Old 12-03-2005, 09:10 PM   #1 (permalink)
I want LESS smoke.
So I just put in some BDP Stage 1s today and the truck hauls balls but smokes like a freight train. I knew this was going to happen, but unlike some others, I don't want to piss off everyone driving behind me.
Does an intercooler help or do I just need a better turbo?
What turbo do I need?
BDP has some turbos in the what's next, but nothing for sale yet.
Thanks Bean!!!
Michael
1996 F-350 4x4, Reg. Cab, 7.3L PowerStroke, 4.10s, Luk SMFW, BDP 4" Exhaust, Tymar Intake + HX Kit, BDP 6 Position Chip, BDP Stage 1s, BDP Modified IDM, Homemade AIC, Oilguard Bypass Filter, Mobil Delvac 1, Homemade Coolant Filter Setup. 223,000 miles.
1993 Mazda 4x4 on Toyota Axles and 36s, Pictures
1991 Chevy Beretta GTZ - Daily Driver ~29 mpg
TexasAggie is offline
Old 12-03-2005, 09:18 PM   #2 (permalink)
My Photos: (39)
Re: I want LESS smoke.
You'll need a turbo....besides though it don't smoke long.....LOL
Paul/TP
Houston Area Powerstrokes
I have a VERY bad case of DIESEL-I-TITS!!!! [img]/ubbthreads/images/graemlins/crazy.gif[/img]
<font color="blue">My 1995 250 S/C LWB PSD <font color="red">4x4</font></font>, SWAMPS Babies[img]/ubbthreads/images/graemlins/smokin.gif[/img], 6pos. Flip Chip by twildman, Isspro gauges, Hypermax DP & twin 5" stacks, TYMAR intake & HX hose, On Board Air, 4" Superlift [img]/ubbthreads/images/graemlins/smile.gif[/img], 35" A/T's, 5spd. w/Luk, 4:10's, Window guards,Carr steps [img]/ubbthreads/images/graemlins/smile.gif[/img], Pioneer Cd player, APC clear corners cab lights & side markers and headlights,Ranch Hand Grill Guard & rear bumper, AC mod
<font color="red">Tri-Community Volunteer Fireman </font>
BigStroker is offline
Old 12-03-2005, 09:27 PM   #3 (permalink)
Posts: n/a
Post deleted by JLester
Old 12-03-2005, 09:42 PM   #4 (permalink)
pwrtrip's Avatar
diesels aresupposed to smoke.get an economy setting for your chip.my stage 2s only smoke in the luke cline extreme.they will smoke if i want them to in the tame extreme and barely smoke in the economy setting
YUP that is what I say. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Jeremiah
1996 crew cab 4x4 black psd
BDP 250cc hyrbids
BDP fuel system
Stealthhinator dual ipr hpop
H2E
TDP tuning
515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
Truck and misc pics
pwrtrip is offline
Old 12-03-2005, 09:50 PM   #5 (permalink)
Well, I have a 6 position chip with stock/economy/tow and 3 extreme burns. It smokes BAD in all but TOW and STOCK. If economy is the one with higher injection pressure (Like Bean told me) then it smokes more than TOW.
Some notes on the install:
I had already purchased 8 Motorcraft glow plugs, the two little rubber hoses that go from the Y pipe to the intake manifold and the gasket for the turbo. After pulling the valve covers I noticed that two of the wiring harnesses were burned so my dad went to get two valve cover gaskets and four new harnesses from Ford. I also wanted a new turbo inlet boot which happens to be a kit so $430.52 later I had:
Stage 1s
Eight new glow plugs
New turbo inlet kit
New valve cover gaskets
New under valve cover harnesses
New turbo gasket
New Y pipe boots
I'm just waiting on the 4" exhaust and the gauges now.
I traded Bean some cores for some stuff and his customer service blows away any other companies I have dealt with for my truck.
How often should air filters be changed? I have 34k on mine! [img]/ubbthreads/images/graemlins/eek.gif[/img]
Thanks Bean.
Michael
Old 12-03-2005, 10:13 PM   #6 (permalink)
jna
congrats on the mods!!
less smoke? use biodiesel [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
1996 F-250 POWERSTROKE , Crew Cab Short Bed, 4x4
Custom Air Ride
BDP Dominator 66
Stetcher Stealth Pump
Total Diesel Chip
150cc Swamp Babies
BDP fuel system
many[color:"blue"] TYMAR mods [/color]
TRUCK
BTS
Dana 60
2008 F-450 4x4
jna is offline
Old 12-03-2005, 10:17 PM   #7 (permalink)
power+no smoke...sorry bud, you need a gasser. with a diesel, that's just the nature of the beast...
