Old 12-09-2006, 07:41 PM   #1 (permalink)
I dynoed today
There was a dyno diesel hangout deal in the area I lived in today and I jumped on since the stage 1s are in the mail to get a baseline on the truck, basically my high numbers were 221 hp and 415 ft/lb. I was expecting to be a little higher [img]/ubbthreads/images/graemlins/shrug.gif[/img] but it was my first time on a dyno so I think I was backing off to soon but it was fun and a good learning experience and I got to hang with a fellow member, I think we were the only two fords, but I got there kind of late. So with stock injectors do the numbers make sense? Or was I backing out to soon?
Dan
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 12-09-2006, 07:43 PM   #2 (permalink)
Re: I dynoed today
Oh yeah I got pics Ill try to get to em over the weekend.
Big_Dan97's Photos
Old 12-09-2006, 07:54 PM   #3 (permalink)
Re: I dynoed today
Totally stock is usually around 165ish. So for just a chip, intake, and exhaust I think you're doing pretty good.
'97 F350 PSD E4OD CC 4x4
265/75/16, BB shim=73psi, Open Element, 10K with switch on dash, IDM mod, 30K Hayden tranny cooler, 3" downpipe, 4" straight pipe, the usual gauges, Bullydog 6 position chip. Biodiesel as much as possible.
Tankota is offline
Old 12-09-2006, 08:43 PM   #4 (permalink)
KRP
Re: I dynoed today
Jeez, those numbers sound a little low. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Just messing with you Dan, glad you made it out today. Like you said it gives you a baseline to compare to later and it's a good time. You missed the other two Fords that ran, the one right before me did 337 I think and the guy with $7000 worth of Bank's equipment that did 286. [img]/ubbthreads/images/graemlins/eek.gif[/img]
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
KRP is offline
Old 12-09-2006, 09:02 PM   #5 (permalink)
Banned
Re: I dynoed today
those are good numbers for stock injectors,good job [img]/ubbthreads/images/graemlins/smokin.gif[/img]
tubzz is offline
Old 12-09-2006, 10:13 PM   #6 (permalink)
Re: I dynoed today
LOL I bet that Banks Guy was not happy with 286hp [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
00 CC, LB, DRW, Black F350 4x4, 6 speed, lunar series Boost and EGT. DP tuner 6pos chip SBC clutch,fuel system. GTP 38R BB, by Diesel Inovations. Weld Typhoones rims, Tymar filter,CCV mod and TERMINATOR OIL.
97 CC, SB Green F250 4x4 5 speed, SBC clutch, F5 DP chip, Isspro boost, EGT.Stage II sticks, Tymar, CCV mod, TERMINATOR OIL, Banks pipe kit IC, fuel system, GTP 38R BB Turbo, Weld Typhoones
07 Dodge CTD, QCSB, Dark Gray 4x4, 6 speed, Tinted windows and a B&W hitch, MBRP 4in, AFE Stage 2 Progaurd 7, Centerline Wilderness Grizzly, Smarty CR, Quadzilla Commander, Fass 150, sbc , head studs so far a MPI twin turbo ,DDP 90hp tips also. It still smokes a little
deerezilla9620 is offline
Old 12-09-2006, 11:42 PM   #7 (permalink)
Re: I dynoed today
sounds about right. Mine did 225/450 with a superchips tuner.
Curt
1997 F350 cc/lb, 4x4, E4OD, 4.10, Pyro/Trans Temp/Boost Gauges. Torn apart- installing h2e, sd intercooler, bronco tank, bosch 044 fuel pump, dahl 150, regulated return, big oil, b codes.
CEMeyer is offline
Old 12-10-2006, 12:19 AM   #8 (permalink)
AlaskaRedneK's Avatar
Re: I dynoed today
About how much does it cost to dyno?
-Stouff
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, ~111K miles/ 3-4" Down Pipe hooked to 5" Turnout Stacks, Isspro EV Guages, Tymar, 6 pos. Northern Diesel Performance TS Chip, 7.3 IC, gutted stock fan- w/ single electric fan, Stage 3 DIY Hybrids
In the garage: RacerX Tranny kit, headstuds, 910s, pushrods
Next: New TW tunes!
AlaskaRedneK is offline
Old 12-10-2006, 12:39 AM   #9 (permalink)
KRP
Re: I dynoed today
The event we had here today was $50(was supposed to be $45 but the new owner changed it). That was supposed to be for 3 runs, but they weren't strict about that. The other local shop I know that has a dyno charges $100 an hour for dyno time. It's going to vary depending on the shop and what they have going on I'm sure.
KRP is offline
Old 12-10-2006, 01:12 AM   #10 (permalink)
Re: I dynoed today
Thats not bad at all.
Now, we just need one of these "events" up my way [img]/ubbthreads/images/graemlins/grin.gif[/img]
-Stouff
Next: New TW tunes!
