I have an interesting Problem - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 07-16-2009, 08:51 AM   #1 (permalink)
tgorsuch's Avatar
I have a 4 position TW chip, in the third position (heavy pull) only the engine completely dies when I let up on the pedal. It throws a code that indicates problem with the CPS. It only does this in position 3. I changed CPS sensors thought I had it fixed but the problem is back.
Any ideas?
1997 PSD 4x4 F250 Crew Cab, Red, Auto, DP, NAPA 6637 Air Cleaner, Autometer Gauges on Pillar, 3.73 gears, 240,000 miles, 16 to 19 MPG, 10 MPG towing 30' fifth wheel and 20' Bass Boat, TW 4 position chip, Fuel Heater Mod.
Full force Stage I's. Modified turbo ped, Gutted EBPV, 6.0 IC, 6.0 trans cooler, CCV Mod., BTS Trans. 07 front & rear axle w/coil springs, Blistein shocks, Fox Steering stablizer, Front 4 link, superduty grab handles.
http://terryssite.typepad.com
tgorsuch is offline
Old 07-16-2009, 02:04 PM   #2 (permalink)
Feedback Score: 3 reviews
Call Tony..
Cary
caryt is offline
Old 08-23-2009, 12:36 PM   #3 (permalink)
tgorsuch's Avatar
Sent my chip to TW but he couldn't find anything wrong so he sent me a new chip with some different burns. All seems to be working good.
Tony sure takes care of his customers. Would recommend him to anyone.
tgorsuch is offline
Old 08-23-2009, 03:38 PM   #4 (permalink)
tgorsuch, we have similar trucks, what egt's do you see empty/towing on hills.
1997 F250 7.3 LB SC,auto,3.55 LS,82,000 miles,deep trans pan, 03 SD trans cooler,3" DP,no kitty,Tymar intake,Optix gauges(pyro,trans temp,boost,coolant temp), SD intercooler W/Banks pipes, TW custom tunes
70jeeper is offline
Old 08-27-2009, 02:31 PM   #5 (permalink)
tgorsuch's Avatar
Empty, I don't know it doesn't get very high even in the hills.
pulling my 5'er and bass boat I still have to watch it close it will get to 12 on steep hills.
tgorsuch is offline
Old 08-31-2009, 12:00 AM   #6 (permalink)
Thanks tgorsuch, thought I would check, mine never sees under a 1000 when towing, makes pulling hills tough.
Mike
70jeeper is offline
