Old 07-08-2006, 06:50 PM   #1 (permalink)
inercooler pipes
Hey i was wondering if any of the stock pipes or y pipe or spyder what ever you call it, from a super duty will fit in our trucks with a 7.3 cooler? anyone done it before?
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 07-08-2006, 09:36 PM   #2 (permalink)
My Photos: (6)
Re: inercooler pipes
Must be early 99 I got mine from Chris at the power stroke shop. 98.00 new.
You will also need reducer boots and new turbo clamp.
pm me I have part #s
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
249,000 Miles, and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
Old 07-08-2006, 09:44 PM   #3 (permalink)
ThreeStarJR's Avatar
The Early 99 y-pipe will fit the obs turbo, you need the wider flanged turbo to y-pipe clamp. The drivers side stock 7.3 pipe can be made to work by cutting it close where it passes by the a/c compressor and adding a boot or welding in a new piece of pipe. The passengers side will not work without extensive re working by adding some additional bends. Check out these series of pics... here... and ..... here... to give you an idea of the procedure....
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Wildman Tunes
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
play it loud!
#3
ThreeStarJR is offline
Old 07-09-2006, 08:28 AM   #4 (permalink)
DZLJIM's Avatar
Where did you get your boots at?
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB
DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
DZLJIM is offline
Old 07-09-2006, 09:37 AM   #5 (permalink)
Jimbo, the only two boots in the pics that are not factory is the blue one on the cac tube near the a/c compressor, Turbohose.com. and the 4" orange on the intake kit from airflo.com. If you need it, I'll get you part #'s on the stockers......
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP Fuel system
Wildman Tunes
Caltracs
play it loud!
#3
Old 07-10-2006, 12:56 AM   #6 (permalink)
so where can i get some steel j bends, seems like all i can find is alluminum
Thanks,
Jeff
1996 F-250 Powerstoke Diesel XLT, smokes bad, rides kinda rough.
open element air filter, H2E turbo, Custom Tranny, 6.0 Charge air cooler, Swamp 175/173 squirts, TS chip, A Cool Radio, COBRA truck condom.
WEBSHOTS-->http://community.webshots.com/user/dieselwiezil
-->http://houstonareapowerstrokes.com
DieselWiezil is offline
Old 07-10-2006, 09:34 AM   #7 (permalink)
so will a 3" intake spyder work on our trucks if you upgrade to 3" intakes? I've got a line on a spyder and intakes for cheap...does it mount to the turbo the same? Thanks.
97 F250 Crew Cab 4X4 3.55LS E4OD TS 6 POS Chip MBRP 4" Exhaust Custom Intake Will Work For Stage II Injectors!!!
Wifes Ride
01 Excursion Limited Powered by Powerstroke!
ryanp is offline
Old 07-10-2006, 02:21 PM   #8 (permalink)
Ryan, the 3" spyder does not fit our turbo. You would need to use a SD style turbo, build a wastegate actuator, modify the firewall, change the pedistal, and fabricate a custom downpipe. Also you will need the SD exhaust collector, up-pipes, possibly the drivers exhaust manifold as well. Also you will have to eliminate your stock fuel filter housing/fuel pressure regulator. The rest would be easy.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 07-10-2006, 06:06 PM   #9 (permalink)
anyone know where can i get some steel j bends, seems like all i can find is alluminum bends?
Thanks,
Jeff
WEBSHOTS--&gt;http://community.webshots.com/user/dieselwiezil
--&gt;http://houstonareapowerstrokes.com
Old 07-10-2006, 06:36 PM   #10 (permalink)
Jeff,
Do a google search one: mandrel bent exhaust tube
I found mine at a local auto parts store that specializes in suspendsion and exhaust parts.
Maybe you need to move to Austin. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Jeff Blumenthal
Austin, Tx
97 F350 CC SWD 4X2 4:10, Wildman chip, AFE Stage 2, 6.0 IC, BD 4" Exhaust System, BD Exhaust Brake, BD AutoLoc, Tranny Shift Kitted, Billet Torque Converter, Tru Cool 4739 w/Thremal Bypass, EGT Shutdown Monitor, Air bags, EGT/Boost/Tranny Piller Guages
warpdriv is offline
Old 07-10-2006, 08:37 PM   #11 (permalink)
Briansshop's Avatar
www.intakehoses.com
www.turbohoses.com
They both have steel elbows,but I didn't see any J bends.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 07-10-2006, 09:55 PM   #12 (permalink)
Jeff,
need any diesel techs out that way in an A/C shop??? lol Man this heats killin me!!
Thanks,
Jeff
Old 07-11-2006, 12:43 AM   #13 (permalink)
My Photos: (32)
Summit Racing.
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
Old 07-11-2006, 08:25 AM   #14 (permalink)
DZLJIM's Avatar
I wonder if you got that new spyder, if you cut off the part that hooks to the turbo and at least use the Y for the intake from the 'cooler. Then, just come up with an elbow from the turbo to the 'cooler.
Cheap is cheap, make it work...
DZLJIM is offline
Old 07-11-2006, 09:20 AM   #15 (permalink)
My Photos: (6)
W00000 Housing (Y Pipe) F81Z*6K889*BA
W07905 Clamp F81Z*8287*DA
W06501 CONNECTION (Reducer BOOTS 2 NEEDED)
F81Z*6C640*FA
Cratos is offline