Josh
1996 Ford F350 XL SuperCab shortbed 4x4, PSD, 5-speed manual, D60 swap, 6" Skyjacker (all spring) lift, 37" Super Swamper SSRs, 16x10 Ultra Stargazer wheels, South Bend Con-O-FE clutch (HIGHLY RECOMMENDED!!), SMFW, Tymar air intake, Swamps 150/146s, shimmed FPR, Northern Diesel Performance 4-position chip, 3.5" Hypermax downpipe, 4" Airflow exhaust, Dieselsite's BRV, Husky lo-profile toolbox, Reunel front "Import Mauler/Chevy repair kit-gotta do my part to clean-up America" DYNO'D 1 October-308.8 RWHP, 620.1 RWTQ!!...see her here www.cardomain.com/id/rattlinford
RattlinFord is offline
Old 12-03-2005, 10:34 PM   #8 (permalink)
Tons of smoke means you need more air. Your turbo cant keep up. You need to either tone down the fuel with tuning or get a turbo that will support your air needs.
MY TRUCKS
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
&lt;&gt;&lt;
2002 Excursion PSD 4x4 XLT Premium- TN BB 1.0 Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner PCM QLJ5/PMT1 combo, Edge Juice/Attitude for gauges.
SOUTHERN CALIFORNIA POWERSTROKES MEMBER
mattymx is offline
Old 12-03-2005, 10:43 PM   #9 (permalink)
you have stage ones and no guages. wow, scary
anyways, a IC will make it smoke worse, as it builds boost slower.....
lots of junk
97 f350, 7.3L, 2wd, auto, exhuast, intake, injectors, chip, IC, big gooseneck.
93 f350. 7.3L idi turbo, 2wd, 5 speed, dually.
Pics
BurnedBronco is offline
Old 12-03-2005, 10:47 PM   #10 (permalink)
I'll have the gauges soon and I won't be towing or running hard until then...
Michael
Old 12-03-2005, 11:17 PM   #11 (permalink)
Hey Mike, looks like you got them in ok.
Perforance injetcors with a chip will always smoke off the start, higher the program with more tip in fuel will smoke more. Once you get the ex in (gut the EBPV also) it will clean up onc ethe turbo is spooled. If you lay into it with no boost it will always smoke, just build about 5#'s before you letrrip.
Ryan Bean
beans diesel performance
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems
Stealth Dual HPOP Systems
Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
BIGBEAN is offline
Old 12-03-2005, 11:37 PM   #12 (permalink)
If you are trying to have less smoke, I would say get some more oil or more boost. I really haven't driven the '96 in my sig much since I got the stage 1's in, but it practically DOES NOT smoke. It will, however, light the tires at 25mph. I have already seen 30# of boost - I attribute that to the 1.0 housing. I don't notice any more lag than stock injectors with no intercooler.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 12-04-2005, 01:07 AM   #13 (permalink)
"insert sarcasim here" Buy Bank's stuff, according to them a diesel isn't cool if it smokes, you are loosing power, yadda yadda. As soon as he has a street legal diesel beat a 10:13 in the quarter I may listen....
97' F250 CC 4x4 SB PSD 5spd 188,000 4:10's
LT265/75R16 Cooper Discoverer ATR's
Tymar Intake, HPX, 3X4 DP, 4" Street Exhaust
Custom Injectors
17deg HPOP
SD HT Starter
Shimmed FPR
Uniden Pro520XL
MaxRad Antenna
1000cca Everstarts
AIC
Autometer Gauges
Disconnected EBPV
ES bushings
Warn Premium Hubs
Rhino Liner
Custom goose neck
Chrome bed rails & body skirts
Custom wife dents
Stickers that make it faster (no really)
North West Ford Diesels Truck Club
Truck Pics
Pat_T is offline
Old 12-04-2005, 01:17 AM   #14 (permalink)
blowby's Avatar
Especially if they follow you to work "Department of Engine and Emissions Research" [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/depressed.gif[/img] [img]/ubbthreads/images/graemlins/vulnerable.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
PowerFool (N2O) by Dennis @ TS Performance
Tuning by Blowby abd DI
BTS built 4R100
603hp / #2 - 11.93
726hp / N2O - No runs yet (no tuning yet)
blowby is offline
Old 12-04-2005, 01:18 AM   #15 (permalink)
GSXRTURBOQUAD's Avatar
No, Diesels don't have to smoke like freight trains.
Your smoke issue is probably in tuning. Or you have low ICP, weak HPOP.
In my opinion, get Big Oil.
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
