Re: i-beam pivot bushings
I used an air hammer to drive em out, a long bolt, heavy washers, a nut, and an impact to drive em in.
By far the worst part is trying to line em back up to put the bolts in. You'll need a couple floor jacks and an assortment of pry bars to get em lined up. I even had to drop the leaf spring on one side....
While you have access make sure the bolts are tight on the pivot brackets, mine were a little loose, Ford even had a tsb about em loosening up..
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB  DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
