Old 09-11-2007, 06:13 PM   #1 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
HPOP Gauge in an OBS
Heck yeah!! Here is mine installed on the steering column! Got it from <span style="color: #FF0000">2</span><span style="color: #999999">L</span> Motorsports
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 09-11-2007, 07:04 PM   #2 (permalink)
Re: HPOP Gauge in an OBS
You gotta link to them. I like that!! What was the price for it?
1997 F-250 CC 4x4. DIY Hybrid 530's, HPX, 5" stack, 7.3 intercooler, tymar intake, headstuds, 17* HPOP, H2E Turbo, TS 6 position chip. 4" lift 35's on 18's. Dana 60 4.11 LS. built E40D tranny. DI Fass fuel system. Motor rebuilt 02/07
http://community.webshots.com/user/Phatbulldog
phatbulldog is offline
Old 09-11-2007, 08:09 PM   #3 (permalink)
Looks good. ditto on the linky and price
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 09-11-2007, 08:37 PM   #4 (permalink)
OK so DiProcol is out with it now, COOL! How does the gauge seem to react? Is it hooked up to an extra ICP sensor or to the existing one? How does it react? Smooth tracking?
And MOST IMPORTANT who made the gauge pod?
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 09-11-2007, 08:51 PM   #5 (permalink)
DZLJIM's Avatar
http://www.itpdiesel.com/store.php?c...on=show_detail
Taps into existing ICP wires.
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB
DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
DZLJIM is offline
Old 09-11-2007, 09:32 PM   #6 (permalink)
Yes, where did the gauge pod come from!!!!
Todd
AKA Toad
1995 Ford F250 7.3L, auto stock 390,000mi, filler neck Mod, 3" DP with test pipe (no cat!), Fumoto oil drain valve, BDP Stage I Injectors, Tymar Intake, DB Electrical High Torque Starter
1965 Ford Mustang Fastback 289 4bbl 75,000mi
1988 Honda CRX Si 1.6L stock
1988 Honda CRX 1.5L stock
1990 Honda CRX 1.5L stock
1991 Honda CRX 1.5L stock
1998 Kawasaki Vulcan 1500 Classic
1981 Honda GL500
1995 F350 7.3L Parts Truck
stang65fst is offline
Old 09-11-2007, 11:50 PM   #7 (permalink)
2L' site isn't up and functioning yet, but you can call Travis Direct at (859) 991-8337 and tell him Michael told you about it
It does just tap into the ICP senor wire, which I don't really like, but did anyway. I may get another sensor and harness for it and get 5v ref and ground on the harness and then make it like it would be factory.
It acts great, smooth movement and seems to not be very 'laggy' at all. It does go up to about 1500psi when I start the truck, which makes me wonder why that is, since it should only take 500psi to start the engine.
It was neat to see what happend when I forgot to turn my fuel pump on after finishing the install. I sat and let it run for a min. like I always do and put it in gear and started to back up, by the time I was outta the driveway it was running kinda rough and lopey. I looked at the gauge and it was up at 1500psi idling and I did a quick through of what was going on, like the gauge was reading wrong or messing with the ICP signal to the computer and it was raising the ICP in turn.
Turns out I turned the fuel pump on and it went back to normal, which I though was neat the PCM was raising ICP to compensate, but was still bad.
The Gauge pod is Autometer from eGauges.com
-Michael
Michael Paul
My Webshots
Old 09-12-2007, 07:44 AM   #8 (permalink)
DZLJIM's Avatar
It'll jump to a higher pressure on start-up till the IPR reacts and starts to work.
Mine usually jumps to 3000psi with twin pumps on a cold start...
DZLJIM is offline
Old 09-12-2007, 01:54 PM   #9 (permalink)
Michael,
I went and looked on the e gauges site and they only list a column pod for 97 up F150's and Superduties. Which one did you get?
Old 09-12-2007, 11:56 PM   #10 (permalink)
My Photos: (14)
it is a superduty pod they are the same column cover I believe diselfecer said it required very minor triming around the back of the turn signal to lever to allow it to function properly in high beam mode, but this even has to be done on some superduties
Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt)
My Webshots
Moremph is offline
Old 09-13-2007, 01:04 AM   #11 (permalink)
Exactally!! I didn't trim mine very well, but its no big deal to me.
Its kinda cool to look at how the PW and IPR DC act when you have really big injectors and medium oil when you got to WOT and back out of it. The needle does a pendulum between 1700psi and 2200 psi. It looks sweet in the dark too
-Michael
Michael Paul
My Webshots
Old 09-13-2007, 09:47 AM   #12 (permalink)
Do they make the gauge in a white face or just black?
95 F350 cc, 4x4, 5sp with a short shift kit, 3.55LS, D66 turbo, Beans stage 1's inj, modded ped, IDM mod ,hx mod, DPR intercooler, 3" intakes 3" dp, 4" side out, 2piller w/boost&pyro, steering column mount w/hpop gauge, TW chip, AFE stage 1, ccv mod, DIY oil & coolant filter setups, John Deere coolant eye, ORU RSK, Black Centerline wildcats w/Hankook RT03 315-75-16 mt, One day hope to have a RockDog front bumper w/8" Hellas and a CT performance rear bumper/tire carrier, 05 SD front and rear seats.
Trying to find time to install Con O clutch, 17* HPOP Swamps fuel sys, Ford rear diff cover, Blackbird rear disc brake setup.
I have two Kids and they come first...
http://community.webshots.com/user/TECH5150
TECH51 is offline
Old 09-13-2007, 02:08 PM   #13 (permalink)
Just black face to match the ford dash cluster, thats why I put it on the steering column.
Their white face gauges are made to match the Dodge dash clusters
-Michael
Michael Paul
My Webshots
« leak | dt 530 »
