Old 01-12-2007, 07:53 AM   #1 (permalink)
BardOrBrad's Avatar
IDM mod ???'s
I'm thinking about doing the IDM mod. Those of you out there that have it, what do you think about it? Pro's & Con's if there are any. If it's worth the time & money. I've heard that this mod increases injector noise? What does that sound like?
Thanks for any reply!
97 350 XLT SRW CrewCab, 4X4, 4:10's, Gauges, Tymar OAE, HX hose, 6p chip, no EBPV, ORU RSK, Evans Coolant with inline filter, PLM tranny and diff covers, 203 T-stat, Spin-on in-line trans filter & true cool cooler, 5" exhaust, IDM mod, AC mod, Banks IC, hada PULSE HPOP but a 17 willdue4now, DIY Stage I's, Dieselsite CPR OBS electric fuel system, Gregg Evan's Monster in a BOX!
BardOrBrad is offline
Old 01-12-2007, 09:35 AM   #2 (permalink)
My Photos: (9)
Re: IDM mod ???'s
I can't really comment on doing the mod as I did not do mine. I have heard from those that have done it and they say it is fairly easy to do. I like mine and have noticed no down side or injector noise. You will notice a little more low to mid range power.
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
SLAPS Treasurer
Member of FOKISD
<font color="red"> #5 </font>
Truck pics at http://community.webshots.com/user/ytee1100
ytee is offline
Old 01-12-2007, 10:24 AM   #3 (permalink)
DIESELDUTTON's Avatar
Re: IDM mod ???'s
What Chris said, I put mine in two days ago and I dont notice and more injector noise, the biggest change I noticed is when I'm going down the road at 50mph before idm now I'm going 60mph with my foot in the same spot. You know that (spot)does this make sense to ya ? [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 01-12-2007, 02:42 PM   #4 (permalink)
My Photos: (32)
Re: IDM mod ???'s
I didn't notice any extra noise either.
The job is not tough if you are careful. I followed Fordforgotten's instuctions, only I did it before he updated it to show 1/2 watt resistors whereas he showed 1/4 watt resistor up until a few months ago. I don't say this to criticize, I just mention it in case you had printed out the instructions before he updated the info!
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
Old 01-12-2007, 03:00 PM   #5 (permalink)
PSDan000's Avatar
My Photos: (11)
Send a message via AIM to PSDan000
Re: IDM mod ???'s
yep, the mod is fairly easy. just take your time with it and make sure you have a good variable temp soldering iron with a small tip. its also good to have a hot glue gun to put some hot glue around where you soldered so it does not come loose later from rattling around. ive done the mod for 4 local guys and a few others, no one has noticed any difference in noise but all have noticed a good low end power increase. good luck to ya.
-Dan
1996 F-250 PSD, 195k, 4x4, Supercab, LB, 3.55's, 4" lift, Built Auto with Precision converter, 150cc injectors, Autometer Z-series Pyro/Boost/Tranny/Diff guages, DIY open element intake, Sandpiper Diesel Performance 4" exhaust, TS 6pos. chip with 2L Motorsports tunes, Shimmed FPR, Modded IDM, Stainless HPX mod from ITPDIESEL.com , Baldwin Coolant Filter from Dieselsite.com , Bilstein shocks on all 4 corners, 315/75 BFG A/T's on 16x10 black Rockcrawlers, Custom front bumper, Ranch hand rear bumper, Warn manual hubs, Sparky's AIC, Full chrome grille,
318hp 643tq
#24
sitting in the garage: 6.0 Intercooler
My Webshots
[URL="http://www.thedieselstop.com/forums/
PSDan000 is offline
Old 01-12-2007, 10:02 PM   #6 (permalink)
BardOrBrad's Avatar
Re: IDM mod ???'s
Thanks all for the replies. Dan, where did you get your resistors from and do you have any pics of your IDM? I know of the one site from "Forgoten.net" I was wondering if there were any others. I'm confused if I need 1/4 or 1/2 watt resistors.
Old 01-12-2007, 10:19 PM   #7 (permalink)
Re: IDM mod ???'s
B or B,
The mod is very worthwhile-- having said that, I'm not sure that I could tell if I never knew it was done, but I do and the throttle tipin just 'feels' better. Definitely comes on better in low and mid; I have spots on my route where if encouraged it wouldn't spin the tires and with the same 'encouragement' it does now. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
94 F250 SC, 4x4, 5spd, 4.10ls, LuK, Toyo Country AT 285/16s, 190K, edge evo, shimmed FPR, Bilsteins, Add-a-leaf, 3"DP/4" exh, new ACs, ISSPRO, Term. 17* HPOP, pedestal mod, Tymar Intake and HPX, IDM and CCV mods
335HP, 716TQ (3-08)
mandkole is offline
Old 01-13-2007, 12:24 AM   #8 (permalink)
Ford_Forgotton's Avatar
Send a message via ICQ to Ford_Forgotton Send a message via MSN to Ford_Forgotton Send a message via Yahoo to Ford_Forgotton
Re: IDM mod ???'s
My site (forgotton.net) is the only one Im aware of that is openly posting the info.
While a 1/4 watt resistor will work, I now recommend using a 1/2 watt resistor just for some headroom.
