How many amps does the starter draw? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 09-15-2008, 10:54 AM Thread Starter
I want to put a disconnect switch in the hot wire from the battery to the starter (actually the solenoid mounted on the starter) I once had a starter hang...the solenoid stuck in the on position and I had to scramble to get the batts unhooked before the starter caught fire. It was close...still smoking after 5 minutes. Anyway, ever since then I have wanted to put a disconnect switch on it, for emergencies, anti-theft, etc. I just need to know the amp draw before I buy one.
Thanks,
Jerry
Black 2010 Ford F250 XLT Crewcab Longbed 4x4 6.8L V10. Special Ordered. 295/70r18 Nitto Terra Grapplers on black powdercoated stock wheels, Harley Davidson Edition headlights. FX4 Grille. Recon smoked cab lights and mirror lenses. Factory bumpers and nerf bars have been powdercoated black.Husky Mudflaps,custom black 4" exhaust, AirAid intake, X3 tuner from 5 Star Tuning, AutoVentShade door sill protectors. Soon will black out the badges.
Jerry Miller is offline
post #2 of 8 (permalink) Old 09-15-2008, 11:41 AM
From Alldata:
Current Draw Under Normal Load 230-630 Amps
Max. Load 2400 Amps
No Load 170 Amps Max.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
RD97 is offline
post #3 of 8 (permalink) Old 09-15-2008, 12:07 PM Thread Starter
Thank you very much. I had no idea it would be in the 600's. The highest I can find is a 500amp switch. Looks like I better keep looking.
Jerry
post #4 of 8 (permalink) Old 09-15-2008, 08:01 PM
BKB
450-475 amps is what i used to measure
05 f350 CC LB King Ranch. 6.0 with torqushift 3.73 gears, SCT. 60k miles
BKB is offline
post #5 of 8 (permalink) Old 09-15-2008, 08:30 PM Thread Starter
Thanks for the info. When you measured this, what was the conditions? Cold/Warm engine, outside air temp, weight of oil in crankcase?
Thanks,
Jerry
post #6 of 8 (permalink) Old 09-16-2008, 03:03 PM
ammayernick's Avatar
Jerry,
You will be fine using the 500 amp variety. It is plenty large enough. Disconnect switches are rated in the amount of current they can switch under load. When you use this switch it will normally not have a load on it.
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps *
ammayernick is offline
post #7 of 8 (permalink) Old 09-16-2008, 03:27 PM
BKB
Thanks,
Jerry
I serviced a fleet of school busses for 3 years. That is the current draw a saw summer/winter, warm oil, cold oil, ford starters, reman starters. If we started to see something around 600 we would replace them. This was using a AutoMeter roll around tester with clamp on current probe.
BKB is offline
post #8 of 8 (permalink) Old 09-16-2008, 08:24 PM Thread Starter
Thanks guys. I'll pick up the 500 amp unit.
Jerry
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
