Old 10-03-2008, 10:49 PM   #16 (permalink)
Originally Posted by Big Jeremy View Post
I just recieved my copy of DIESELPOWER and there is a good write up about the IDM mod it even has pictures. after reading it I'm thinking I'll do it myself. I'm adding it to the list of other things to do
what page is it on ??
95FORDBOY is offline
Old 10-04-2008, 01:41 AM   #18 (permalink)
of the oct issue
on 184 i have a converter add and on 185 theres a diesel tech on conservation of energy
Old 10-05-2008, 01:03 AM   #20 (permalink)
aaaa i just got my oct issu
Old 10-05-2008, 05:27 PM   #21 (permalink)
95FordBoy most of the IDM's look different internally I have done the mod quite a bit and noticed the same thing as you have discovered.
1996 Powerstroke
127,000 and counting...
MODS:
~ AEM intake
~ Tymar 3-4" ceramic downpipe & 4" MBRP exhaust
~ fpr shimmed
~ TS 6 pos. chip
~ electric fans
~ dfuser 18K module
~ Custom ported turbo w/ 1.0 turbine housing
~ 3" superduty intake plenums
~ Banks intercooler
~ IDM mod
Curently Working On:
~ E4OD Transgo shift kit
SuperDuty73 is offline
Old 10-06-2008, 01:07 AM   #22 (permalink)
ok
so theres only the one resistor that has 6042 on it and thats the one i need to change right ?
Old 10-07-2008, 02:59 AM   #23 (permalink)
Ford_Forgotton's Avatar
Send a message via ICQ to Ford_Forgotton Send a message via MSN to Ford_Forgotton Send a message via Yahoo to Ford_Forgotton
Originally Posted by 95FORDBOY View Post
ok
There are 4 styles of IDM that I am aware of.
IDM 100
IDM 100a
IDM 110
IDM 120
That looks to me to be either an IDM 100, or an IDM 100a.
As far as Im aware, you only change the one resistor marked 6042.
For those of you that just "break and remove" the old resistor, A word of warning. You can very easily "tear" or "lift" the copper pad that is bonded to the circuit board material. If this happens, you are seriously screwed. I've done better than 2 dozen IDM mods now, and havent had any lift on me yet, but then, I use solder wick and a really hot, small, chisel point to get the solder off.
Im curious how the article in the magazine looks like. Joe Servo managed to keep the mod a "secret" for many years. *NO ONE* would post what it was he did, even tho several ppl knew the "secret".
I finally got someone to send me their modded IDM (I wasnt about to shell out 300 bucks! for Joe to do mine). I opened up his case, found the changed part, did some math, and posted my findings. It has since become a "common" mod, but ppl do still get scared of the whole electronics thing.
Daryl
Forgotton.net
Northwest Ford Diesel Truck Club
2000 F-350 CC SB 4X4 SRW BONE STOCK!
Ford_Forgotton is offline
Old 10-08-2008, 01:15 AM   #24 (permalink)
its a 100A
Old 10-19-2008, 12:27 AM   #25 (permalink)
kaquinn's Avatar
sweet! i hadn't looked at my Nov Diesel Power, i still had Diesel World on the thrown! Nice to know someone at Diesel power is paying attention!
97'F-250HD 4x4 7.3 cc,sb AFE stage II, MBRP-ss 4", BD-brake, DP-tunner chip, mostly BD trans, auto meter C2 gauges overhead
03'E-350 7.3 DRW cutaway-KUV 410 posi.
05'Explorer XLT 4.6 V8
94'Taurus SHO 3.0 5-speed
04'Mazda6 (had to go for now honey need AWD)
06'Murcury Mountineer
85' F350 4x4 6.9 w/banks sidewinder under the knife!
94' F350 4x4 7.3 N/A under cont./ referb.
kaquinn is offline
Old 11-12-2008, 10:27 PM   #26 (permalink)
Thumbs up
I just did the mod tonight on my 100a IDM module, PIECE OF CAKE !!
Like said earlier, just use a good soldering iron, some desoldering braid and some good solder.
I scraped the board with a razor to get a clean work area too...
Whole process including case opening took under 10 minutes !!
Thanks guys !!
73 AND BEST DX,
DE KB3MMX CHUCK
KB3MMX is offline
Old 11-13-2008, 07:41 AM   #27 (permalink)
"But these are not ordinary radio shack resistors! They are special, high tolerance, heat resistive,
metal film resistors that are about 40 cents a piece, versus your usual 5 cent rat-shack ones.
Its imperative that you use high quality parts as any drifting of the values could result in a
blown IDM."
Where where I aquire the appropriate resistor?
"DigiKey sells the needed resistors:
75.0KX (Violet-Green-Black-Red-Brown)
73.2KX (Violet-Orange-Red-Red-Brown)"
Never heard of DigiKey, is there a local place I can go to deal with somebody face to face?
-Calf_Roper
Calf_roper_John is offline
Old 11-13-2008, 09:25 AM   #28 (permalink)
I called around to a bunch of electronic supply houses and could not come up with any that met those specs, I ended up ordering them from Digikey.com and it was good service, a little pricy on the shipping, but I had the resisters (cause I had to buy 5) in two days. cost was $5.99 including shipping.
Justin
'96 F250 HD Crew Cab Short Bus, built E40d, 4.10 ls 305s on stock Alcoas IDM mod
DixieJeeper is online now
Old 11-13-2008, 09:58 AM   #29 (permalink)
DIGIKEY is where I got mine too...
I had to order 5 at a time minimum....oh well...
Got the IDM back in the truck this morning after letting it dry overnight in the warm house......
WOW !! This mod was SOOOOOOO worth doing !!
The truck now lights right up when I hit the key and the increase in throttle response is AWESOME !!
Maybe mine gave more of a performance boost because I have the old 100a IDM ????
Anyway, IT ROCKS !!
Thanks guys !!!!!
73 AND BEST DX,
DE KB3MMX CHUCK
KB3MMX is offline
Old 11-13-2008, 10:19 AM   #30 (permalink)
ANyone got a scan or online version of the IDM article in Dieselpower? I cant find it any where around me, and I want to see it to check something.
Daryl
Forgotton.net
