just dont look at your electric meter when that is on-----!!!!!!!!!!!!!!
Bumper to bumper, Full Synthetic!!! Rotella T 5-40 -- Mobil 1 Mercon V -- Amsoil Extreme 75-90 -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 15 Passenger Van with E40D and Dana 60. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
Is there something wrong with your stock block heater?
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
No, it works perfect but in the "cold country" like -20 to -50 below it is way insufficient.
It only heats the one bank pretty good and the other OK, in normal conditions. In this cold weather it is not nearly enough.
My entire engine and engine compartment will be warm at -50 below.
The oil pump to the injectors is very important to get plenty of heat too as are both heads and the oil.
I'm putting synthetic 5 -40 oil in the motor and synthetic transmission fluid in the automatic transmission and synthetic rear end grease in the differential and then and putting a magnet heater on both the tranny and motor oil pans.
I'm trying to keep this thing alive while it sits outside in the cold.
I will also idle a lot with the RPM's raised several hundred RPM's with a prop between the gas peddle and seat to do this.
-20 to -50? I knew i lived in the south for a reason...i think that's it...
Randy
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 100gal aux fuel tank. A real pig from a stop, but give me 10' and she'll lite'em up.
150K miles, 12 injectors, EGR cooler, Fuel pump, 8glow plugs, GPCM, FICM rebuilt FoMoCo longblock under 7/200 warranty.
A 2000V heater is something to brag about alright. Where did you find a 2000V outlet to power it?
Watts I guess that is, sorry about that.
I'll know more in the morning but I think this is going to heat everything "except" the radiator. I was told to make sure to unplug it before I start it for that very reason.
That is a little secret everybody should know about there 7.3 block heater. Unplug it before you start the motor or the cold water hitting the element will eventually or even quickly ruin it.
I'm very concerned about the ice cold water hitting my engine and ruining it. A very real concern. -- Once and you got nothing.
Survival is this cold country is at play here.
I know that i am comparing apples to oranges here, but bare with me. Think of NASCAR for a second. When the cars are lined up in their starting position on pit road, just prior to the green rag, the teams circulate the oil through portable heaters and back into the engine. For different reasons of course. Key word..circulate. Maybe that method would apply in your case. Just a thought.
Have you thought of using your stock block heater in conjuction with your aftermarket heater?
Randy
Several years ago I worked for powerline construction equipment company. We had a tech that stayed on site for a large customer somewhere north where temps stay below 0. He had a setup on his service truck with heater hoses running to the service bed with heater cores he put in the tool compartments. He had block heaters and maybe hose? heaters hooked with some kind of low volumn pump that kept the coolant circulated through the whole heater system and service bed. Made his tools somewhat easier to handle (if only temporary till they were outside a few minutes) but also made his service manuals easier to handle. I never got to see it, he always flew home for short periods w/o the truck. But it sounded like the cat's meow. We were in Louisiana, so we've never seen cold like that.
1990 F350 2wd DRW Super Cab E4OD 7.3l IDI
Gooseneck hitch, Flowmaster (single inlet/dual out), 60 gal tank/toolbox/bedrails/headache rack (custom built, welded together as 1 unit)
