Old 02-15-2006, 12:34 PM   #1 (permalink)
Covah's Avatar
HPOP/CEL ?
If my hpop is weak on the top end would i get a cel? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
95 crew cab,5spd,4x4,edge evo,3"downtube,no cat,4"exh,k&n,autometer pyro&boost,stancor,10k,smfw,240k
Covah is offline
Old 02-15-2006, 01:12 PM   #2 (permalink)
My Photos: (6)
Re: HPOP/CEL ?
That is one of the reasons for a CEL, but if you are running stock injectors, I would think there is a better chance you have an injector or two that is using too much oil..
On edit, I see you have a 10K mod. If you have that removed, do you still set a CEL? I used to be fine with the stock stuff, but the moment I ran the 10K -or- chip in anything other than stock setting, I would set a CEL pretty much at will. Even worse with the new injectors.
.02
Chris
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 02-15-2006, 01:31 PM   #3 (permalink)
PSDfreak's Avatar
Re: HPOP/CEL ?
With my chip I can throw a CEL when really gettin on...without, no.
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 02-15-2006, 05:12 PM   #4 (permalink)
GSXRTURBOQUAD's Avatar
Re: HPOP/CEL ?
Well, looks like you have a CA 97. If so, you have splits. You need at the least an SD pump(17*). Why not just go all the way to Big Oil! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 02-15-2006, 05:23 PM   #5 (permalink)
PSDfreak's Avatar
Re: HPOP/CEL ?
Mine is not a california truck...it has single shot squirters.
-Casey
PSDfreak is offline
Old 02-15-2006, 09:30 PM   #6 (permalink)
Covah's Avatar
Re: HPOP/CEL ?
That is the reason for the question 10k switched on I get no cel but around 2500 rpm it quits making more power,just flattens out switched off it will pull to redline. It is the same on all settings of the edge programmer.I believe the 10k mod is working due to rougher idle and a slight power increase. It wont set a cel i've kept my foot in it for a while. So my question is if it was a weak hpop not able to hold enough psi would it set a cel? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Covah is offline
Old 02-15-2006, 11:13 PM   #7 (permalink)
johndeerebones's Avatar
Re: HPOP/CEL ?
Mine does this too, with stock injectors and a stock hpop I think it is probably about impossible to use more oil than the hpop can supply. Our injectors just aren't big enough.
I think what is more likely is with the icp already sensing that the ipr needs to kick it up a notch on wot I think the 10k changes the numbers and the pcm just doesn't know what to do with it.
The 10k tells the pcm it needs more hpop oil and so does the icp at wot I think they just add up to numbers certain pcm codes don't like.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 02-16-2006, 12:31 AM   #8 (permalink)
Re: HPOP/CEL ?
Sorry to hear it's not a CA model, thats too bad [img]/ubbthreads/images/graemlins/frown.gif[/img].
You need to throw a gauge on it or scan tool and read your pressure at WOT. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SDRCM #7
Old 02-16-2006, 01:23 AM   #9 (permalink)
My Photos: (6)
Re: HPOP/CEL ?
Same exact symptoms as mine. Swap in a new '02 HPOP (and incidentally new injectors at the same time) and presto.. no CEL.
I really feel that my injectors were fine, just a bit tired, and that my problem was my HPOP.
sorry for no firm facts, but just my .02
radarman is offline
Old 02-16-2006, 01:07 PM   #10 (permalink)
Covah's Avatar
Re: HPOP/CEL ?
[/ QUOTE ]Thats what I was thinking. Does anyone in the seattle area have a way to test psi at WOT? I would appreciate the help. : [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Covah is offline
Old 02-16-2006, 01:10 PM   #11 (permalink)
PSDfreak's Avatar
Re: HPOP/CEL ?
I'm not sorry...replaced the fuel pump a few months back without having to take the turbo off! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
-Casey
PSDfreak is offline
Old 02-17-2006, 01:22 AM   #12 (permalink)
Re: HPOP/CEL ?
Ya, but the CA 97's run so much stronger then the federals do. [img]/ubbthreads/images/graemlins/wink.gif[/img]
SDRCM #7
