Old 12-26-2005, 01:35 AM   #1 (permalink)
I need opinions on torque wrenches
Which one is a good one ( almost bulletproof) one for our trucks. and i.e. foot to lbs . Thinking of doing injectors in the near future. thanks in advance. Karl [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1996 F-350 psd crew duellie,declawed, demuffed,fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />thanks Matt!! more mods to come.
fordmedic is offline
Old 12-26-2005, 04:22 AM   #2 (permalink)
My Photos: (19)
Re: I need opinions on torque wrenches
I exclusivly use snap-on. Look to spen $200 plus depending upon mechanical/electric.
2000 F-250 Reg Cab 4x4 6 Spd - Somewhat stock...
MachinistOne is offline
Old 12-26-2005, 09:59 AM   #3 (permalink)
johndeerebones's Avatar
I use Snap-On also, but I make a living with my tools. My local NAPA stocks S and K. They are good tools that cost alot less.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 12-26-2005, 10:28 AM   #4 (permalink)
Banned
i have a craftsmans TQ wrench that has been a good one.
injectors are TQ in INCH lb's.i got that at the auto parts store
tubzz is offline
Old 12-26-2005, 11:05 AM   #5 (permalink)
ThreeStarJR's Avatar
Karl, I'm with Tubzz on the craftsman, for my needs, truck only, the ft/lbs wrench works good. I did get the s/k from napa for the inch/lb when I did my injectors. Nice piece.....make sure you get one that has good range of settings, saw quite a few that the lowest settings started out @ the same torque value as some of the requirements of the bolts you need to torque in your injector change. I've always been anal about working @ a lower setting and working my way up to the specified torque value [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Wildman Tunes
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
play it loud!
#3
ThreeStarJR is offline
Old 12-26-2005, 11:29 AM   #6 (permalink)
have used the craftsman in foot pounds for years now and it has always been reliable. have a mac inch pound wrench with a wide range of settings 30-250 inch pounds. very nice tool. was a b-day present which made it even nicer. [img]/ubbthreads/images/graemlins/cool.gif[/img]
G3 be safe and stay warm
'96 F-250, ext. cab, 2 wheel drive, long bed, stock as they come. works hard every day on the job hauling pipe and tools and then on the farm at night and weekends. the best never rest!
GEODON is offline
Old 12-26-2005, 01:15 PM   #7 (permalink)
Banned
This is somewhere you really don't want to skimp. Especially if you plan on doing some very critical torqueing such as head bolts/studs. For the injectors it's not quite as critical but you still want a good wrench. I have two Snap on ft/lb wrenches and one craftsman In/lbs wrench. It is a good idea to send them in and have them recalibrated ever so often. I have a friend with a Dodge running twin turbos that kept poping head gaskets and come to find out his torque wrench was reading 20 or so ft/lbs low. He used another wrench from someone he worked with and hasn't had a problem since.
gtspowerstroke is offline
Old 12-26-2005, 01:27 PM   #8 (permalink)
My Photos: (19)
Not to pick on you GTS, but your sig has "bigger" missing a "g"
SK tools are good quality for the money.
Old 12-26-2005, 01:58 PM   #9 (permalink)
cruise ebay--you can get snap-on tq wrenches on there reasonable--the micro type--after use--unscrew till bottom on lowest setting--spring doesnt compress that way--had mine for 30 yrs--took to work--was 1/2 lb off!!!!!the ones that have the lever you lift to change the settings--can leave where its at--and wont change--but personally---- i wont scrimp on tq wrneches as its the most important thing putting a engine together---
94_turbo is offline
Old 12-26-2005, 03:12 PM   #10 (permalink)
My Photos: (22)
A good rule of thumb, DON'T buy Chinese and/or Taiwanese made junk such as those Harbor Freight ones. Buy decent quality Made In USA TQ wrenchs and have them calibrated periodically.
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
Old 12-26-2005, 04:24 PM   #11 (permalink)
Banned
[img]/ubbthreads/images/graemlins/blush.gif[/img] oops! [img]/ubbthreads/images/graemlins/blush.gif[/img] I hate when I type in a hurry and don't go back to check it! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 12-26-2005, 06:15 PM   #12 (permalink)
You can also send old torque wrenches off, and get the calibration checked, and adjusted.
Just Google "Torque Wrench Calibration", and you'll come up with a dozen places or more that do this.
I would make sure the torque wrench is one of decent quality, and shape before I sent it for calibration. Don't waste your money on a junker! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1997 F250HD Regular Cab 4x4, 4.10 SRW, Handshaker ZF5 Tranny, Bean Stage I's, TWildman 4 Pos Chip, 3" Downpipe/4" Exhaust, Tymar Intake, Luk Single Mass Flywheel/Clutch, IDM Mod, Ford AIC, Stancor GPR, HX Mod, Gutted EBPV, Dead Kitty, Coolant Filter, 203* Stat, Twin Electric Fans, A/C Mod, GPR Bypass System, 1.0 A/R Turbo Exhaust Housing
There's no Substitute for Cubic Inches!!!
F250Jockey is offline
Old 12-26-2005, 06:29 PM   #13 (permalink)
kfjensen's Avatar
I went with a Husky brand torque wrench that maxes at 180ft lbs I believe. Had it for 2 years and flawless, didnt want to go the way of Snapon seeing as I dont use it enough to get my money out of it.
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 12-26-2005, 11:27 PM   #14 (permalink)
I bought my share of snap-on tools, still have two torque wrenches among other things. Only problem is since I "retired" the snap-on (or mac)man doesn't come by the house. The craftsman man is always easy to find, though [img]/ubbthreads/images/graemlins/grin.gif[/img]
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 12-27-2005, 12:34 AM   #15 (permalink)
I have craftsman clickers in inch and ft lbs 3/8 and 1/2 drive. Snap on in 3/4 drive. The bigger stuff is out of craftsman league, but love the easy warranty on hand tools.
The Racer X Built E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Diesel and nitrous!
Family owned & sponsored by : FloridaNorth
For Fuel - D.J. @ DIY-injectors.com
"AMERICAN INGENUITY " Half of AMERICAN is I CAN."
Racer_X is offline
