Old 04-22-2005, 06:25 AM   #1 (permalink)
DZLJIM's Avatar
How much fuel does the Areomotive pumps really move?
Book says the A-1000 moves 500 lbs per hour.
The A-2000 moves 350 gallons per hour.
Why would it be rated in lbs/hr? How does this convert to Gallons?
Thanks.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB
DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
DZLJIM is offline
Old 04-22-2005, 08:38 AM   #2 (permalink)
Re: How much fuel does the Areomotive pumps really move?
This is a swag Jim, but roughly 66 pounds.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 04-22-2005, 11:08 AM   #3 (permalink)
Banned
If im not mistaken a gallon of diesel weighs 9 or 10 pounds
Luke
lukecline is offline
Old 04-22-2005, 11:25 AM   #4 (permalink)
The A-1000 will feed 400cc B-Code injectors with a 1 psi pressure drop at WFO. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Jonathan
The Swamp Donkey: 1995 F-250 4x4 with 2.5 ton military drivetrain, 49" 14.00x20 Michelins, dual 5-speed trannys feeding NP-205 X-case and 1410/1580 U-joints. Engine & trannys are out getting rebuild #2...hmm...I wonder what I can do to it now?
Swamp's Diesel Performance
<font color="red">Competition Parts for Power Strokes--Injectors, Chips, Clutches, Engines, Tuning. </font>
swamp@swampsdiesel.com
1-615-793-5573 9am-8pm CST
Power Stroke Roadside Help Network
Swamp Donkey is offline
Old 04-22-2005, 11:28 AM   #5 (permalink)
Water is 8lbs per gallon. Diesel is lighter than water. I thought 7~7.3lbs per gallon was usually used per gallon.
This means that 500 lbs/hour = 71.4gal/hr = 1.19gal/min.
Hey, if I saw it on the web, it must be true!!! [img]/ubbthreads/images/graemlins/crazy.gif[/img] [img]/ubbthreads/images/graemlins/crazy.gif[/img]
1997 F350 Powerstroke Crew-Cab XLT 4X4 5spd 145,000 miles. Tymar Intake, ceramic coated Hypermax downpipe, full 4"exhaust with 36" muffler, Calf. fuel Reg kit, HPX crossover kit. Bushwacker extend-a-fender flares, grill and bezels painted to match truck, 305-70-16 Goodyear Wranger MTR's. For Now!
GO BUCKEYES!!!!!!!!!
Rex_Reimer is offline
Old 04-22-2005, 11:31 AM   #6 (permalink)
Jim
The specific gravity of diesel is about 0.78 - 0.79.
Standard water is 1.0
That means a gallon of diesel weighs in the neighborhood of 6.5 lbs.
The lbs per hour stuff is a mass flow for the convenienece of people
wanting to know that without density corrections so to speak.
At standard conditions, and hip-pocket calculations, mass and gallons are convertable.
OB
rlm5 is offline
Old 04-22-2005, 02:12 PM   #7 (permalink)
DZLJIM's Avatar
Thanks all.
And thanks Jonathan. You directly answered my dilema. [img]/ubbthreads/images/graemlins/smile.gif[/img]
DZLJIM is offline
Old 04-22-2005, 03:15 PM   #8 (permalink)
My Photos: (13)
hey Jim, thats pretty convinent huh [img]/ubbthreads/images/graemlins/wink.gif[/img]
Tim
'97 F350 crew cab 4x4 lwb xlt 5 speed 225hp
'95 F250 reg cab 2wd xl auto 215hp
75f100 is offline
Old 04-22-2005, 11:22 PM   #9 (permalink)
Powerstroke2000's Avatar
My Photos: (17)
Have had an A1000 Aeromotive sitting on my workbench now for a year, so it looks like it should handle my injectors just fine then!
Need a turbo first though!
Thanks Jon..
Dale
IDM mod
TYMAR intake
Amsoil dual by-pass
Precision Ind triple disk Torque Convertor & Pro build tranny
Transgo Tugger shift kit
Ford AIC & full gauges
Mini-Me/SWAMP 250cc Hybrid 530 injectors
17° HPOP
5" custom exhaust
Superduty Intercooler & GTS pipe kit
CCV mod
TS 4 position Flip Chip
<span style="color: blue"> My truck </span> & <span style="color: blue"> Dual Idler Tensioner mod </span> , <span style="color: blue"> Superduty HPOP & Mini-Me ~ Swamp Injectors </span>
Powerstroke2000 is offline
Old 04-23-2005, 12:02 AM   #10 (permalink)
johndeerebones's Avatar
Sweet, If I hit the lottery I'm getting some 530's and this pump
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 04-23-2005, 12:33 PM   #11 (permalink)
DIESELSITE's Avatar
Keep in mind, the A-1000 is not warranted for use in diesel fuels.
Bob
Bob Riley, Owner DieselSite.com & BlueOvalSite.com
CPR Fuel Systems, Wicked Wheel, The PULSE
Proud Sponsor of TheDieselStop.com
GOT DIESEL? call us at 888-414-3457
DIESELSITE is online now
Old 04-23-2005, 03:29 PM   #12 (permalink)
I've had mine in for 3 years, 60,000 miles, and from -10 to 110 temp.
I've never had any problems and if they can fuel 400cc's I should be just fine. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Early '99 F-350 Reg Cab - puller
1997 F-350 Reg Cab - pulls the puller
2001 E-350 PSD Quigley 4x4 - finances the puller
P714 is offline
