Old 01-08-2007, 04:24 PM   #1 (permalink)
HPOP drainback question
When you bolt on a 17*pump to a factory 95 powerstroke motor everyone says the resevoir will bleed off.My question is what is different from the stock 15* pump and the superduty 17* pump that creates this bleed off issue?
outlaws51 is offline
Old 01-08-2007, 08:02 PM   #2 (permalink)
Nit
Re: HPOP drainback question
there's a anti drain valve in teh pump, teh diff is the cover, rather thanthe valve in teh pump they re-configuired the cover so it can not drain off. There is a cheap fix that you have to drill some holes adn add a line
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 01-08-2007, 08:33 PM   #3 (permalink)
Can this drain valve be installed in any way possible in the 17* pump?
Old 01-08-2007, 09:04 PM   #4 (permalink)
Nit
no it;s completely internal
pictures
dirty30
Nit is offline
Old 01-08-2007, 09:56 PM   #5 (permalink)
TheRubberDuck's Avatar
Nit, where can I read about the fix. I got a friend with a 95 that needs some help.
TheRubberDuck
1995 F350 Crew Cab 4x4 dually
Stage 2 DIY inj
RSB 140v IDM
Tymar Intake
DP Tuner 2 pos. chip w/custom switch
FPR Shim 70psi
3"dp to 4" straight piped to 5" Stacks
Hot Pedal
I miss you No.3
RIP #17
TheRubberDuck is offline
Old 01-08-2007, 11:34 PM   #6 (permalink)
http://www.superdutydiesel.com/forum...ead.php?t=4833
there is no line added in this fix [img]/ubbthreads/images/graemlins/shrug.gif[/img]
i have a truck that will suck my eyeballs into the back of my head at will
bigbadf350psd is offline
Old 01-09-2007, 03:27 AM   #7 (permalink)
GSXRTURBOQUAD's Avatar
[/ QUOTE ]Actually, there is another way. I can pull the internals out of an SD pump, and install them into a 94-95 body. Problem solved. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 01-09-2007, 12:17 PM   #8 (permalink)
Are there any special tools or parts required to pull the guts out of the 17* pump and putting them in the 15* housing?
Old 01-09-2007, 03:31 PM   #9 (permalink)
My Photos: (6)
I have a fix that is based on the one from 94f450sd. He and I worked on a How-to and I posted it. You can just follow the link in my sig. Several people have done this with no problems at all. difficulty level is from 1 being tightening a screw and 10 being rebuilding the engine, I would rate it between a 3 and 4.
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 01-09-2007, 05:25 PM   #10 (permalink)
[/ QUOTE ]Yes. It's not simple unless you have the proper tools and knowledge. TE can do it. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SDRCM #7
Old 01-09-2007, 06:30 PM   #11 (permalink)
Nit
Radar your the one I was trying to remember I thought there was a line invlived but I guess not, way cheaper option than my accumulator and relay setup
pictures
dirty30
Nit is offline
