How to Lift Cheap - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 12-16-2011, 10:11 PM Thread Starter
How to Lift Cheap
I don't know a ton about these trucks so I'm trying to learn. I know however that the words lift and cheap don't usually go together.
What I have is a 1996 Ford F-250 Extended Cab long bed. 7.3L Powerstroke. 4x4. The rear end just had new hangers and shackles with a brand new 5 leaf pack which I believe is more like the f350 leaves. The front has an add a leaf so 3 up there. Non solid axle. I am running 33's.
What I am wanting to do is get about 2 more inches of lift on it. I know from reading other posts that blocks in the front seem to be a bad idea.
Any ideas on how to get about another 2 inches. And also what will not reach and need to be modified? Steering?
Thanks for all the help!
BamBam1067 is offline
post #2 of 8 (permalink) Old 12-16-2011, 11:36 PM
BadDogPSD's Avatar
There really isn't a cheap way to lift the F250 due to the front axle. About the only way is to go with lift springs & drop center pivot brackets. You may need longer shocks & brake lines too.
For the rear, if you still have the stock 2" F250 blocks, you could swap those out for 4" F350 blocks.
2013 F350 CC LB Lariat 4x4
BadDogPSD is offline
post #3 of 8 (permalink) Old 12-18-2011, 02:01 PM
mikevyota's Avatar
You can add some Add-a-leafs to the front for 2"-3" lift, but it will be a stiff ride.
30k original mile(now 79k) 97 F-250 CCSB, 7.3l PSD, S&B intake, 4" SS Diamond Eye exhaust w/o muffler, PHP tuned TS-6 chip, 7.3L Al. tank SD CAC, John Wood built E4OD, 6.0L F-550 Tranny cooler, Mag-Hytec trans pan, 4.10 gears, Dana 60 Front, 08 SD rear diff cover, 285/75R16 BFG's, stock 16" Alcoa's, AutoMeter 3 gauge pillar pod, Desert Runner Fab rear bumper with swing-out tire carrier, Line-X'd bed, dual Optima's, Valley class V hitch, Air-Ride overload bags.
mikevyota is offline
post #4 of 8 (permalink) Old 12-19-2011, 11:04 AM
Feedback Score: 3 reviews
You can't...your steering will be messed up and so would be your alinement...save your $$ towards a D60 swap.
caryt is offline
post #5 of 8 (permalink) Old 12-26-2011, 02:19 PM
kaquinn's Avatar
My Photos: (15)
I run Tuff-Country EZ-Ride 2.5" lift in all my F-250's the sit a bit higher then the stock F-350's with out getting out of hand. Ill take a TTB with this kit over a Dana 60 any day the ride is much better then the 60 and great (for a truck) IMO. And im not bias look at my sig i own many of bolth. If you wan"t 10" of lift and 40" tires then a 60 swap is in order!
OBSession
  • 03' F550 4x4 6.0 CC Lariat utility body:MBPR,BD EGR bye bye,afe stg2 dry, superchip cortex
  • 97' F-250HD 4x4 7.3 CC,SB: AFE stage II, MBRP-ss 4", BD-brake, DP-tunner chip,big oil, mostlysun coast trans, auto meter C2 gauges overhead, fuel?....
  • 97' F-250HD 4x4 7.3 EC,SB 5 speed
  • 96' F-250 Centurion 4dr bronco 4x4 7.3
  • 96' F-350 4x4 7.3 SC, LB
  • 95' F-350 4x4 7.5 460 CC,LB
  • 94' F350 4x4 7.3 N/A under cont./ referb.
  • 94' F350 4x4 7.3 turbo, dually auto
  • 86' F350 4x4 6.9 4spd dually dump
  • 85' F350 4x4 6.9 w/banks sidewinder
  • 85' F350 2wd 6.9
  • 06' Mercury Mountineer
  • 05'Explorer XLT 4.6 V8
  • 93'&(2)94'Taurus SHO 3.0 5-speed
TRUCKS ARE BEAUTIFUL!
kaquinn is offline
post #6 of 8 (permalink) Old 07-09-2012, 02:24 PM
Hey I have a 1997 Ford F250 Ext Cab 4x4 Looking to do a leveling kit or small lift any help would be great Thanks
1997 Ford F-250 4x4 7.3 200,000 miles
OfficerPSD is offline
post #7 of 8 (permalink) Old 07-10-2012, 05:03 PM
Save ur money and get rid of that crap 250 front suspension and get the d60 up there it will make life ALOT easier
Aw9414 is offline
post #8 of 8 (permalink) Old 07-10-2012, 05:45 PM
Kaquinn...ya really need to drive a OBS with a D60/RS SD spring swap...we can get our trucks with a D60 to ride even better than a SD..been doing it for over 12 years.
caryt is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
