went out this morning to head for the coffee shop weather 5 degrees and wind about 20mph normal for kansas
1997 F 350 4x4 auto block heater plugged in all night
would not start, heard buzzing under the hood it is relay number 3 which power the modded imd all maxi fuses are good, so now it is you guys to start guessing, or you know what is going on here????
__________________ 1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
First thing I would check for is a bad battery. Disconnect both of them and check the voltage of each of them independently. If one is bad, replace both. Cheers!
Could be a lot of things. Resistor came off in idm, bad cam sensor, have you had the recal done on that? Did you try swaping the "buzzing" relay. I have never not had my truck start even when I forgot to plug in or even when I had a cam sensor going bad. Is your tac registering? That is sure sign of bad cam sensor. HPOP resevoir full of oil? Bad fuel and it gelled? Hopefully nothing serious.
Good luck.
__________________ 1997 F350 CC4X4 120K superclean truck Beans 6 pos chip! IDM mod(it works!) Pyro, Boost and Trans Autometers over mirror. 4" straight pipe! 285/65X18's Nittos. Ford V-10 trans cooler, Tymar Intake, 6 leaker intercooler. Swamps 175/146 sticks fed by Adrenaline in front of a BTS. WOP QSSB turbo! 1997 F350 XLT 4dr 125K 5" Pipe no muf and no kitty (totaled). 04/04 F350 EX Cab LWB "Leveled" Lariat FX4 Limited slip. BFG's 295/75R16. 4" pipe from back of kitty exiting in front of rear wheel. Autometer Pyro and Boost guages 65K. 422hp and 772tq (SOLD) 96 F250 powerstroke extended cab. Original E40D 132K Wood hauling machine. 10k MOD. Autometer Pyro and Boost gauges. Gutted Cat. Sold.
1966 Mustang "mostly restored" replaced by 2009 Dodge Chalenger! My Youtube vid. http://www.youtube.com/watch?v=fdXy-bV6Zks
yes taking care of recall on cps, was replaced about 10 mom ago
You could try pulling your chip I had an Edge go bad and truck would not start but everything else was nomal.
Good luck
pulled the chip a month ago thinking about a new flash
switch relays as drwoodchopper, thanks, suggested and fired right off thanks everyone for the help that is what this forum is for
relays usually chatter because of low voltage don't have a wiring diagram so i don't know what energize it
thinking about a new chip looks like i will get twildman to think up a new burn
i don't know if many manufactures read these forum but they seem to be passing buy the old body stile trucks i don't know about the rest of the country but where still kichin butt here, are trucks are not fancy to look at but they run