Old 12-10-2006, 02:17 AM   #11 (permalink)
Re: I dynoed today
We had one a few years ago in Anc. Nobody was very happy with the results. I had a modded IDM and a several different chips back then. No injectors. TYMAR and straight exhaust. I could only get about 175hp. Jim only was around 240. Should have been at least 350. Turned out the dyno had real light rollers for ricers and we couldnt get the boost to build before we ran out of rpm's. Jim needs to get a good Dyno up here for us Northern Boys to run on. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Doug <font color="red">34</font>
96 F-250 xlt auto 4x4, 4.10's, ext cab, Red & White two-tone, Dana 60 front end with a Sky Man. Reverse Shackle Kit, Firestone airbag overloads, 35" tires. TYMAR intake, fillernecks, and hx hose, running Roan Switches, custom 4-position chip from Northern Diesel Performance, JS idm, Hypermax dp, 4" exhaust before tire, DIY exhaust brake, homemade AIC, 10k, shimmed reg, sonnex valve and tricumulater springs, Isspro EV gauges on pillar, Lund visor, mudflaps, and steps for the wife.
Oh yeah!! I almost forgot Swamped!!!!
Babies through Northern Diesel Performance.
http://ctperformanceinc.com
<font color="red">Call Dale Isley at(509)922-truk{8785}</font> or info@tymarperformance.com
DozerDoug is offline
Old 12-10-2006, 06:29 AM   #12 (permalink)
Re: I dynoed today
Stock OBS trucks usually are around 175 hp and SDs about 225 hp. The weight of the rollers make a big difference on a DynoJet. Dyno'ed the truck on a 3000# roller dynojet and barely made 330 hp in direct and much less in OD (282 hp). Running 120mph on a dyno is a little strange. [img]/ubbthreads/images/graemlins/eek.gif[/img] A 5000# roller Dynojet gave me 399.8 hp readings. Mustang dyno readings have been from 342 to 365 hp. These are corrected numbers with a CFs of 0.92-0.96. Out here the numbers shrink when corrected. These are from 4 Mustangs and 2 Dynojets. As a comparision, the truck did 14.5 1/4s@7500# with the same powertrain setup. This was with a stock muffler and stock turbo (1.0 housing) and an old 2003 dieselpower chip. The addition of Bean's single SD fuel system increased the horsepower to 408 with a broader torque curve. Current setup is a little different but have not had an opportunity to dyno or race the truck.
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
Old 12-10-2006, 02:59 PM   #13 (permalink)
Re: I dynoed today
As Im typing this 10/13 photos are uploaded on webshots under album dyno. I have to go to a friends to scan the dyno sheet. My scanner and I arent getting along (computers [img]/ubbthreads/images/graemlins/shrug.gif[/img]). Like KRP said it was $50 and I did like 8 runs since it was my first time they worked with me to get some good numbers. Before I start getting a bunch of crap about stickers [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] let me say this, the banks one is from the original owner who had a banks dp I sold it and the module for almost half of what my exhaust cost that I bought, but I keep it on cause it makes me look like I have lots of money [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. The bullydog ones are cause I bought my gauges from em.
Now we need a drag strip here so I can blow black smoke all over superdutys with my stage 1s, maybe even KRPs superduty [img]/ubbthreads/images/graemlins/biggrin.gif[/img]!
It was fun, and my 4yo daughter loved it, I thought shed get scared cause your going real fast in front of a brick wall but she loves blowing smoke too! cant wait to do it again after the stage ones. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
KRP good seein ya again.
Big_Dan97's Photos
Old 12-10-2006, 03:24 PM   #14 (permalink)
kfjensen's Avatar
Re: I dynoed today
Sounds like you had a good time, I need to get on one, prolly this next summer , never seem to have a chance [img]/ubbthreads/images/graemlins/mad.gif[/img]
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 12-10-2006, 03:25 PM   #15 (permalink)
Re: I dynoed today
the last dyno run that I made was with the 95 in my sig. on 09-12-06 on a mustang dyno. temp. 95 +/- Made this run with dp tuner 80 hp econo. tune - stock inj. made 264.2 hp / 559.1 tq
-95 F350,PSD,CC,All White,E4OD,- 250 RWHP 560 TQ
-Stage 2 AFE Magnum Force Intake - Custom Flip Chip - Isspro 60 lb. Boost,Scaled Pyro & Tranny Temp in pillar pod - <font color="red">Turbonetics Ball Buster Windmill</font>[img]/ubbthreads/images/graemlins/cool.gif[/img] - Homemade Downpipe - Homemade Reg. Return Fuel System - HPX mod - CCV Mod - Homemade 4" Exaust - 3" Intake Plenums - TransGo HD2 Shift Kit - Soon To Come; Custom I/C - BDP Stage II's - Bigger Oil - Still Looking For that 400+ RWHP!!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
-97 F350,PSD,CC,ZF5SPD. - 3" DP. - LuK Single Mass Flywheel & Clutch. - Isspro 60 lb. Boost & Scaled Pyro in pillar pod.- 100 a/r Non EBPV Turbo - Edge Evolution Race Tuned - 260,xxx Miles And Counting [img]/ubbthreads/images/graemlins/smile.gif[/img]
God,Guns,And Guts Made America. Lets Keep all 3
Gun Control = Using Both Hands!!! &gt;&lt;&gt; &lt;&gt;&lt;
CUR3406B is offline
