I'm thinking that I'm going to have to put a lower hose heater on my radiator to keep - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-10-2009, 08:20 PM   #1 (permalink)
midwestconnection's Avatar
To keep from breaking my block.(hot frying pan-put in cold water)( it will bust right in half)
You can't add ice cold water to a hot engine and that is what is going to happen when my Kim Hotstart heater brings my temp gauge to half and I start the motor and instantly the ice cold water from the radiator surges through the hot motor, even though it's not boiling hot.
I think it will ruin my motor.
Bumper to bumper, Full Synthetic!!! Rotella T 5-40(7.3L) -- Mobil 1 Mercon V(E40D) -- Amsoil Extreme 75-90(Danas 60) -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 XLT Club Wagon 15 Passenger Van. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
Old 11-10-2009, 08:41 PM   #2 (permalink)
timberjack's Avatar
My Photos: (17)
Please elaborate. How does the hot water circulate? Or do you expect the heat would only rise from ?convection?? and when started would then circulate via the engines waterpump?
I'm not familiar with the "hotstart" system, or frankly even heard of it. I think your best solution would be to have a circulating pump somewhere with this heater, and then it won't be an issue.
Never mind, just saw your other thread. I'll monitor that one.
2007 F-250 XLT 4x4 Supercab PSD - Such a screaming deal I couldn't resist
1996 F250 XLT 4X4 Supercab PSD, Dana 60, Boss PowerV-XT 9'2" snow plow.
Webshots of some of the riggin' and scenery
timberjack is offline
Old 11-11-2009, 04:37 AM   #3 (permalink)
I'll know more here in a few hours. In ten minutes the heater hose and unit itself are hot. It's circulating but I don't think that includes the radiator. I'd be bird happy id it did. It's 30 minutes now and I can just barely feel heat touching the valve covers, or mabe that's wishful thinking. Another hour will tell.
Old 11-11-2009, 06:39 AM   #4 (permalink)
ford_doctor's Avatar
What do you think happens when you normally start the truck up without any type of engine heater? The engine gets hot then the thermostat opens and in comes the cold coolant from the radiator...
Ford Master Diesel Technician
Diesel Technician Society
ford_doctor is online now
Old 11-11-2009, 07:34 AM   #5 (permalink)
True but there is "some" flow through the thermostate before it opens all the way letting enough through I'm guessing to reduce the shock factor a lot, vs an open thermostate with a hot motor and ice cold and -30 below coolent hitting it hard all at once.
Old 11-11-2009, 10:55 AM   #6 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
There should also be some heat flow through the system anyway. If I plug my factory block heater in, it not only heats the coolant in the block, the radiator gets nice and warm as well (as does the oil). I don't think you should have a problem. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 11-11-2009, 11:19 AM   #7 (permalink)
I don't know about the 7.3, but from this article about the new 6.7, it looks like thermal shock is something they test during engine development.
A thermal fatigue test is used to prove out the engine assembly process by stressing the head gasket, joints, radiator connections and other seals. For this test cycle, the engine is idled and then throttled up to peak power for about 14 minutes. That’s enough time for the engine to get red hot. It’s then shut off and 16-degrees below zero coolant is pumped in and allowed to soak for a few moments before the engine is fired back up to rated power. The shock loop is 150 hours long, or 75 cycles.
I don't know if this would be reassuring or troubling, knowing that it's somewhat similar to their extreme test conditions.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
webshots
RD97 is offline
Old 11-11-2009, 08:10 PM   #8 (permalink)
Tomorrow I am hooking directly into the block through the 1/2 inch plug I removed from the back of the drivers side head, just below the back bottom corner of the valve cover. It's 3/8 recessed for a 3/8 rachet or breaker bar. I soaked it with Liguid Wrench Penetrating oil and taped on it a bunch with the hammer and a 3/8 extension in the hole but very softly and more liquid wrench. It let loose nicely, I got to get a nipple to match the 5/8 hose and now I have direct thermosiphen directly into the block. It should make my whole motor like toast at -50 below. 120 to 140 degrees thermostat.
Tomorrow will tell. I'm betting on it. I was over to the guys house who has one and this is how he is hooked up only he's on the right front head and I'm on the back left head, both of us have both our in and out for the tank heater on the same side.
I think it's going to work.
Old 11-12-2009, 06:07 PM   #9 (permalink)
Good luck....
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
