Info On 96-97 F-350 B/W 4407 T/C Front Output Yoke - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 09-16-2010, 10:26 PM Thread Starter
I deleted the info on the yoke. The machine shop told me the spline count was the same as my original yoke, 31. The yoke I gave info on, and installed in my truck, is a 32 spline yoke. Now, I'm in the same boat as everybody else. I need the right yoke. I've had no problems with the yoke I installed, but I want it right. Sorry for the bad info guys!
OBS96 is offline
post #2 of 17 (permalink) Old 09-17-2010, 02:11 PM
Feedback Score: 3 reviews
How did you address the valley of the splines as they are also square
caryt is offline
post #3 of 17 (permalink) Old 09-17-2010, 07:15 PM Thread Starter
I didn't. Admittedly, that would have been best. The machinest I went to, said to try it without grinding the valley's, as he thought that might make it a little sloppy. Guess I could have bought another yoke, and spent the money to have it ground, as you're saying, but what he did, by shaving the tops, worked. I'm driving it. It's tight, and no problems. I guess you could still use the same yoke, and do as you say. It makes sense to me. Now, you have me wondering if grinding the valley's, would have indeed made it sloppy, or if they just didn't want to do the work.
OBS96 is offline
post #4 of 17 (permalink) Old 09-17-2010, 08:04 PM
Thanks for the information. I might have to go this route because I can't find a yoke anywhere. I was starting to think that i would have to swap the entire transfer case.
Dylan
97 F250,RC,XLT,4X4,E4OD,4.10, 195K TYMAR, D60, LINE-X, AUTOCOMAND, GUT EBPV,3 SSDP,HPO PLUG,Tru-cool 4950
97F350 CC,XLT,4X4,E4OD,4.10,137K,TYMAR,GUT EBPV,3 SSDP
NorthernVT is offline
post #5 of 17 (permalink) Old 09-17-2010, 09:40 PM Thread Starter
Okay now, I've been thinking about this: The output shaft has the same squared off splines. The yoke does not. If you squared off the tops of the splines on the yoke, you wouldn't have to worry about the valleys. you would just have a tiny little triangle space at the end of the valley, because the spline on the input shaft wouldn't quiet reach the bottom of the valley. The splines on the yoke, and the shaft, are the same pitch. I think what the machinist meant by saying it would make it sloppy, is because he would have to change the pitch of the splines, in the yoke.
OBS96 is offline
post #6 of 17 (permalink) Old 09-18-2010, 07:04 AM
The only issue with using an F250 shaft and yoke is vibration, correct?
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 150k mi. Dana 60, SD v code springs, RSK
psu927 is offline
post #7 of 17 (permalink) Old 09-18-2010, 09:37 AM Thread Starter
I don't know about the vibration issue. Somebody on here probably will though. The F250 U-joints are not the same size as the F350 though. You would have to have new end piece welded onto your driveline, to fit the F350 U-joint, and yoke. Then have it balanced, of course.
OBS96 is offline
post #8 of 17 (permalink) Old 09-20-2010, 10:11 PM
On my 96 and my 91, I just installed the original F250 front driveshaft like nothing ever happened. The length and U joint size were correct. Many have reported length differences, but it wasn.t the case for me x2.
On the vibes, it is only an issue if the hubs are in or it is in 4x4 and over 40 mph. Only an issue in the snow. And I don't get in the snow much.
I'm still planning on geting the corect shafts when possible, don't like limits!
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #9 of 17 (permalink) Old 09-20-2010, 10:39 PM
bugman's Avatar
My Photos: (12)
There was a TSB out on the vibration in the driveshaft and if you compained about it and you had the F250 you got the F350 driveshaft as a replacement. I did it along with a couple of friends.
bugman is offline
post #10 of 17 (permalink) Old 09-21-2010, 08:42 PM
I wish i knew about that TSB 9 years ago. Oh well. I'm still looking for a yoke. I found a shop in TX that I am sending dimensions too. Hopefully they can figure something out.
Dylan
post #11 of 17 (permalink) Old 09-22-2010, 10:36 AM
I'm running the spicer one with no problems....
/190K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/95 dana 60 / 6" skyjacker Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/bilstein 5100 shocks/Valeo clutch/31575R16 Cooper SST mt/K-9 Remote Security System/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
agomez is offline
post #12 of 17 (permalink) Old 09-22-2010, 01:06 PM
Their is someone trying to get them made right now..I gave up as I couldn't get my machinest off his...
caryt is offline
post #13 of 17 (permalink) Old 09-23-2010, 07:58 PM
Cary,
If somone is trying to get them made, is there a way to put in an "order" for one?
thanks
Dylan
post #14 of 17 (permalink) Old 12-14-2011, 09:48 AM
to you all with a 4407 transfer case. finaly a front cv output yoke is available. i found it on ebay. you can find it by typing in 4407 transfercase yoke
riebemac is offline
post #15 of 17 (permalink) Old 12-14-2011, 08:13 PM
Well, there is only 2 left now. Checked part number, checked feedback, done deal. Been looking way too long to let that go by. Thanks for the tip!
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
