HPOP question - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-05-2009, 02:41 PM   #1 (permalink)
Question HPOP question
Does anyone know for certain whether or not I can use a late '99 HPOP with a '94.5 if the appropriate IPR is installed?
Tim the 2Lman, '85 F350 2WD CC C6 basically stock 274K miles, '86 F350 reg cab flat-bed DRW 4-speed, '94 F350 powerstroke ZF-5 SRW long bed project soon to be daily driver, 217K miles.
Tim the 2Lman is offline
Old 11-05-2009, 05:13 PM   #2 (permalink)
blageurt's Avatar
I'm not 100 % on this but, I beleive you will need to mount a 97 style HPOP resevoir , as well as upgrading the IPR . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 11-05-2009, 06:04 PM   #3 (permalink)
You won't have the anti-drainback feature, so you may have extended cranking intervals waiting for oil pressure to build up.
Get the Adrenaline pump from Dieselsite instead, its better than the '99 AND you can get it made with the anti-drainback feature.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
Old 11-05-2009, 07:58 PM   #4 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
The early pumps had the anti-drainback valves in the pump. The later ones have it in the front cover. It will work (old cover, late pump), but will drain back causing longer cranking to start. You change to a later front cover (motor has to be pulled) or there is a mod to the older front covers that can be done (I'll have to look for a link), or some have added an accumulator to the system (PM members Nit or Powerstroke2000 unless they chime in on this one). I'm with Bill (get an Adrenaline). Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 11-06-2009, 08:44 AM   #5 (permalink)
Patrick, are you actually refering to the engine front cover as having the anti-drainback or the HPOP resevoir housing?
Old 11-06-2009, 12:43 PM   #6 (permalink)
I believe he is saying that in the early model powerstrokes, the anti-drainback valve was in the hpop itself, whereas in the later model, as a '99 would be, the drainback valve was in the front cover. I would also recommend installing an Adrenaline HPOP as was previously stated. Check out dieselsite.com, they sell the Adrenaline pump and they can answer any questions you have regarding hpops.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 11-06-2009, 12:59 PM   #7 (permalink)
Exactly what sdan said.
coming soon: 6.0 IC
Old 11-06-2009, 05:09 PM   #8 (permalink)
Let me ask again. Are you talking about the engine front cover or the HPOP resevoir/ gear housing? They are not the same thing. I would expect the resevoir to have the anti-drain back valve on the later models.
Old 11-06-2009, 06:00 PM   #9 (permalink)
The anti-drainback is in the front cover itself, not the reservoir. Lifted from a writeup by Chris Nigh (on converting the 94 cover to the later anti-drainback):
Step 5 is to create the new standpipe hole in the timing cover.
To create the new hole in the timing cover to the new reservoir standpipe, I VERY CAREFULLY centered the F6TZ-6619-AA gasket on the timing cover. Center punch the timing cover where the additional hole is using the F6TZ-6619-AA gasket as a template.
At this point you will be making lots of metal shavings so be very careful and prep the area with lots of rags and such protecting any possible path into the engine. I used several layers so that I could remove them one at a time and vacuum very thoroughly between each layer I removed. I also used plenty of brake cleaner to wash the metal particles onto the rags before I removed them.
Drill a 3/16" hole down through the timing cover to the small upper drivers side cavity. Don’t have to be terribly careful other than making sure the hole is perpendicular to the timing cover. I have a buddy stand at the side of the truck and watch the front and back tilt, and I watched the left to right tilt and drilled away. Once that is done, you will need to make the special gasket relief tool, or in other words the 11/16" spade bit with the end tips ground down so that it will create a flat gasket relief in the timing cover. Here is my special tool:
Nigh.org Photo and Video Gallery
With the special new drill bit, create the gasket relief the same way you drilled the hole. Be careful not to drill too deep. Go in steps to make sure that you get the depth right. I used the old gasket as a depth gauge. Here is what I ended up with:
Step 6 is to plug the existing hole in the timing cover.
Last part of the mod is to plug the hole in the front of the small cavity. I used a self tapping screw from the REAR of the timing cover coated with lots of RTV. Once it is in place, trim the excess screw that is protruding into the gear area.
coming soon: 6.0 IC
Old 11-06-2009, 08:47 PM   #10 (permalink)
That helps nashvillebill, Thanks. I see I will need a later model reservoir and gasket, but procedurally it looks quits simple. Hopefully I can secure one of these later pumps and reservoir and get it set up. I'll let you know. Unfortunately, the Adrenaline HPOP is not in the budget.
Old 11-06-2009, 11:24 PM   #11 (permalink)
My Photos: (19)
Sort of. The antidrainback was moved from the pump into the front cover in mid-96 (I think). Anti-drainback was in the pump up to engine serial number 201680. Cheers!
Old 11-07-2009, 11:21 AM   #12 (permalink)
Thanks guys. This has been a huge help for me. We'll see which pump I end up with and how it turns out. When I hear her fire up for the first time I'll be stoked! I've had the truck a month and heard nada. Thanks again!
