I just ordered my tw chip and i am wondering how to install it before it gets here.
-kord
( totalled)white and turquise 96 with 175,000 miles. 4 in lift with 16 in welds and 35 in bfgs. 5in straight pipe exhaust, twildman 4 postion, pyro and boost gauges, diy tymar, Built Tranny. new turck white 96 130,000, 4 in lift, 35 in tires, 4 exhaust, intake, gauges, tw 4position and built tranny
On the tw, where do i route the cord for the switch?
Depends on where you want to mount the switch...I mounted mine on the dash right next to the "Diesel Idiot Light Pod" (Wait to start, fuel filter etc...)...I just drilled a hole in the middle of that plastic square and mounted the switch. Ran the wire under the dash and into the cavity behind the e-brake where the chip plugs into the PCM using zip ties to secure it.
Ok thats what i was thinking but wanted some other feed back before i did it.
-kord
