Old 07-07-2006, 07:07 PM   #1 (permalink)
how to install a boost guaGE
HEY i was wondering how to install a boost guage on my 1996 f 250 i only need to know where do i hook the t fitting up to so i can run the tubing to the guage also where to wire the light for the led on the guage any help is greatly appreciated
thanks mike [img]/ubbthreads/images/graemlins/confused.gif[/img]
05 F 250 XLT extented cab PSD, guages, exterior stuff, recon stuff, SCT Xcal 3 innovative X street tune, silver line cool duals, mtx thunderform encolsure with two 10's, alpine deck.
96 F250XLT heavy duty, ext cab, PSD 5-speed, 4:10's/limited slip-so far homemade tymar intake with big filter ,diy stage 1's, ts 6 pos chip, 4 inch turbo back to 5 inch slash cut stacks, pyro and boost guage.reverse glow guages, replaced clutch with a LUK replacement,garmin street pilot, sirius sat radio, Alpine Cd player, Alpine Type R 12" sub, sony xplode amp in custom center console, diamond plate trim and side steps, Visor, bug sheild,
CapeCodF250PSD is offline
Old 07-07-2006, 07:27 PM   #2 (permalink)
Re: how to install a boost guaGE
Get a "T" fitting and splice into the MAP sensor line. It is on the passenger side of the truck and comes from the manifold and into the senor located on the fire wall. It is easy to reach and looks like a 1/4" fuel line. As for the the electrical hook up, I wired mine into the running light switch. That way you can get the dimmer like on the interior lights. It's pretty easy to do, so have fun.
'96 F250 Ext Cab XLT, 4X4, 5spd, 3" Down Pipe, 4" Exhaust, Tymar Intake, Single Mass Flywheel, Bully Dog Programmer, Boost and Pyro gauges. 81,000 miles.
bryanpickle is offline
Old 07-07-2006, 07:32 PM   #3 (permalink)
thank you greatyl is the map sensor the line the line that comes from the y pipe from the turbo output to a sensor, if you have any pics that would be awsome thanks greatly
Old 07-07-2006, 07:43 PM   #4 (permalink)
That'd be the line. My Diprocol kit from DPPI (a sponsor here) came with the fittings. I cut a slit in the rubber grommet around my steering column to run the line through. Depending on where you mount it (min'es by the ash tray) you might need more of the 1/8" nylon line available at the parts store.
Aaron SEIA
My Truck:
94.5 F350 dually crew cab psd 5 speed
0-35 lb DiProcol Boost gauge
DIY Intake
3" MBRP DP
AaronSEIA is offline
Old 07-08-2006, 12:41 AM   #5 (permalink)
kfjensen's Avatar
If you go Here, scroll down half way or so and its a "T" for $10, thats what I got, worked slick. Its the hose that comes off of the firewall towards the passenger side right next to that big plug, its like half inch hose, cant miss it, just plum in the "T" and what I did instead of the nylon hose went with 10ft or so of copper tubing the same size for Dale Isley, this way I know that it wont get pinched and just run it to your gauge, its more of a ***** winding it around to where you want things but I like it better.
In case you dont understand a word I just said (which is highly understandable) check out This site, tells you which fuses to plum into with fuse taps for either key on power for the gauges and have them come on with your regular lights. If you dont want either of these could allways put them on their own switch.
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 07-08-2006, 06:02 AM   #6 (permalink)
Here is a pic. Hope it helps.
http://community.webshots.com/photo/...75922530RkkJvk
Red 1996 F 350 XLT 4x4 Standard Cab Auto
Shimmed FPR, 10k mod ,DIY Intake, Gutted EBPV, 3 inch downpipe, Catless, Sandpiper Diesel Performance 5 inch stright cut stack with raincap, 4 position TWildman chip,DIY 160cc injectors, Diesel Dan IDM Autometer Ultra-lite Boost and Pyro gauge, SPI digital tranny gauge, Dixie Horns, Homemade Diamond Plate Mud Flaps, T.C. lockup L.E.D.
http://community.webshots.com/user/onetonstroke
Timmy1980 is offline
Old 07-08-2006, 11:33 AM   #7 (permalink)
thanks for all of the great help guys it was greatly appreciated, i just wanted to make sure i didnt cut the line lol, with this help i realized how easy it really is one more thing do you think i should junk the plastic t it came with and go to a brass one, also when driving the highest boost i see is 15 is that about right, but in 2 it goes to about 7 then next shift it quickly goes to 10 then so on....., if i build boost at the light it builds much quicker but do u think 15 is to low or what thanks again
greatly appreciated mike
Old 07-08-2006, 11:37 AM   #8 (permalink)
Thats about right for stock injectors and no chip.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 07-08-2006, 01:47 PM   #9 (permalink)
kfjensen's Avatar
Its up to you if you want to junk the nylon or not, I did just because I didnt want to worry about it.
Those numbers sound about right.
Kevin
kfjensen is offline