If you do the math, (ohms law, voltage/resistance/amperage calculations followed by amperage/voltage calculations) you'll find that your running right at 1/4 watt of power, thru a 1/4 watt resistor. So going to a 1/2 watt just gives a little beathing room.
The 1/4 watt resistors were used for a long time (thats what I found inside the pics posted on my page, and it was supposed to have been a DI modded IDM).
Daryl
Forgotton.net
Northwest Ford Diesel Truck Club
2000 F-350 CC SB 4X4 SRW BONE STOCK!
Ford_Forgotton is offline
Old 01-13-2007, 12:31 AM   #9 (permalink)
My Photos: (32)
Re: IDM mod ???'s
I believe Digi-Key will have the 1/2 watt resistors too.
I used the 1/4 watt resistor back in June ('06) and have not had any problems. In that time we have towed our trailer to California and back, no problems w/ the 1/4 watt. If I did another one I'd go for the headroom Daryl mentions!
TC
TimC63 is offline
Old 01-13-2007, 01:05 AM   #10 (permalink)
Pike's Avatar
Re: IDM mod ???'s
When you order from Didgi-Key have them ship 1st class mail and that will save you some money. The Grey silicone from Ford is the most expensive part of the whole deal.
96 F250 SuperCab Short Bed, 4X4, 5spd, LUK SMFW and Clutch, 4.10LS, D60, 3" Down Pipe, Gutted EBPV, Tymar intake, Banks Intercooler, DIY 160 Injectors, TW 4 Pos. Chip, DIY IDM mod,"KCM"HPX mod, Superduty fuel heater mod, 203*Tstat, D Pricol Gauges.
Pike is offline
Old 01-13-2007, 01:56 AM   #11 (permalink)
PSDan000's Avatar
My Photos: (11)
Re: IDM mod ???'s
digikey part number for the 75k ohm 1/2 watt resitors: PPC75.0KXCT-ND
the resitors are cheap but they get ya on the shipping and handling, probably be around $10 to your door for 5 resitors. definitely go with the GOOD RTV at the dealer. tell them you want the stuff for the 7.3 diesel, it'll run ya around $20 for a half caulk tube, which is more than enough to do your IDM. i dont have any pics, just followed what i saw on Forgotten's website and all was well. good luck [img]/ubbthreads/images/graemlins/cool.gif[/img].
-Dan
318hp 643tq
#24
My Webshots
PSDan000 is offline
Old 01-13-2007, 06:55 PM   #12 (permalink)
BardOrBrad's Avatar
Re: IDM mod ???'s
BIG THANKS guys for the replies! I'll get with Digikey and get dem resistors. Looking forward to adding it in now. Thanks again!
Old 01-14-2007, 11:39 PM   #13 (permalink)
Re: IDM mod ???'s
Kind of a dumb question maybe, but do you need your chip reburned for doing this mod?
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 01-18-2007, 09:49 AM   #15 (permalink)
Re: IDM mod ???'s
Sorry, but I'm just a little confused... Yea.. [img]/ubbthreads/images/graemlins/shrug.gif[/img] I know whats new [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
But as I read Dayl's website, forgotten.net about the IDM mod, I don't know what value resistor to use for what voltage I want out of the IDM.
here is what I cut and pasted from his web site. The IDM-100 and IDM-110 is what I need help with...seems the resistors are the same???
<font color="blue"> IDM-100 uses a 75.0k Ohm (75,000 ohm) </font> 1/2 watt 1% tolerance Metal Film resistor
<font color="blue"> IDM-110 uses a 75.0k Ohm (75,000) </font> 1/2 watt 1% tolerance Metal Film resistor
IDM-120 uses a 73.2k Ohm (73,200) 1/2 watt 1% tolerance Metal Film resistor
DigiKey sells the needed resistors:
75.0KX (Violet-Green-Black-Red-Brown)
73.2KX (Violet-Orange-Red-Red-Brown)
Does the Nomenclature IDM-xxx siginify the type of IDM you have or the voltage out? I guess this is the point of my confusion, combined with the resistor question...
Have I totaly confused the issue and am thinking too much or what???
I couldn't sleep last night and read this post, thought I could go back to sleep and read it again this morning and it would be clear, NOT...
Thanks in advance for clearing this up for me, and I'm really a pretty good with a soldering pencil, but here lately thinking is up for grabs...
RoReRi
New to me... not anymore...
02' 4x4 | F250 | CC | SB | Auto | 3.73 rear end
Running boards | Tow Mirrors | Tymar intake | DP-Tuner 80hp Eco, Stock, 60hp Tow | Fumoto drain | Sony,CDX-GT610UI | 2.5" TuffCountry leveling kit
96' 4x4 F250 EC 4"lift Ranch Hand Front and Rear bumpers. Tymar intake and downpipe & Cat delete pipe. 203 degree T-stat, $40 AIC, Stage 1 INJECTORS...
Running WVO since May '04
Be without fear in the face of your enemies
Be brave and upright that God may love thee
Speak the truth even if it leads to your death
Safeguard the helpless
THAT IS YOUR OATH
roreri is offline
» Site Navigation
» Home
