I used Prestone Anitfreeze good for everything it says??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-10-2009, 08:06 PM   #1 (permalink)
midwestconnection's Avatar
I hope it is OK, I also added the Ford 16 ounce bottle of conditioner.
I put Full Synthetic Rotella T 5-40 in the engine with a Motorcraft filter.
The rear end I'm afraid to put the synthetic 75-140 in it so I'm taking it back and putting in Synthetic 75-90 instead. It gets really cold here, like -40 and I'm afraid the 75-140 would get to thick, even though it's synthetic. My Dana 60 floater doesn't even recommend synthetic if I'm not mistaken.
My E40D transmission is getting Mercon V, I think that it is synthetic, I'm not sure I still have to buy it.
I put in my $500 Kim Hotstart 2000 Watt tank heater today that I got for $158 off from eBay. It cost me an additional $60 for hoses and adapters.
I'm concerned about the cold radiator water gushing into a hot engine, does anybody know anything about any of these things.
I'm supposed to be a master but I'm gambling on a lot of this stuff.
Trying to keep my van alive.
Bumper to bumper, Full Synthetic!!! Rotella T 5-40(7.3L) -- Mobil 1 Mercon V(E40D) -- Amsoil Extreme 75-90(Danas 60) -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 XLT Club Wagon 15 Passenger Van. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
Old 11-10-2009, 09:18 PM   #2 (permalink)
pjwoolw's Avatar
My Photos: (5)
If you flushed the cooling system and put in new coolant about one and a half pints of the SCA additive would be needed. You'll test strips to check for the correct amount. As long as the coolant is a low silicate formula you should be good. There is much debate on that subject.
That oil is really gonna loosen up the gunk in the engine. Change it again after 500 miles or so. It may use oil faster too and possibly leak more so keep an eye on it. Thats a ton of miles on one engine.
What is the tank heater for and where did you install it? I'm curious.
From what I understand that unit has a thermostat in it so it only gets so hot regardless.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
Old 11-10-2009, 09:52 PM   #3 (permalink)
Is the Ford additive the SCA that I need, if so the three 16 oz bottles at $10 each, I can get two more and add them Thanks. Where do I get those test strips.
This motor is so clean inside and out you would swear it only had 80,000 miles on it. I know I gambled big time going synthetic. I put it in everything I own two years ago, everything had 150,000 and more. It improved every thing. Winter starts are critical here.
I put the heater in the pocket nearest the gas tank.
Old 11-10-2009, 10:00 PM   #4 (permalink)
pjwoolw's Avatar
My Photos: (5)
Napa normally carries the test strips. Or any Cummins of IH shop. They do expire so check the dates on the package.
Pete in San Ramon
pjwoolw is offline
Old 11-10-2009, 11:24 PM   #5 (permalink)
FYI...courtesy of Steve Baz:
Coolants
Extended Life Coolants
Cooling system maintenance
The cooling system on any diesel has special concerns. It's possible for the coolant to cavitate --produce tiny bubbles--that can with time cause pinholes through the cylinder walls from the water jackets. For this there is an additive; Ford P/N FW-15 or FW-16, Fleetguard P/N DCA4; that needs to be maintained in the coolant. Generally this means installing 8 to 10 oz of the additive to the cooling system every 15000 miles. Another method is to monitor the cooling system with Fleetguard's DCA4 test kit P/N CC2602 or CC2602A. This measures the level of DCA4 in the system, and then you add the amount as required. The cooling system should be drained (and flushed if you live in an area with especially alkaline water) and refilled with a fresh 50/50 mix of coolant/water and one pint of the additive for every two gallons of coolant/water at 30,000 miles. Use only a low-silicate ethylene glycol-based coolant. Ford does not recommend using propylene glycol coolants in any of their vehicles. · Ford or Motorcraft Premium Antifreeze · Motorcraft Premium Gold Antifreeze (does not require SCA/DCA)
· Texaco Antifreeze/Coolant
· Texaco Antifreeze/Coolant Pre-diluted 50/50
· Zerex 5/100 (white bottle) Antifreeze/Coolant
· Zerex Ready To Use Antifreeze/Coolant (premixed 50/50 with de-mineralized water)
· Zerex Heavy Duty Pre-charged Formula
· Shellzone Premium Quality Antifreeze
· Fleetguard Complete EG--pre-charged at 1.5 units/gallon DCA4
Also available premixed 50/50 with water with the same DCA4 level · Pyroil Heavy-Duty Antifreeze/Coolant--Low Silicate
· Fleet Charge Antifreeze/Coolant--pre-charged with Pencool
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 11-11-2009, 04:24 AM   #6 (permalink)
Coolants
My Prestone Extended Life Antifreeze/Coolant Official NHRA Antifreeze Up to 150,000 mile/5year protection bottle says ethylene glycol, diethylene glycol, sodium 2-ethyl hexanoate, sodium neodecanoate. Maximum 70% Prestone 30% Water = -84F It says ALL MAKES, ALL MODELS of cars and light trucks add to any color antifreeze.
I wish I had seen this before I did it. Live and learn. I got 3 1/2 gallons in and one 16 oz bottle of the Ford additive in there now. It's looking like I will have to drain it.
It doesn't say propylene glycol unless it's the same thing with another name.
But I should have waited.
Old 11-11-2009, 04:30 AM   #7 (permalink)
OK, thanks, I'll get some today.
Old 11-11-2009, 05:53 AM   #8 (permalink)
Why do you have to drain the Prestone? I use it without problems.
MichaelPatrick is offline
Old 11-11-2009, 07:35 AM   #9 (permalink)
See the above.
Old 11-11-2009, 07:44 AM   #10 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
Seeing the above makes no difference. You are using the correct type coolant and you added the correct additive. There is no difference between the coolant that you bought and the ones listed above. I have news for you. The dealer buys their fluids in bulk from the cheapest place they can get it from. I have personally been in the shop when the truck has come to refill the supply tanks. I personally know the three local diesel techs at the dealerships(two of them) and all they do is add the additive to the coolant.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 11-11-2009, 08:58 AM   #11 (permalink)
Just one little note. The Fleetguard ES Compleat is charged with 2.5 units of
SCA per gallon.
TNTech is offline
Old 11-11-2009, 02:36 PM   #12 (permalink)
No he is not running the correct fluid. You will get cavitation if you do not use the proper antifreeze.
#2. Hence why we don't take our obs trucks to the stealership!
Also, did you drain the block plugs? if not your missing a bunch of coolant.
2003 F350 crew cab 4x4 Bone Stock.
RIP, For now. Left in a field in Wyoming.
96 7.3 f250 4x4 ext cab , longbed,3" downpipe to a test pipe, Gutted ebpv, tw 4chip, stage 1 injectors,Stealth oil pump,Electric fans. shimmed fpr . 19 mpg in economy mode 8mpg in extreme mode. 281,117 miles as of 11-30-11.
ryhed is offline
Old 11-11-2009, 04:16 PM   #13 (permalink)
The Ford spec is ESE-M97B44-A. Prestone meets the spec. It is silicate free according to prestone.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
Old 11-11-2009, 07:56 PM   #14 (permalink)
My bottle says "Meets or Exceeds" ASTM D3306 and ASTM D4985, whatever that is. Yes it is Silicate, phosphate,borate and nitrate free. I drained at the drain plugs and the radiator.
Old 11-12-2009, 11:33 AM   #15 (permalink)
BigDieselBoy's Avatar
Very good post, the first thing I'm doing today is going to ford and getting some fluid and additive.
BigDieselBoy is offline
