock downpipe.
bugman is online now
post #4 of 9 (permalink) Old 09-20-2012, 05:49 PM
Short answer is a chip. Long answer is change to a Tymar intake, good downpipe and check for exhaust or intake leaks. If I realllllly hammer on mine I can see 17 or so lbs (maybe 18, but probably 17). I have a DIY intake and a stock DP cut off ahead of the cat. Need to have a good load behind you and run about 3,400 rpm to see anything above what you are seeing. I know there is a different exhaust housing you can put on, but I am pretty sure that moves the stock max boost down in the powerband a bit. Do a search for the 1.0 housing and you'll find some good reading.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
post #5 of 9 (permalink) Old 09-20-2012, 06:17 PM Thread Starter
yea i am only running on the stick down pipe i am running no other exhaust jus cut right off at the cat and i am soon getting a ts performance chip with custom tunes from kt performance and also a a 3inch dp to 4 in dual exhaust or a 3inch dp to 5 inch single straight pipe i am leaning towards the diamond eye 5 inch straight pipe which has the 3 inch dp and if i do a boosted launch i can see a max of 20psi and thats at 3500 rpm butt the egt wer at 1000 degrees should the new exhaust lower the exhaust gas temp?
post #6 of 9 (permalink) Old 09-22-2012, 11:45 AM
All the OBS non-intercooled PSD's do NOT have waste gates. Some people have put S-D intercoolers on but still probably don't have waste gates.
For a mostly stock truck, a single 4" exhaust is plenty. Dual 4" or a single 5" is just a waste of time, effort, & money. A single 4" should be fine to 400-450 RWHP. Stock was 3-1/2".
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
post #7 of 9 (permalink) Old 09-30-2012, 10:21 AM
fourhatz's Avatar
Make sure you do not have a leak at your up-pipes or exhaust manifolds. Should be able to get close to 20 on a stock motor.
96' F-250 4x4 SB Crewcab, 3.55 gears, rebuilt E4od, Air bags, 2" leveler kit, 10 disc cd changer, Tymar intake, Tymar 4 pos TS chip, 4590 cooler, boost, pyro(pre-turbo) & tranny temp AutoMeter gauges mounted in pillar, Diamond eye 4" exhaust with lost kitty, Tymar 3x4" downpipe, Warn hubs, Prodigy brake controller, Hypermax intercooler, CCV mod,17* HPOP, stage 1 injectors, fpr. Rebuilt tranny with pump and valve body mods, 3 disc torque convertor. Diesel mechanic 20+ years
fourhatz is offline
post #8 of 9 (permalink) Old 10-07-2012, 03:31 PM
u2slow's Avatar
My Photos: (21)
A quick-spool housing should help with boost. Like a .9 or 1.0 A/R. I almost got one before I sold my truck.
93 W250 6BTA/5spd/D60/D80/3.54/Lockright/HX35/5x.012inj/4" pipe
90 D250 6BT/5spd/D70/3.54/powr-lok
84 Ramcharger (Receiving '90 D250 cummins)
Marine Engines I mess with:
Mitsubishi S6U, S6R, 6D14; Mirrlees National KVSSM; DDC/MTU 12V2000; Cat 353, 398, 3306, 3406
u2slow is offline
post #9 of 9 (permalink) Old 10-14-2015, 12:10 PM
i have a 1997 f250 and with exhaust, intake, and 40hp single position and i can push 27lbs of boost when i get on it.
97pvilleobs is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
