Improved Ride!! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 05-11-2008, 04:09 PM   #1 (permalink)
Improved Ride!!
Hey Guys,
I had 33" Bf Goodrich tires and my rig rode like hell. I just put on toyo open country 35" tires and I feel like I'm driving a redneck cadillac! With some Billsteins, I'll be set!
1995 F350 7.3 PSD Turbo Crew Cab long bed with factory Regency Conversion. @197k miles. Downpipe, 3 way Superchip, Tymar intake, 35" Toyo open country tires, wheels, and high pressure fuel pump modification. Texas legal exhaust
abruchey is offline
Old 06-04-2008, 12:23 AM   #2 (permalink)
I just added a set of BFG 285/75/16 Mud Terrains to go with my Bilstiens and the ride is schweeet...
1997 F-250 HD 4X4 CCSB - TTB D50 - freshly rebuilt E4OD - 4.10
Tymar oil, open air intake & coolant by pass filter system(s) - Racor fuel filter - Bilsteins - BFG 285/75/16's Mud Terrains on Alcoa's - Hella long range driving lights, center mounted KC Off Road light with rear bumper mounted Hella fog lightswired for back up lights - Sony CDX-GT610UI CD/MP3/USB Reciever w/ iPOD interface - Garmin 600CSx
My Baja loving Power Stroke.
chronicplayer is offline
Old 06-04-2008, 09:13 AM   #3 (permalink)
Feedback Score: 3 reviews
If you have a 4x4 try a RS kit and SD springs to vastly improve the ride!
Cary
Cary
caryt is offline
Old 06-04-2008, 10:12 AM   #4 (permalink)
MJLankford's Avatar
x2 on the superduty springs.
1996 F250 XLT, CC, SB, 4x4, 270,000 miles, 4.10 gears, E4OD, Tony Wildman 4 Pos. Chip, Shift Kit, Downpipe and 4" exhaust, 1997 F350 Dana 60 Axle swap with 3" RSK and 2004 F550 Superduty Springs "X codes", 16x8 Classic II and LT315/75R16 Nitto Terra Grapplers.
Truck Pics
MJLankford is offline
Old 01-30-2009, 04:19 PM   #5 (permalink)
Hello-
I have a 97 F350 with a 4inch block lift. it rides terrible and I am looking for a low cost, yet quality fix. I have heard a lot about the reverse shackle system and Super Duty springs....Are people just using super duty springs from the junk yard or buying after market? Also, does this affect my towing capacity?
Thanks-
Adam
adamwartman is offline
Old 01-30-2009, 11:35 PM   #6 (permalink)
DIESELDUTTON's Avatar
Originally Posted by adamwartman View Post
Hello-
Thanks-
Adam
I bought my front springs form the guy that I bought the Dan 60 from (junk yard) and my rear SD springs came from a guy that put a air system in. My capacity went up since I put in 350 springs, the truck will squat about 1 1\2 with my 9500lbs camper, then I just hit the in cab switches to add some air to my bags and I'm good to go. I cant stand the nose pointing up, not to mention the lights blind on coming traffic. Good luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 01-31-2009, 09:41 AM   #7 (permalink)
ammayernick's Avatar
Frank,
I have been talking to GNXTC (also in Jersey) about his superduty / RSK set-up. He claims the ride is incredible. I believe most lean to buying all new parts. I need new rear shackle mounts so I'm going to do this all at once.
Andy
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps * http://community.webshots.com/user/ammayernick
ammayernick is offline
Old 01-31-2009, 12:44 PM   #8 (permalink)
ThreeStarJR's Avatar
Cary
Listen very closely to what this man tells you. Cary is "THE OBS SUSPENSION GURU!" Cary just finished doing a complete '08 suspension under an OBS truck that is as slick a set up as you'll ever see.
He can be contacted here:
Home
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
#3
ThreeStarJR is offline
Old 01-31-2009, 07:31 PM   #9 (permalink)
PSDfreak's Avatar
Home
x2...Cary has a very good understanding of these suspensions and what works best...very good resource
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
Old 01-31-2009, 08:38 PM   #10 (permalink)
4micaman's Avatar
Did Cary build this twisted bronco? That's just plain amazing! But his 08 suspension conversion is bad to the bone!
Nice work, Cary!
-Steve
'95 F-250 Ext. Cab long bed 7.3L 4:11 2WD
IDM Mod, HPX, DIY Intake
4micaman is offline
Old 02-01-2009, 10:57 AM   #11 (permalink)
Thanks for all the kind words! I have a disease..can'tleaveanythingaloneites
No I didn't build that one but I built this one..
Cary
caryt is offline
Old 02-01-2009, 04:49 PM   #12 (permalink)
4micaman's Avatar
LOL - roger that
Awesome work, Cary. If you need any other OBS to experiment on, I can be up there in less than two days!
-Steve
4micaman is offline
Old 02-01-2009, 08:04 PM   #13 (permalink)
diesel_brad's Avatar
Frank
Technically you didnt raise your gvw at all since there is no difference between 250 and 350 rear springs If anything i think you lowerer it buy using SD springs. My 97 SRW 350 wouldn't move when i put the goosneck trailer on it. My 00 dually dropped about 1.5-2" withe the trailer.. The SD springs ride nicer but i dont think they have the weight carring capacity of the old springs. O and my 97 had 150k of hauling a trailer and the 00 had brand new sprigs
86 F250 6.9 4spd 4x4 6"+315s's(coming soon POWERSTROKE,D60&zf5 )
00F350 Xcab Dually 7.3.ZF6, 4x4 SOLD
94 Lightning, Full Bassani exhaust,underdrive pullys, CAI, new paint w/ stripes
96F350, 4dr, 460, ZF5, 6"lift, 35"thornbirds, banks torque tubes, 3"custom bent exhaust, bbk throttle body, stull grill, clear front turnsignals, lund visor, 3.55gears
1980 F350 PULLIN TRUCK, 429, C6, detroit lockers f&r 10.25/D60 33' BFG muds
diesel_brad is offline
Old 02-02-2009, 10:49 AM   #14 (permalink)
The reason it didn't move is the OBS top overloads are almost touching with the truck empty unlike the SD which has to drop 2"+- to bring them into effect. The SD top overload spring is also longer and such gives a softer ride quality. When you use SD springs you keep your top overload...unless you want the SD one which requires you to relocate the frame stops.
Botom line both will carry the same weight its when they start is the difference.
Cary
caryt is offline
Old 02-02-2009, 03:54 PM   #15 (permalink)
Thats the thing. my 97 didn't have overloads. And that was just empty. Loaded the SD squated ALOT. The 97 just kinda sat there
