Old 12-09-2006, 05:48 PM   #1 (permalink)
tjbeggs's Avatar
HPOP rear cover removal
I have a late 99 core engine laying in the shop with a good HPOP on it but its not a humped cover so I would like to remove it to check for bearing or bushings. Got the snap ring of but can't seem to get the cover off. Its not magnetic enough, and I can't get a pick behind it to pry out.
Those of you who have reomved them how did you do it?
Tim
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 12-09-2006, 05:49 PM   #2 (permalink)
PSDfreak's Avatar
Re: HPOP rear cover removal
Wrapped my hand in duct tape (sticky side out obviously) and just stuck it to the little round cover and it came right out stuck to my fingers [img]/ubbthreads/images/graemlins/wink.gif[/img]
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 12-09-2006, 05:56 PM   #3 (permalink)
ThreeStarJR's Avatar
-Casey
Pretty inventive there Casey!! Another way is to put air pressure thru the feed line openings and that will bring it out of the casing....
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Wildman Tunes
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
play it loud!
#3
ThreeStarJR is offline
Old 12-09-2006, 06:17 PM   #4 (permalink)
PSDfreak's Avatar
-Casey
Thanks Jim...I was going to use the air technique but wasnt near a compressor so I have to improvise...
Its comes out real easy with a little help from air or tape or whatever else you can think of...there is a little but of greasy stuff under that cover which is what is keeping it from just falling off...plus it can be "stuck" under the lip where the snap ring seats a little bit.
-Casey
PSDfreak is offline
Old 12-09-2006, 06:57 PM   #5 (permalink)
tjbeggs's Avatar
So duct tape or air into the oil feed hole. thanks guys I will give that a try.
What seals that back cover?
Truck Pics
tjbeggs is offline
Old 12-09-2006, 07:04 PM   #6 (permalink)
Tom S's Avatar
My Photos: (20)
There is a o-ring type of seal.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 12-11-2006, 11:54 PM   #7 (permalink)
I felt pretty stupid about all the time I spent fooling around getting the cover off until I used the duct tape trick! I recently sent JOAT the oring # for the rear HPOP cover to add to the list. It also fits the turbo to Y pipe.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 12-12-2006, 12:35 AM   #8 (permalink)
PSDfreak's Avatar
I am getting kind of worried about the o-ring...I took the cover off of my SD pump more than once and I don't specifically recall an o-ring...maybe it was there and i just missed it??? I have a small leak coming down the back of the motor from what I am guessing it either the Rear Mail or one of the rail plugs...Guess I should get in the valley and make sure its not leaking at the HPOP [img]/ubbthreads/images/graemlins/crazy.gif[/img]
-Casey
PSDfreak is offline
Old 12-14-2006, 10:29 AM   #9 (permalink)
tjbeggs's Avatar
duct tape worked and now I have a free 17 degree pump! We had a core engine sitting in the shop that we paided the core charge for after reomving it from a customers truck. it was a late 99 with 95k on the clock but due to a k+n it was dusted. flat rear cover but it does have the bushing rather than the bearing so I am in luck!
Truck Pics
tjbeggs is offline
Old 12-15-2006, 12:29 AM   #10 (permalink)
I'm usually good at oil leak locating, but I blew this one so I thought I'd share.....I had oil in the valley and drips hanging on the bottom of the HPOP and in the rear cover smap ring groove. This popped up after the first time I towed up a 10 mile grade. (read as sustained higher than usual ICP) I went throught the whole process of reseaching and replacing the HPOP rear cover oring to find out I missed the leak at the #8 o-ring boss plug on the top of the HPOP. Of course there was never a drop there anytime I looked. The moral of the story? The rear cover doesn't have any pressure on it so is very unlikely to leak. Look there last.
Old 12-15-2006, 01:38 AM   #11 (permalink)
PSDfreak's Avatar
Thank you for sharing...that REALLY helps....I am in the middle of tracking down a fuel/oil leak and was worried it might be the back cover of the HPOP...I'll tear into a little tomorrow and see what I find...
Thanks again,
Casey
PSDfreak is offline
Old 12-15-2006, 02:19 AM   #12 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
What exactally is it?? Mine has a leak at the back cover of the HPOP also.
-Michael
Dieselfever78 is offline
