06-03-2008, 06:01 PM
#1 (permalink )
idm mod question
does it matter which way the resister get sodered in?
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
06-04-2008, 12:18 AM
#2 (permalink )
resistors have no polarity.
06-04-2008, 01:31 AM
#3 (permalink )
thanks for the reply.
anthony
Parts Replaced:
Parts Replaced
06-04-2008, 05:58 AM
#4 (permalink )
Make sure you use a good resistor not a cheap Radio Shack one.
IDM Mod
1997 F350 XLT, Centurion Pacifica Pkg, AT, 4.10, 3"DP, DB Exhaust Brake, BD Auto Lock, US Gear Boost, Trans & Pyro Guages, Air Lift Rear Bags With in Cab Control, On Board Air, 100G Fuel Tank in Bed, Ranch Hand Grill Guard & Headache Rack, CB With Dauls
BLT 10/96 185,000 miles
1996 C350 Classic Centurion, 7.3L, AT, 4x4, 4. 10 Rear, Bank's OttoMind, FPR Shimmed ,1.00 Turbine, 3" DP, Isspro Boost, Pyro, & Trans Temp Gauges BLT 10/95 176,500 miles
Linear Mode
» Site Navigation
» Other Sites
» Buyers Guide
» Network Links
