Old 08-11-2006, 05:38 PM   #1 (permalink)
IDM modification
Just finished the IDM modification. It wasn't too bad to do. The cover was sealed on really really well so it was a pain to remove. I used a Radio Shack butane soldering iron to remove the old resistor and install the new one. The size of the soldering iron didnt seem to be much of a problem like I had read it might be. The only problem was heating both ends of the old resistor at the same time in order to remove it. Check out my webshots for some photos.
All in all the modification did seem to work. There is a very slight notice in increase of power and like everyone else says, it does run smoother. Its not as noticable though as the 10k mod but I think that it's a worth while modification for just 10 cents. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1997 F-350 Crew Cab 4x4 Cali truck - IDM mod (check my webshots), 10k mod, DIY 1C Kit 160cc single shots, fully modified fuel system all electric, seperate pumps with WMO system and tube-in-tube inline heater, typical pillar guages, no cat, no muffler, no ebpv, moded ccv
My Webshots
av8shunmeckaneck is offline
Old 08-11-2006, 05:56 PM   #2 (permalink)
My Photos: (13)
Re: IDM modification
No need to heat old resistor I just snaped it in half, then installed the new one. My 97 has the 100idm and also is a splitshot motor (cali) like yours, but is in a van and the mod is well worth it!!!
Works Great!!!
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 08-11-2006, 05:57 PM   #3 (permalink)
Believer45's Avatar
My Photos: (16)
Anyone have a link to instructions? I checked the tips and tricks and did a few searches with no luck.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is offline
Old 08-11-2006, 05:59 PM   #4 (permalink)
There are some links on JOAT's Page.
'97 F-350 CC LB 2wd Verk Truck, 280k miles, Tymar intake, SD starter, 203° thermostat, A/C mod, 3" DP, 4" exhaust, negatory on the cat, Stancor GPR, stock otherwise.
texasellis is offline
Old 08-11-2006, 05:59 PM   #5 (permalink)
My Photos: (13)
Do a search on Joat.
His web page explains the Mod.
I do not know how to link.
Maybe someone can link to this post.
Joats PSD Page (idm mod)
Bill
MADVAN is offline
Old 08-12-2006, 03:30 PM   #6 (permalink)
Dave / Believer45
Here is the link that I used.
My Webshots
Old 10-02-2008, 10:49 PM   #7 (permalink)
Are you able to modify the idm on 6.0 powerstrokes
sharestroker is offline
Old 10-02-2008, 11:01 PM   #8 (permalink)
I just recieved my copy of DIESELPOWER and there is a good write up about the IDM mod it even has pictures. after reading it I'm thinking I'll do it myself. I'm adding it to the list of other things to do
1996 F-350,CC,LB, Rebuilt Tranny,Billet Trq conv,shift kit, AFE Stage 2 intake, 3' dp, 4''Diamondeye exh with flow through muffler, 35"BFG's,no lift,new engine wiring harness,new fuel heater(dealer fixed due to a short before I found this site,knowing what I know now I would have just unplugged it),new glow plugs at about 145,000 mi,balljoints,bearings,rotors,all new steering linkage,GPR,powersteering pump,steering wheel bearings,IDM mod,rebuilt turbo and gutted EBPV and pedestal,just over 175,000 mi,
Big Jeremy is offline
Old 10-03-2008, 01:20 AM   #9 (permalink)
Supporting Member
mattski's Avatar
IDM Mod
97 F350XLT, CC, SRW ,LB 4x4, 4.10LS, E40D, genuine Tymar intake, Diamond Eye 3" DP- 4" back to 5"tip, Stage 1 inj, IDM mod, gutted EBPV, modded pedestal, TW 6 pos chip, 1.0 turbo, shimmed FPR, Dipricol Optix pyro, boost & tranny temp on A-pillar, Pioneer CD, SIRIUS Sat.
Next up: SD I/C, SD HPOP & tranny cooler
mattski is offline
Old 10-03-2008, 01:46 AM   #10 (permalink)
Rtxcoon's Avatar
its a pretty easy do it yourself mod if you are comfortable with a soldering iron....its not as hard as alot of folks make it sound...just get the right parts, and make sure you dont splash alot of waste around while your in there...Joe sure did make this popular and did alot of research on it, and I think its worth the time, should result in better throttle response at the minimum...
this is the start:
Powerstroke Diesel IDM mod
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
Rtxcoon is offline
Old 10-03-2008, 04:23 PM   #11 (permalink)
Question
How can I get a copy of DIESELPOWER?
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; gutted Kitty; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 10-03-2008, 04:44 PM   #12 (permalink)
klhansen's Avatar
My Photos: (92)
The 6.0L doesn't have an IDM per se. It's called something else that slips my mind right now, but it's a completely different animal.
You're going to have to wait on some smart person like JoeServo to invent the (IDM) mod for the 6.0L
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 10-03-2008, 07:19 PM   #14 (permalink)
Talking
Originally Posted by BlueMule View Post
Jose
Are you looking for the magazine or just the IDM article? Rusty (Rtxcoon) in the post above yours was the one who did the mod for the magazine. Try sending him a PM and see if he can send you the info.
Thanks Rodney, I just wanted the article. I will PM to Rusty.
Old 10-03-2008, 08:42 PM   #15 (permalink)
my idm dosnt look like any of the idms iv seen on the net
http://i104.photobucket.com/albums/m...L/c4c47c60.jpg
is it the blue little guy that says 6042
http://i104.photobucket.com/albums/m...L/97ef1994.jpg
95FORDBOY is offline
