Improved Ride!! - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 02-04-2009, 03:19 PM   #16 (permalink)
Cary,
Would it be possible to get some info on how you did the converstion.
Dennis
dowrey is offline
Old 02-11-2009, 09:35 AM   #17 (permalink)
Send a message via Yahoo to boozer88
I'm in the same boat!!! I want to lift my truck also and I'm looking for some good tips. Just started looking at the RSK. I need more info please.
thank you in advance!!!
1997 F-350 PSD Crewcab
boozer88 is offline
Old 02-11-2009, 11:13 AM   #18 (permalink)
Feedback Score: 3 reviews
I have posted this so many times ..wish it would become a sticky
very easy..buy a RS Kit from Sky or ORU, install it 4" forward from where the instructions show it. Notch the bumper bottom end or relocate it forward to clear the front RS hanger.
Use V code front and B code rear SD springs, use SD bolts or 3/4" grade 8 bolts to bolt springs up you will need to drill out spring eyes and hangers to match the bolts used.
Must IMO use a adj track bar and correctly valved Bilsteins and longer SS brake lines. Droped Pitman arm is optional, High steer for a KP axle is best.
Feel free to check my pics or PM me.
Cary
Cary
caryt is offline
Old 07-02-2009, 07:36 PM   #19 (permalink)
ok...so I have finally located some front SD springs...Should springs from a 2000 F250 work? I have a 4 inch lift...do the SD stock sit that much higher? Also, am I wasting my time doing the swap without the RS kit? And, is it ok to only do the fronts with SD and leave the rear stock until I can find them? Thanks so much and Happy 4th of July to all!
Adam
adamwartman is offline
Old 07-02-2009, 08:17 PM   #20 (permalink)
BadDogPSD's Avatar
Adam
Depends which springs you got. The 'best' to use are V codes. W are a step up from V's and X' are a step up from W's. You'll gain +/- an inch with the V's, maybe 1.5 with the W's & X's (from what I've read). The SD springs are a tad over 3.5" longer than the OBS springs. You'll have to do something to make them fit. The RSK 'fixes' a design flaw and moves the shackles to the rear of the spring where they belong. The RSK, along with the SD springs greatly improves the ride. The RSK will add about 3" of lift, unless you go with SKY's 5" RSK, for 5" of lift.
You can just do the fronts, but you'll need at least 4" blocks to level out the ride if you go with the 3" kit.
1997 F250 4x4 Crew Cab PSD; Modded H2E, FFD Stage 2's, CPR Fuel, SRP1, ARP studs, Comp 910's, DI pushrods, Dana 60; Sky RSK w/SD springs.
BadDogPSD is offline
Old 07-03-2009, 11:56 AM   #21 (permalink)
Thanks so much! Ok...One last question...how do I tell if they are V codes or W or X? I have not physically seen the springs yet...are they stamped or how can I tell?
Thanks again!
Old 07-03-2009, 02:51 PM   #22 (permalink)
You will see a stamped spring code in the spring..or look at the trucks door decal.
Cary
caryt is offline
Old 11-15-2009, 11:26 PM   #23 (permalink)
back from the dead- I bought a truck thats lifted- Not sure how- It sags big time with my 38ft sand piper fifth wheel- I just added some air lift helper bags- A neighbor told me about the reverse shackle mod will help it ride smoother so i looked it up and found this thread. THe the reverse shackle kit just for the front? anyone have any pictures?
97 F350 2wd PSD 5 speed
tymar chip, downpipe, ebp delete,
96 F350 Crew cab 4x4,
96 F800, 12v cummins, Eaton 6 speed
scotzilla is offline
Old 11-16-2009, 01:51 PM   #24 (permalink)
I have helped hundreds with this mod since I first did it 8 years ago. Pics and info..PM me.
Cary
Cary
caryt is offline
