Old 07-01-2005, 03:26 PM   #1 (permalink)
My Photos: (22)
how much HP from intercooler install
Im talking about if you put one on with no other mods
my friend that realy dose not know about our trucks is trying to tell me we will get 100HP off an intercoler install
Steve [img]/ubbthreads/images/graemlins/smokin.gif[/img]
<font color="black"> Theres No replacementfor displacement</font>
<font color="purple">THIS IS THE TRUCK I HAD
Almost stock 96 F-250 CC XL short box 4X4 BFG AT 265-75-16
Cruse Control Mod
gutted EBPV
big open eliment air filter</font>
<font color="brown">3:55 gears open diff.
firestone ride rite air bags(on the front for sag lift)
warn manual locking hubs
how many times I have had my truck stuck:2
E4OD
240,555.9 km
my pic's[img]/ubbthreads/images/graemlins/smokin.gif[/img] </font>or dead truck pic's[img]/ubbthreads/images/graemlins/smokin.gif[/img]</font>
westroke is offline
Old 07-01-2005, 03:37 PM   #2 (permalink)
My Photos: (6)
Re: how much HP from intercooler install
Huh???
far as I know, you will get a MARGINAL (&lt;&lt;maybe&gt;&gt; 20hp) increase in power, but maybe 200 degree reduction in EGT temps. That would be good for the towing crowd and engine longevity.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 07-01-2005, 03:43 PM   #3 (permalink)
My Photos: (21)
No you will not gain any HP with an I/C. You will loose a pound or two of boost (less power) but you will be able to keep it at WOT longer before you get to the 1250-1350 degree range. You shouldn't even need one on a stock truck.
JIM
His: 1997 F350 PSD, CC, 4X4, 4.10's, 35/12.5/16.5's BFG's
Hers: 1997 F250 PSD, X-Cab, 4x4, 4.10's, 315's
All My Photos
Toys/Blown Head Gasket
Drag Videos
motor/turbo/fuelsystem pics
Traction Bars
Father & Son Time
THE_ALASKAN is offline
Old 07-01-2005, 03:48 PM   #4 (permalink)
TravisT's Avatar
If it was that easy we'd all have one wouldn't we? [img]/ubbthreads/images/graemlins/grin.gif[/img]
So, at 70-75mph I am at about 800* (right at the exhaust port). If I accelerate it can jump to 1200 super easy and fast. What changes could I see if I put in one of those super duty intercoolers? Would it just stay cooler at 70-75mph, or will it actually keep it from rising so high and quick? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F-250HD 5-SPEED 4X, New 4.10s (PRECISION GEAR), Truetrac (DETROIT LOCKER), Hubs (WARN), 4" lift (SKYJACKER), 35x12.50 (PRO-COMP), Classic Lock (M/T), 100 Gallon Nomad (greasel.com), Dominator 66 Turbo, Stage 1 Injectors, 6 Position (BDP), Clutch (LuK), 6.0 Intercooler (4WP Dumpster), DP & Guages (SCHEID DIESEL), 4" exhaust - properly loud (BD-POWER), 203' Tstat (dieselsite.com), Prerunner bar (N-FAB), Yellow tops (OPTIMA), Diamond Clear headlights with H.I.D. conversion, 205000 (s)miles 2005 Emblems
TravisT is offline
Old 07-01-2005, 03:55 PM   #5 (permalink)
My Photos: (21)
Both, It will run cooler (EGT's that is not motor temp) at Hwy speeds and it will slow down the temp increase you have now. Maybe someone can give you a more intelligent explanation instead of the 3rd grade answer I gave ya [img]/ubbthreads/images/graemlins/wink.gif[/img].
JIM
All My Photos
Drag Videos
Traction Bars
Father & Son Time
Old 07-01-2005, 04:46 PM   #6 (permalink)
My Photos: (5)
tell him to quit sniffin' gasoline fumes cuz' he's high.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 07-01-2005, 05:03 PM   #7 (permalink)
Steve, you will indeed gain very little power from an intercooler-only mod. This small power gain will be because of a cooler intake air charge. Keep this in mind also-you will be adding quite a bit of volume to your intake air charge, which will slow down your turbo response time (read as increased lag), possibly making the seat-of-the-pants o'meter think you actually have less power than before. On the good side, an intercooler will open the door for more mods!
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 07-01-2005, 05:13 PM   #8 (permalink)
Powerstroke2000's Avatar
My Photos: (17)
Can't add much more than what has been said here, but I gained NO power with my intercooler install. As mentioned above, it does allow for lowering EGT's for other modifications though!
