Is this mod worth doing if you are already running a chip or are they not related to each other at all? For those who have done it were you able to feel a significant increase in power? I read somewhere that it could increase HP by 20. This seems like a cheap way to boost power but I am curious if its worth the trouble. Thanks
What the mod does is it ups the voltage to the injectors so they open up faster which is almost like an advance in timing. All engines sotck or modded from what I hear can benefit from this mod.
1996 PSD F-350 crew cab 4x4, AB CODE CALIFORNIA TRUCK, 5 speed,CON-O SMFW modified by Southbend Clutch, ORU Reverse Shackle kit, 4:10, u.s. gear chip, IDM MOD BY ME , down pipe, 4 inch straight pipe, boost and EGT gauges,PRO COMP A/T's 305-70's, Bilstein's, ditched the k&n filter for an open element Baldwin PA 2818, kenwood & polk audio sound system.
2002 Excursion PSD 4x4 XLT Premium- TN BB 1.0 Turbo , 6.0 IC, 8 inch Sky Jacker lift, FOX shocks with remotes, 35-12.50R17 BFG Muds mounted on 17x10 Boyd Coddington Billet wheels, ORU Frozen rotors, custom hybrid intake, DVD/2 monitors, Billet grill, XM radio, DP Tuner PCM QLJ5/PMT1 combo, Edge Juice/Attitude for gauges.
Definitely makes a difference. I actually can leave rubber on the ground now...maybe the mod wasn't such a great idea after all [img]/ubbthreads/images/graemlins/phoney.gif[/img]
'97 F350 PSD E4OD CC 4x4
265/75/16, BB shim=73psi, Open Element, 10K with switch on dash, IDM mod, 30K Hayden tranny cooler, 3" downpipe, 4" straight pipe, the usual gauges, Bullydog 6 position chip. Biodiesel as much as possible.
Joe Servo was up to about 300 bucks a pop before I reverse engineered it and posted the instructions (which were then confirmed by a few others in the know).
Now its about a 50 dollar mod for time and shipping.
Works best on IDM 100 and IDM 110's. Not as noticeable on IDM-120s (newer SD trucks tend to be 120's)
No that is because the mod increases voltage to the injectors to a theoretic by electrical theory that is to around 140 volts, 120 to 140 is obviously not as big a change as 100 to 140. I had the idm 100 and noticed signifigant gains. I think that the reason the SD trucks went to the higher voltage is to make calibration specs as far as timing goes, more set in stone, the injectors will respond faster to inputs, to help to compensate for a better need for precise timing control for the "split shot" fuel injection. JUST speculating on why they did it though.
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
Thanks FF and JDB... I knew the voltage was 140 on the modded IDM's and I should have figured out what the 100, 110, and 120 meant. Thanks for clearing that up for me. That has been a mod I wanted to do for a while and I hope to get both of my trucks done in the spring.
well worth the trouble. ive done mine and a few of my buddies idms, weve all noticed a difference.
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille, 318hp 643tq #24 sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