I found that my EGT's don't climb as high or as quickly when towing in mountain passes, albeit, with aftermarket injectors, you certainly CAN surpass what is "safe" if you don't watch your pyrometer!
I try to stay at about 1300 EGT or less while towing, but have surpassed it on many occassions, as there is just so much more pedal left with my injectors!
With the auto tranny, staying in 3rd gear (button pushed in) you can travel most hills easily at a higher speed with an intercooler, and run by your pyrometer...staying at whatever your "personal safe EGT is" and maintain it if you have the fuel. With stock injectors, I found the pedal to be on the floor, with little gain in speed while towing some of the 10%+ hills we have here in the west, whereas now I doubt I'm much past half throttle, going much faster than what full throttle was in the old days. I'm sure many of you with aftermarket injectors/intercooler find similar results.
Dale
IDM mod
TYMAR intake
Amsoil dual by-pass
Precision Ind triple disk Torque Convertor & Pro build tranny
Transgo Tugger shift kit
Ford AIC & full gauges
Mini-Me/SWAMP 250cc Hybrid 530 injectors
17° HPOP
5" custom exhaust
Superduty Intercooler & GTS pipe kit
CCV mod
TS 4 position Flip Chip
<span style="color: blue"> My truck </span> & <span style="color: blue"> Dual Idler Tensioner mod </span> , <span style="color: blue"> Superduty HPOP & Mini-Me ~ Swamp Injectors </span>
Powerstroke2000 is offline
Old 07-01-2005, 05:14 PM   #9 (permalink)
This is all true.
I picked up 50# torque and about 15 rwhp going to a bigger CAC. We actually changed the CAC while the truck was parked on the dyno overnight and ran the truck the very next day. I guess my truck needed the cooler air really badly. I could feel no hp difference but the difference in egts was pronounced.
I see stupid people. They're everywhere. They walk around like everyone else. They don't even know that they're stupid. AND THEY POST ON THIS SITE!
Early '99 7.3 Superduty. Built 3-98
Chassis: Supercab SB, Lifted w/ 20's.
Tranny: Suncoast parts built by the local guy.
Engine mods: Diesel Innovations all the way (tuning, injectors, & turbo), Homemade "Big Oil", GT42R Big frame turbo. Rods and junk to keep it all together.
http://community.webshots.com/myphot...ecurity=MuSLdj
Suns_PSD is offline
Old 07-01-2005, 05:26 PM   #10 (permalink)
TravisT's Avatar
I wonder if that was because your stocker 99.5 was restrictive in some way and the new one opened it up.
TravisT is offline
Old 07-01-2005, 05:57 PM   #11 (permalink)
Banned
If you are looking for power an IC isn't where you are going to find it. With a stock truck you won't see any gains. You will see lower EGTs. They won't be much cooler at cruising speeds because you aren't makeing much boost so you aren't building a lot of heat in the intake. Where you will really see it is at higher boost levels. The more boost you make the hotter the air is and the more drop you will see in your EGTs vs. with no IC. On a highly modified truck such as Sun's where it is really hot and smokey you will see slight gains as he mentioned. The diesel world is completely different than the gas world where you will see more gains because the PCM will be adding more fuel to make the proper air/fuel ratio on a gas engine or the engine would burn up. On a diesel the PCM is adding all the fuel it is going to at a given boost level. So any extra or cooler air you are getting to the engine isn't going to do anything for you unless it is very hot and smokey to begin with.
gtspowerstroke is offline
Old 07-01-2005, 06:44 PM   #12 (permalink)
I dynoed my truck back to back with the cooler and without all in a 15 min time frame, I gained 30 hp. The cooler the intake temp the more power your going to make.
Later,
AlanB
97 PSD f250 4x4. 06 common rail conversion in the process.
<span style="color: red">cummins conversions by Rockin S performance </span>
AlanB is offline
Old 07-01-2005, 08:58 PM   #13 (permalink)
Tom S's Avatar
My Photos: (20)
My EGTs at 70mph level road, 75degrees are right at 500 degrees depending on the slight variation in the true grade of the road.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 07-03-2005, 03:05 AM   #14 (permalink)
Banned
Later,
With what all mods done to at the time?
AlanB
Old 07-19-2005, 12:38 AM   #15 (permalink)
My Photos: (22)
well it has been a wile since I could get back to check this post
thanks for the info now when my friend trys to tell me more of his crap i can shut him up
note this is not going in my truck
Cruse Control Mod
gutted EBPV
E4OD
240,555.9 km
westroke is offline
» Site Navigation
